Block to AAL
Discussion in 'Suspension' started by Thesilversurfer, Jul 31, 2011.
  1. Jul 31, 2011 at 9:24 AM
    Thesilversurfer
    Thesilversurfer [OP] Member
    Rich
    Calgary, Alberta, Canada
    2011 TRD Long Box
    Toytec ultimate lift kit UCA's Pro Comp Rims Dakar rear springs Centre bearing drop Bilstein 5100's BF Goodrich TA's Leer topper TRD Panel filter
    Hi guys
    I just had an ultimate lift kit put on my double cab long box and I love it. I had a block put in the back for the best ride.
    The other day I fitted a new topper to the truck and the back had dropped quite a bit. It's no longer level. I don't pull any heavy loads and I just want the truck to not be low at the rear. I don't mind if it's a little higher either. People are recommending me get a Dakar pack but that is a 2 1/2 inch lift, probably more than I need.
    The block is a standard 11/2 inch block. Do i get a 2 inch add a leaf to lift the rear and compensate for the topper and are they any good?
    What do you think?
    Richie. I will add a picture
  2. Jul 31, 2011 at 9:29 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    i would think that a 1.5" aal would do the trick.
  3. Aug 3, 2011 at 8:04 AM
    Thesilversurfer
    Rich
    2011 TRD Long Box
    Thanks for the replies.
    I had a look underneath last night can you believe that 1 month after fitting the block, the standard springs are flat and even softer. The block killed them.
    I'm ordering some OME Dakar spring packs for the rear and be done with it.
    My local Toyota Dealer can get them up to Canada for me.
    I think I will need a Diff Bearing drop and some longer brake lines though? what do you think anyone put them on before?
    Richie
  4. Aug 3, 2011 at 8:10 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    longer brake lines arent needed i dont think, but it shouldnt hurt.
    do you have the leaf TSB done?
  5. Aug 3, 2011 at 8:10 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Get the CB drop kit and the shims, they're cheap and that way you'll have them in the event you do need them. There is also a centering pin extension that's good to have if you need to add shims. These items are cheap to buy with the Dakars and you will most likely need to install one if not all of them anyways. Also, check out OZ-T's build, he put on Dakars and was able to use the stock brake lines. If you wheel hard you might need to replace them though.
  6. Aug 3, 2011 at 8:10 AM
    Pugga
    Massachusetts
    He's in Canada, they don't have the TSB up there. They come with the 4-leaf pack stock.
  7. Aug 3, 2011 at 8:21 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    OP , read this thread and get some centre pin collars for the Dakars , and install them when you put on your leaf pack . This will allow you to use axle shims later if you need them
    You don't need to get them from the online place shown in the thread , I got mine at a local spring and suspension shop .
    http://www.tacomaworld.com/forum/showthread.php?p=2839336
  8. Aug 3, 2011 at 8:23 AM
    Pugga
    Massachusetts
    Knew it was just a matter of time...
    Do have an alert that goes off when someone mentions "dakar"? :D
  9. Aug 3, 2011 at 8:28 AM
    OZ-T
    Peter North
    British Columbia
    I am all knowing
    I am all seeing
  10. Sep 24, 2011 at 10:36 AM
    Thesilversurfer
    Rich
    2011 TRD Long Box
    So finally I fitted the Dakar's on the rear of my Tacoma and it's fantastic. With the Toytec Ultimate lift kit the ride is better than ever and it looks awesome. Thanks for all the advice and help with this project. You guys rock.
    Richie
    I will put some pictures on later today.
