block and oil pan heaters
Discussion in '1st Gen. Tacomas (1995-2004)' started by pilatus, Jan 5, 2014.
  1. Jan 5, 2014 at 11:55 PM
    pilatus
    pilatus [OP] Member
    kurt
    valdez, ak
    2002 sr5
    i live in valdez, but often work brings me to copper valley and fairbanks, would i be fine with just an oil pan heater or would i need to go all out with a block heater and battery heater? and which brands would all of you suggest
  2. Jan 6, 2014 at 7:17 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    I've considered the plug in heat options but have yet to install anything yet.
    The oil pan heater (Wolverine pan heater comes to mind) I will be installing during the next oil change since the skid plates are a bit hefty (Bud Builts). The factory block heater (for the V6) makes me a bit nervous since I have heard many reports of them leaking water and my truck needs to be as reliable as possible. I've considered a battery heater too, but I will need to modify the existing battery tray for that to work.
    In my mind the V6 doesn't need a block heater. My truck warms up to full operating temperature within the first 2 miles even when the temperature is 0F. The pan heater is piece of mind when it comes to wear and tear. The battery heater would be nice for those extended periods when the temperature doesn't get above 0F for days on end.
    For what it's worth, the factory block heater (400 watt) on my old 2002 Chevy Silverado 5.3 really didn't make much of a difference hence why I'm even more skeptical against it.
  3. Jan 6, 2014 at 11:32 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I ran a block heater in my 1992 Toyota (V6) Pickup and LOVED it - easy starts and instant heat! It had been in the truck for ~2yrs when I upgraded to my current Tacoma. FWIW, it NEVER leaked or gave me any problems.
    I've thought about putting one in the Tacoma, but never found any solid part number or reliability reports from owners. The same was true of oil pan heaters and battery blankets when I considered those a couple of years ago.
  4. Jan 6, 2014 at 11:41 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I have a magnetic oil pan heater that seems to do the trick. Went to go get it and found my wife had lent it out to a friend in town:eek: Her excuse was good: "You got a Toyota, all she has is a Jeep Cherokee." Good point, and good girl:D
  5. Jan 7, 2014 at 9:15 PM
    izzan67
    izzan67 Active Member
    West Virginia
    02 Tacoma
    ARE Camper Shell
    I was stationed in North Dakota for 4 years. I did have a garage and when I got home the truck would always go in the garage. My garage was insulated and not heated. I still had ice on the windows and doorknobs inside the garage and any liquid kept in the garage (except for oil and some alcohol would freeze. I did not have any type of heater on my truck and it would spend anywhere from 10 to 16 hours exposed to temps as low as -40 ambient (without wind chill). I did have a block heater on my jeep that I kept outside all the time. Both vehicles started up every time. Only one time did I have a battery trouble, block heater was not going to help me out in that situation. I did put what ever motor oil I was using in a plastic bottle and when it was unusually cold I check that oil to see if it still moved. Wasn't really worried about the engine block as long as the right antifreeze mixture was maintained. Just a thought
  6. Jan 8, 2014 at 2:02 AM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    I say go for it. The heater pads for the oil pan are cheap and easy to install.
    I have a block heater, oil pan heater and a battery warmer. I usually don't plug the truck in the until about 15° or colder. While it's nice to have since your truck warms up a lot quicker, I don't feel that the heaters are necessary. I've had my truck as cold as -30° and it fired up just fine without being plugged in. I also run synthetic oil.
  7. Jan 8, 2014 at 2:18 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    my 96 had a block heater..busted out on my while at my first TW meet..coolant everywhere. Screw those things.
  8. Jan 10, 2014 at 7:07 PM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Oil pan heater is worth the investment, synthetic oil helps as well
