Block vs. Add a leaf
Discussion in 'Suspension' started by MikeyD, Nov 20, 2009.
  1. Nov 20, 2009 at 8:49 AM
    MikeyD
    MikeyD [OP] Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    okay so up front I have a temporary 3" lift but i want to lift the rear 2"s. Alot of people say blocks will kill your ride. But i dont understand. I would think it keeps the stock ride, depending on the shock you replace the stock shock with. And wouldn't a add a leaf make a stiffer ride since your adding another leaf? And my last question is what is a good shock to get 2"s of lift out of. I don't want a stiff ride.
  2. Nov 20, 2009 at 8:50 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Bilstein 5100 adj. for shock lift. And DO THE AAL, don't screw with blocks, they are not functional and cause more problems that they are worth.
  3. Nov 20, 2009 at 8:55 AM
    MikeyD
    Sayreville NJ
    But if i set the billys at 2"s aren't they going to be a little stiff?
  4. Nov 20, 2009 at 9:28 AM
    MikeyD
    Sayreville NJ
    And just curious but what problems are the blocks going to cause?
  5. Nov 20, 2009 at 9:30 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Axle wrap and wheel hop.
  6. Nov 20, 2009 at 9:34 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    the ADJ billies are for FRONT ONLY!!!! just thought I'd tell ya
  7. Nov 20, 2009 at 9:49 AM
    MikeyD
    Sayreville NJ
    And a add a leaf will not cause axle wrap and wheel hop?
  8. Nov 20, 2009 at 9:51 AM
    sibanez
    sibanez Well-Known Member
    Camp Hill, PA & New Orleans, LA
    2002 4x4 SR5 XCab
    Leer camper Thule rack
    No, it should generally help with axle wrap and wheel hop. I'm running an Alcan full pack right now, but my truck came with an AAL and it was a good ride.
  9. Nov 20, 2009 at 9:52 AM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    correct. AAL's actually reduce axle wrap from what I heard.
  10. Nov 20, 2009 at 9:55 AM
    c-slak
    c-slak Well-Known Member
    Chandler, AZ
    08 TRD Offroad 4x4
    5100's all around, 265/75/16 BFG ATKO's on MB Razor's, short shift, clutch mod, tsb springs, tsb aal
    I can attest to slight axle wrap from even a small 1" block in the back. In the sand especially! I am switching it out to the tsb aal as soon as possible! The rear 5100's should be able to handle a small 2" lift in the rear. I have about that between the block and the tsb and the shocks have been night and day from stock. I am not saying they are any longer than stock because that has been covered numerous times and I measured them myself. No real difference- maybe a half inch at most. I think it is just the better dampening that prevents the clunk I got with the stock bilsteins when they topped out.
  11. Nov 20, 2009 at 9:56 AM
    MikeyD
    Sayreville NJ
    okay so can someone suggest some good shocks for the rear. thanks
  12. Nov 20, 2009 at 9:58 AM
    MikeyD
    Sayreville NJ
    Ok so before i order can anyone confirm that the 5100s are long enough for the 2" of lift i will be adding.
  13. Nov 20, 2009 at 10:04 AM
    c-slak
    Chandler, AZ
    08 TRD Offroad 4x4
    Like I said, the 5100's are a good economical choice for the rear with a small lift. You can go with the OME rear shocks if you really feel you need the extended travel or the biltein 5125's. I have heard good things about both but again price was a concern for me. For my current needs the 5100s were a perfect choice and I have had a great experience with them. I know many others have run the 5100s in the rear with a similar lift and have had a great experience also. The dampening is far superior to stock and no harsh clunk when they have reached their full extension. Anything over 2" you should consider a longer rear shock.
  14. Nov 20, 2009 at 10:04 AM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    its long enough:)
  15. Nov 20, 2009 at 10:47 AM
    MikeyD
    Sayreville NJ
    5100's it is. Thanks guys
  16. Nov 20, 2009 at 1:08 PM
    Afwrestler1986
    Johnstown, NY
    I am aware of that man. I was saying 5100 for the lift in place of spacer. and AAL for rear.
  17. Nov 20, 2009 at 2:51 PM
    MikeyD
    Sayreville NJ
    Just picked up a pair of 5100s for the rear and a add a 2" add a leaf for the rear with only 5k on it for $135 including shipping. :) How did I do?
  18. Nov 20, 2009 at 2:53 PM
    Afwrestler1986
    Johnstown, NY
  19. Nov 20, 2009 at 3:05 PM
    SLOH
    SLOH Well-Known Member
    Scott
    Los Angeles
    07 SR5, dc long bed speedway blue
    2.5 Icon c/o's and 3" AllPro rear suspension kit, 17" XD Series Addict w/ 285/70/R17 BFG KM2's, K&N 63 Series CAI, 13.5'' JL Sub (13TW5v2-2) and 500w Rockford Fosgate amp, limo tint all around, cat back banks exhaust with no muffler or tip, blue dash light mod, "taco" 3rd brake light mod, blue dome-light mod, cb radio and 4' firestik antenna, blacked out hoodscoop(thanks randy), Total Chaos UCA's
    yeah, a lot of people say you'd get axle rap with a block but i've never experienced any axle wrap (yes i know what it is) and i have a 2" block...but yeah good job getting the AAL, i'm in the process now of getting rid of my rear block, i bottom out like crazy but thats cause i need TSB....so i just decided to get new rear suspension instead of the TSB and to get rid of the block
  20. Nov 20, 2009 at 5:52 PM
    c-slak
    Chandler, AZ
    08 TRD Offroad 4x4
    Sounds like you got a great deal. Congrats!
    Regarding the axle wrap; I don't get any on the street at all. Really the only time I do is when I'm in the sand or mud and I have little traction. It's probably not enough to break anything as long as you let off the gas in time. Then again I am very conscious and careful about it. Let's just say I've seen many 6" full size's break a lot of drivetrain components from trying to just floor it out of a situation. You could see the tires bouncing along right before a big BOOM:violent:
