Block vs no block. This is my question..
Discussion in 'New Members' started by NEKyota, Dec 21, 2020.
  1. Dec 26, 2020 at 8:11 PM
    Bad@Nicknames
    Bad@Nicknames Well-Known Member
    Bruce
    Greenville SC
    2008 TRD Sport AC
    Bilstein 5100's set at 1.75 Gunmetal Ray 10's
    Does the definition of axle wrap only apply to an experience that occurs from going from a complete stop to forward acceleration, or can it happen at speed induced by a bump? Just want to understand definitions before I continue to ask questions.
    Matmo215[QUOTED] likes this.
  2. Dec 26, 2020 at 8:12 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I only experienced it under acceleration from a dead stop
    Bad@Nicknames[QUOTED] likes this.
  3. Dec 26, 2020 at 8:22 PM
    Bad@Nicknames
    Bruce
    Greenville SC
    2008 TRD Sport AC
    Axle wrap
  4. Dec 26, 2020 at 8:36 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It can happen due to a bump upsetting the suspension (or even a gear change when the driveline and suspension become unloaded) but it's significantly more pronounced when accelerating hard from a dead stop.
  5. Dec 26, 2020 at 8:45 PM
    Bad@Nicknames
    Bruce
    Greenville SC
    2008 TRD Sport AC
    Thanks again for your input. You are informative. Definitely not axle wrap in my case, and definitely nothing that is overly concerning. It is a fun learning experience and I appreciate hearing opinions like yours.
  6. Dec 26, 2020 at 8:50 PM
    Key-Rei
    Key
    Florida
    Yeah man, you're good TW ia a great place to learn about stuff. A huge chunk of my own knowledge is from here. If you've only got a 1 inch block and it's working for you I would prioritize a leaf lift until your current set up is no longer meeting your needs.
    Now wants is a different thing altogether. Probably 60% of what I've done to my truck was a want to, not a need to.
  7. Dec 27, 2020 at 4:20 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    I plan on a 1.5" block. I'll do Bilstein 6112/5160. Note I don't tow or carry any additional weight
    Plenty of truck come with 1-4" blocks from the factory. A quick search shows, F-150 1.25" block, Dodge Ram 4x4 2-4" depending on the year.
