Block Heater ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jcas, Sep 15, 2010.
  1. Sep 15, 2010 at 9:40 PM
    Jcas
    Jcas [OP] Member
    Montana
    2010 TRD
    I've been lurking for a while, just joined and have a question on block heater's, and coolant circulators. Which would you guys suggest. I live in Montana and work in North Dakota and winters/wind can get pretty harsh. I know that the dealer said "with synthetics today you dont need a block heater" but realistically I would like one and plan on installing one simply because it wont hurt. What are your opinions and what is a good product. Thanks in advance.
    4dr 2010 taco trd.
  2. Sep 15, 2010 at 10:25 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Get the one made for the truck installed. It's completely different from any other ones on the market. I have it installed in mine. Super cold starts are hard on seals. It will always start but the thing is it does do damage. Best plug it in when it's super cold.
  3. Sep 15, 2010 at 11:24 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Welcome from Butte! Check in at the Montana Taco thread and say hi! On an answering your question note, I suggest that you get the dealer one. You will pay more, but it is meant for the truck so it is worth it. As far as useage goes, plug it in about an hour before you're ready to go somewhere. It is sufficient time to defrost major components. The plugging it in all night thing is just a waste of power and unnecessary.
  4. Sep 15, 2010 at 11:39 PM
    Trap
    Indego Ink TRD OR
    I've been in places so cold that I bet I can make him rethink that theory. The Toyota one is really long, mounts at the back of the engine and sits right inside there. Really good metal to metal contact.
    Isn't Minot ND coldest spot in the USA ? I watch the weather world wide. Seems to be way colder there than here.
  5. Sep 16, 2010 at 1:47 AM
    JKD
    JKD Well-Known Member
    I don't know about the 4 cyl, but the factory/dealer 6cyl block heater looks like the easiest install I've ever seen.
  6. Sep 16, 2010 at 1:57 AM
    mountaincanoe
    mountaincanoe Active Member
    Colin
    Fredericton, NB Canada
    05 Tacoma 4X4 Access Cab
    Skyjacker Platinum Coil Over, 3 inch soft ride rear leaf pack, Nitro rear shocks, KN 63 series intake, Centerforce II Clutch, Vision X Lights, Pro Comp 7089, Dick Cepek 285/7516 Mud Country,4.88 Yukon, Detroit TrueTrac, ARB Front Locker, All Pro IFS skid, ARB on board air, All Pro Sliders, Allpro Apex front bumper,
    I had the block heater installed by toyota at time of sale. They told me it was a waste and not needed. Last winter we had days of -35 C and if it hadn't been plugged in it would not of started. Really recommend you get the factory one!
  7. Sep 16, 2010 at 10:26 AM
    reg boulette
    reg boulette Well-Known Member
    There is a how to on the block heater on one of the forums, however, (assuming a V6) it is quite easy. The block heater is about $100 (Can) at the dealer and comes with a bit of grease. There is a cylindrical indentation in the block proximate to the starter motor.
    The block heater slides into the opening and then clips secure.
    Job is made easier if:
    -vehicle is cold
    -up on ramps
    -block heater and cord are attached before insertion into opening. Grease the heater.
    -dangle the cord down 'through' the engine, crawl underneath, then insert heater.
    -route electrical cable and cable tie. (mine went round brake booster then front)
    -did not have to remove any wheel shrouds etc. as suggested in the DIY I read.
  8. Sep 16, 2010 at 10:29 AM
    emtlibby
    emtlibby Slaughtering goats
    Boston, MA
    2010 4x4 DBLCAB
    Dont forget, wind chill won't effect an inanimate object thats not producing heat.
  9. Sep 16, 2010 at 10:38 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Is the block heater on these trucks simply by contact?
  10. Sep 16, 2010 at 11:01 AM
    kb1jop
    kb1jop kb1jop
    Rick
    Webster, MA
    2020 Magnetic Gray Metallic SR5 Double Cab
    Factory Towing Package OEM Bed Mat Hard Tonneau Tacoma All-Weather Floor Mats
  11. Sep 16, 2010 at 11:06 AM
    sierrahsky
    sierrahsky Expedition Style
    Hi guys, Quick questions, I do a good amount of snow travel in my truck and am using my truck to run my huskies in the snow often. I was told by the dealership that a block heater would not help me at all when I am out in the woods in the snow because I could not plug it in. However I am starting in no colder than -10 and usually stay around 0 - 20 degrees. What are my options to help the truck out a little?
  12. Sep 16, 2010 at 11:09 AM
    reg boulette
  13. Sep 16, 2010 at 11:12 AM
    reg boulette
    Optima Red Top battery. Used one in the NWT, 5 days average temp -37 celcius, no plug in. Started up pretty well, although sounded like one cylinder, then the next, then the next......
    ghardy likes this.
  14. Sep 17, 2010 at 1:53 PM
    sierrahsky
    Nice, Thanks for the vote on the red top. A few others have said to go with that one as well and a couple had said the yellow top
  15. Sep 17, 2010 at 2:56 PM
    memario1214
    Colton
    Missoula, MT
    Yellow top is a great battery, but if you want maximum performance in cold weather, go with red.
  16. Sep 17, 2010 at 2:57 PM
    sierrahsky
    As usual, you want answers , ask TW !! Thanks guys, really helping!
  17. Sep 17, 2010 at 5:47 PM
    Jcas
    Jcas [OP] Member
    Montana
    2010 TRD
    Thanks for all the info I think that I will order the part from Toyota and install it myself. Sounds pretty easy. Just for reference do you guys know of any DIY threads on this board or others I might be able to link to. I have searched but can't find any its not imperative as I am sure I can figure it out but it would be nice for additional information
  18. Sep 17, 2010 at 5:52 PM
    Trap
    Indego Ink TRD OR
  19. Sep 17, 2010 at 5:55 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Owned Toyota trucks (pick-ups and Land Cruiser) since 1985.
    I live in Iowa and it'll get below -30.
    Always made sure I had a good battery.
    Always started, no matter how cold it was and they were always outside, never garaged.
    Both carb and FI.
    Never even considered a block heater.
  20. Sep 17, 2010 at 6:02 PM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    Here's the thread for the 4.0 block heater install. Make sure the truck is Cold!!! You'll scrape some skin if you have big hands like me! This heater is only 400 watts, and won't heat the block like those used on bigger V-8's, which are usually at least 1000 watts. A small oil pan heater might be a smart addition if you're in a really cold climate.
