Block Heater vs oil pan heater....or neither
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wyotaco06, Nov 4, 2010.
  1. Dec 1, 2010 at 3:17 PM
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    One thing to consider, a lot of new vehicle block heaters won't kick in unless the temp is below -18c. Not sure why that number, or weather this is true for the tacoma heater. Something to check on.
  2. Dec 1, 2010 at 3:24 PM
    wyotaco06
    wyotaco06 [OP] Well-Known Member
    Offroad 4x4 06
    Hmmm, I didnt test it out by plugging it in before installing it, no idea if it turns on at a certain temp.
    I really think that it turns on once you plug in the cord to a hot outlet.....anyone out there know?? Could always just crawl back under there after its been on for a bit and touch the surrounding area....
  3. Dec 1, 2010 at 3:49 PM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    May be a GMC thing only, the heater on my bro's 2010 has a sticker saying it will turn off above -18c. Something about a temp sensitive plug... Didn't see any such indicator on my tacoma
  4. Dec 1, 2010 at 4:33 PM
    wyotaco06
    Offroad 4x4 06
    Plugged it in and checked it about two minutes later, and the thing was pretty hot!!! Was surprised that it heated up so fast. Obviously the only part I could touch was the exposed area where the plug in goes into, but it was pretty damn hot after two minutes. I think this will warm the alumininum block pretty well and it looks like coolant surrounds this area.
    Its 20F right now so it will work at any temp. Just a little colder and I can USE it:D
  5. Dec 1, 2010 at 4:51 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The Toyota block heater heats up the minute you plug it in. I checked mine to make sure it worked before installing it.
  6. Dec 1, 2010 at 5:04 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    What is the big difference you see with a block heater? I did some work in Minnesota last year and had no problems starting the pos durango in -10F. True I did let it warm up for a good 30 minutes before I drove it.
  7. Dec 1, 2010 at 5:23 PM
    wyotaco06
    Offroad 4x4 06
    The big difference that I see is that it only cost $37 and took a half hour to put in:)
    But really the reason I got it is I think that it is better for the engine when starting the truck time after time when its below zero vs no heat at all. I figure anything that I can do to make it easier to turn over at those temps is better than nothing. PLUS, Toyota put that hole there for a reason, and it comes standard on trucks in Canada, where -10 is warm;)
    I know that I can start the truck at -20F all winter without the heater, but will feel much better about it if I plug it in for a bit before starting. It started more smoothly when it was -5. I want this truck to go to 300K:D
  8. Dec 1, 2010 at 5:42 PM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    I would do both. Warm oil will put less wear and tear on your engine. You can get magnetic ones so the instal is super easy. You could take it a step further and get a battery blanket(warmer) as well. The colder it gets the less power your battery is putting out.
  9. Dec 1, 2010 at 6:00 PM
    bigjoetacoma
    bigjoetacoma King of The Dirt
    Joe
    South River ON
    05 TRD offroad
    aftermarket head unit with ipod sync cable routed to glove box
    Can someone provide a link to the cheapest OEM block heater to buy online??
  10. Dec 1, 2010 at 8:09 PM
    a89aries
    a89aries Well-Known Member
    Alex
    London Ontario
    09 Tacoma TRD offroad
  11. Dec 1, 2010 at 8:16 PM
    jesseunvoas
    jesseunvoas Well-Known Member
    Jesse
    Swift Current, Sask, Canada
    08 TRD SPORT
    3" Ready Lift Super 80 Muffler AFE Stage 2 CAI Pro Dry Filter OEM Roof Rack RollBAK Tonneau Cover Cooper AT3 Tires Kakays On The Roof free candy topper
    i put on a circulating heater so when i get in the truck only a minute or so and it pumping warm air
  12. Dec 1, 2010 at 10:22 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  13. Dec 1, 2010 at 10:53 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    Makes sense. This is true, metal doesn't like sudden major temperature changes.
    When you say hole for a reason, is there a place for block heaters or does it replace a freeze plug?
  14. Dec 1, 2010 at 10:59 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Check the second link I posted, there is a hole in the back of the block where you can insert the space heater with the provided grease.
  15. Dec 1, 2010 at 11:25 PM
    #35
    snikch
    snikch Well-Known Member
    Ontario, Canada
    2012 TRD Offroad
    WeatherTech's, Freedom Tri-Fold bed cover, Toyota hood deflector and side window deflectors, Toyota skid plate, AstroStart remote starter
    Thunder Bay?? Crazy, that's where I'm from! Yeah, it gets damn cold.... so cold sometimes that it feels like you're driving on square tires for the first few mins. Block heaters are a necessity some days. The engine doesn't sound too good when starting at -40C without it being plugged in... I can only imagine the damage over time by repeating this. An hour of being plugged in is all you really need. Any longer doesn't really do much good.
  16. Dec 5, 2012 at 6:06 PM
    #36
    Silvert
    Silvert Well-Known Member
    Jeff
    Wisconsin
    2010 Tacoma reg. cab.,5sp., 4 cyl.
    Please let me know where you purchased your block heater for $37.00? Is it a Toyota product? How difficult was it to install? Could you please share basic directions?
    Thanks very much,
    Silvert
  17. Jan 13, 2013 at 7:14 PM
    #37
    campnowell
    campnowell Member
    Dave
    forest lake mn.
    06 Tacoma TRD SR5 4x4 crewcab
    Just install'd block heater on my '06' TRD 4.0 - only took 15 mins. after read this tread - Thanks Guy's. During installation took some Data for the non-believer's. Garage temp. 7 deg. 1/2 hrs. after installation 28 deg. after 2 hours 70 deg.
  18. Jan 14, 2013 at 1:55 AM
    #38
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    Block heater!
    Cheap addition, and you can hear the difference when you start it up. You'll still get the cold start motor whine like with any car, but it sounds (and feels) much much healthier.
    I had cold start piston slap on my old Subaru, and after installing a block heater it was barely noticeable. That just shows me how important it was.
  19. Jan 14, 2013 at 1:56 AM
    #39
    pra4sno
    Thanks for supplying this!
    Did you install the OEM heating element?
  20. Jan 14, 2013 at 5:48 AM
    #40
    Silvert
    Jeff
    Wisconsin
    Has anyone out there installed a block heater on a 4 cylinder? I have a 2010 Tacoma 4 cyl., 4x4, 5 speed. Where did you get the best price for a block heater?
    Thanks!
