Block heater anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Aug 17, 2015.
  1. Aug 17, 2015 at 10:46 AM
    vijay
    vijay [OP] Well-Known Member
    Hello team,
    Anyone from Alaska or far Canadian north here? Do you have a blocker heater on your Taco? If so, what brand? if not, how difficult is it to install it?
  2. Aug 17, 2015 at 10:53 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Hi there is a toyota factory block heater. It's made just for the taco. Do a search.
  3. Aug 17, 2015 at 11:43 AM
    vijay
    I know, but that was not even an option on mine. Just wondering if this is std at certain places. If I have to buy one now, then I'm pretty sure there are some aftermarket brands that "may" be better that OEM.
  4. Aug 17, 2015 at 12:49 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    I got the Toyota one. don't use it that often as the truck still starts fine at -30. a battery blanket would be a wise investment as that's where I've had my troubles, luckily I can open the garage door and boost of my car
  5. Aug 17, 2015 at 6:05 PM
    jstchilln
    jstchilln Well-Known Member
    Larry
    Ks
    2015 TRD Tacoma Sport
    None yet
    I had one on my 2011. It's an easy install and works alright. I used it once and a while when it was below zero and I had to park outside. Do a search there are a few write ups on them.
  6. Aug 17, 2015 at 8:58 PM
    Poindexter
    Poindexter Well-Known Member
    north of Denali
    15 V6 auto 4x4 mag gray
    The Fairbanks toy dealer does a winterization package on every vehicle they sell. $495 installed, block heater, electric pad under battery and one other I haven't tracked down yet, probably oil sump v- Trans pan. I'll get under there myself someday.
    Typically we start plugging in at 20 above, but on a timer so the block heater and Co come on about two hours before anticipated start time.
    I'm paying 25 cents per kwh up here, timer pays off quick on the electric bill. Also, timers start losing minutes every day at -20 and colder, so the heaters come on later and layet every morning. At -30F and colder I check the time on the timer daily.
    Most folks running synthetic oil in these parts don't fool with oil sump heaters.
    If you're not going to see sustained Temps much below -20F I would skip the sump and block heaters, run synthetic oil in the winter months and invest in a trickle charger instead of a battery blanket. Supposedly the batt will last longer and have a stronger charge every day on the trickle instead of a heating pad. Never owned one myself.
  7. Aug 17, 2015 at 9:11 PM
    gearcruncher
    Canadain bumper technician
    Twin batteries here with command start . Its 40 below for the better part of 6 months . Set the command start to run the truck every 6 hours when your at work and leave the block heater plugged in while the truck runs . Toyota uses a dry block heater on the 4 litre .I have since swapped to the wet style block heater (aftermarket }
    The factory block heater works ok if you give it 3 hours of operation time before you try starting the truck.
    If you skip plugging in the Taco at these negative temps , it will hardly start cranking very slowly and sounding like a diesel for the first 10 minutes . I highly suggest installing one if you plan to save your engine . I am also running synthetic oil in the winter
  8. Aug 18, 2015 at 4:43 AM
    FATaco
    FATaco Meh
    Friends call me Ginger
    Fairbanks
    07' TRD DCSB
    Dakars w/AAL, OME/886's, All Pro Front Bumper, Rear bumper, IFS skid, and UCA's. Superwinch Tigershark. Magnaflow muffler... vrooom
    Just installed the cartridge style this weekend. Super easy, honestly about 10 mins total. Purchased a Kats brand off eBay for $50. There's a good video on utube that will show you where to find the proper install location
  9. Aug 18, 2015 at 6:36 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Engine block heater in Georgia :eek:. If that's the case I'll need one in Virginia as we're 3 states above you.
  10. Aug 18, 2015 at 7:10 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    My 2014 has a Toyota block heater. The sales guy thought it was so cool because there's a plug type thing that is attached to the fog light. There is no cord sticking out of the grill or hood that you plug an extension cord to directly. You then have to attach this goofy cord with a strange end to plug in at the fog light. Then plug to a female end of an extension cord, then to an electrical outlet. Really dumb Toyota idea. Could've spent the money on this for heated mirrors instead. I've already broken the plastic housing at the fog light. Just get a regular block heater not the Toyota one. I only use it if it's -20C (-5F). or colder.
  11. Aug 18, 2015 at 8:11 AM
    FATaco
    FATaco Meh
    Fairbanks
    07' TRD DCSB
    You better get on that Rodzilla.... Winter approaches!! Jk, I'm moving to Fairbanks next month.
    R0dzilla75 likes this.
  12. Aug 18, 2015 at 8:31 AM
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    Yeah lol, just yankin yer chain. Enjoy Fairbanks though, you'll be putting the heater to good use.
  13. Oct 22, 2015 at 11:04 PM
    NickB
    NickB Well-Known Member
    Nick
    Bend, OR
    ‘19 DCLB TRD OR
    I've got the Kat's 11813 that I got from Carquest, it comes in the carquest box and costs a lot less than anywhere I found online. I can't seem to get the cartridge to slide all the way in though. Anyone have any thoughts?
  14. Oct 23, 2015 at 6:02 AM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    There is another thread on here that just installed one. On the 2015 there is a bracket blocking you from the install location. There is one (and I mean only one) socket, wobble, and extension that allows you to get it. Search it down and you will see. I thought about adding one. I'm in northern Ohio, but I go up to northern Michigan in the winter. I have one on my kubota tractor (diesel) and it makes a huge difference. Kinda makes me wonder if it would make the taco a little happier in the cold. If nothing else, it's nice to have heat sooner!
