Block Heater ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jcas, Sep 15, 2010.
  1. Sep 17, 2010 at 6:06 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Like I said before it's not like it will not start. It's are you willing to damage the engine when it does not need to be that way?
    Way easier to plug it in a half hour before you start it then have all the problems cold weather starting will cause. -30 is not too bad.
    It will cause problems. My buddy used to say I don't have to plug in my truck, it's got two batteries it will always start. Yup it started alright. That spring that engine was toast, it blew up, I laughed. To me it's just not worth it. If you are living in a really cold spot you need one. It's kind of pay now or pay more later idea. In this country there is only one spot where it is not mandatory from new to have one. Most cars & trucks here have them new off the lot.
  2. Sep 17, 2010 at 6:18 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've got the Toyota block heater (around $40 from the dealer) and it was a easy install. After seeing a couple pictures of the way the dealer ran the cord I decided to just do it myself. There's more than enough length to do a nice run back to the firewall, down the drivers side engine bay and out the front grill.
