Blocks, add-a-leaf, or air shocks in rear?
Discussion in 'Suspension' started by Spikus, Jul 20, 2019.
  1. Jul 20, 2019 at 7:01 AM
    Spikus
    Spikus [OP] Active Member
    Scott
    09 Tacoma 4 cyl 5 spd 4x4 reg cab TRD Off Road pkg
    My new-to-me 2009 4wd TRD regular cab has 2 inch "leveling" spacers in the front, and is stock in the back. On anything but perfectly level ground, it looks like it has a slight droop in the rear, with absolutely nothing in the bed. I hate that look, and plan to use it as an actual truck. I could take out the spacers, but it looks like the new 265/70-17 tires would probably rub in the front if I did. So I'm thinking lift the rear 1 1/2 to 2", but what are the pros and cons of the three options?
    I had an old Hilux that had monroe air shocks in the back and the ride was fine and they never gave any problems ever, over years. I'm looking for the best option, but also cheap.
    Oh, and I WILL lightly wheel it at times.
    Thanks in advance.
    Scott
  2. Jul 20, 2019 at 7:04 AM
    PyroTaco
    PyroTaco Well-Known Member
    2013 Reg Cab Tacoma
    Fat Bob's lift kit, 30's on stock steelies, lunchbox locker in the rear, and a ton of other general mods and additions to help the utility of the truck for my particular uses.
    On my 13 reg cab I have the spacers in front, but put in an aal into the leaf pack. Have you done that? If so and it still sags like mine, I put in Roadmaster active suspension and it brought it right back up.
    -PyroTaco
  3. Jul 20, 2019 at 7:06 AM
    ForesterTRD
    ForesterTRD Trees are pretty neat
    Ethan
    Huntingdon Co. PA
    2010 DCSB Timb Mica TRD OR 4x4
    Front: Ome 887 on 5100s Camburg UCA ECGS Bushing Rear: Icon 1.5" AAL with overload Icon 2.0 rear shocks Wheel/Tire: Method Grid Titanium 16x8 4.5 BS 285/75r16 Duratracs Other: Cali Raised 20 degree sliders 13" antenna Front windows tinted to match rear Husky Floor Liners AVS bug shield and window visors
    Depends really on what you want to spend. But in your case, i think AAL is the way to go. You can pick up single AAL's for $120-$150. I did a Wheelers off road 1.5 inch single AAL, and i got right around 1.5 inches. It defiently firms the ride up, but it really isnt anything outrageous.
  4. Jul 20, 2019 at 7:06 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Blocks and AAL are not “shocks” so I’m confused by this. You don’t gain any lift on a leaf sprung suspension with the SHOCK. It is the leaf or the mounting of said leafs that lifts the truck. I’m just asking for clarification because changing shocks will do nothing to fix how the truck sits. If you need more lift do an AAL, blocks or optimally a whole new leaf pack. And then add some new shocks to finish off the setup IMO. Be sure they’re properly setup for the lift you’re using. Most shocks are generally short and people run them all the time with small rear lifts but you need to keep in mind the shock lengths
  5. Jul 20, 2019 at 7:09 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    Maybe you meant air bags? Air bags are typically only used when you’re adding a very significant amount of weight in the rear and need the option to level it when you have that weight back there.
  6. Jul 20, 2019 at 7:37 AM
    Spikus
    Scott
    Thanks Forester. I've never heard of Wheelers Offroad, but just checked out their site and the 2" AAL is damn reasonable at $77 for a pair! Wouldn't I need longer U bolts too though, and maybe even longer shocks? I thought the TRD package came with bilstein gas shocks (which I love) but they don't look like bilsteins. Mine are just plain black shocks.
    Singletrack. I'm not talking regular shocks, or air bags. There are such things as air shocks, which are shock absorbers that replace the factory shocks you can also raise with air to compensate for suspension sag with a load in the bed. I would run then pumped up just enough for them to sit where I want them.
  7. Jul 20, 2019 at 7:42 AM
    ForesterTRD
    Ethan
    Huntingdon Co. PA
    Hmm...factory bilsteins should be yellow. Did you look under the truck to look at the actaul shock body? Sorry for the stupid question, i just dont want to assume anything. You know how the saying goes :D. As for U-bolts, i would definetly get new hardware.
  8. Jul 20, 2019 at 7:44 AM
    PyroTaco
    2013 Reg Cab Tacoma
    I know what you are talking about with the air shocks. Personally I wouldn’t run them on my truck. Go with an aal, new leaf pack, or ras. The aal kit I got came with longer u bolts.
  9. Jul 20, 2019 at 7:48 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    it looks ass low because not many of these trucks have 2" of rake. it really more like 1" not to say that some may have 2" but that would be more on the less side
  10. Jul 20, 2019 at 9:22 AM
    Spikus
    Scott
    Yeah, I know. Yellow and blue. and yes, I crawled under and looked myself. Thinking I'll go with the 2" AAL, with longer u bolts. Would the factory shocks on there now be long enough to still work?
  11. Jul 20, 2019 at 9:26 AM
    Spikus
    Scott
    a 2" lift in the rear would be fine with me because I don't mind a little bit of rake on a pickup truck. It's there for a reason.
  12. Jul 20, 2019 at 9:28 AM
    Spikus
    Scott
    Any negatives with the AAL? I assume the ride will be a bit stiffer, which isn't a bad thing as far as I'm concerned. Someone told me the AAL would wear out the spring pack quicker, and also limit articulation off road some.
  13. Jul 20, 2019 at 9:33 AM
    ForesterTRD
    Ethan
    Huntingdon Co. PA
    Most likely not. Only other advice i would say is get in touch with Marie @HeadStrong Off-Road. She was a huge help when i was putting together my Old Man Emu lift. Very knowledgable people over there :thumbsup:
  14. Jul 20, 2019 at 9:35 AM
    ForesterTRD
    Ethan
    Huntingdon Co. PA
    Money is the factor here, obviously. If it were me? Ditch the 2 inch spacer and go with a kit like Bilstein 5100 and your 2 inch AAL.
  15. Jul 20, 2019 at 10:03 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    I am running that size tire with stock suspension on stock wheels with no rubbing. I thought the offroad models came with 16” wheels?
  16. Jul 20, 2019 at 10:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    Shop for a used 3rd gen front coilovers and rear shocks to replace yours.
    Budget friendly, refreshes your ride. Remove the spacer when swapping out.
    Lift doesn't contribute nearly as much to tire clearance as wheel fitment.
    Consider sending a PM to this guy. NOT posting in his thread, as he's likely on the cusp of being spanked for trying to sneak an ad in.
  17. Jul 20, 2019 at 10:07 AM
    Spikus
    Scott
    They may have. I assume this is not the tire and wheel setup that came on the truck originally, although they are factory Toyota wheels. It has 131K miles.
  18. Jul 20, 2019 at 10:41 AM
    Spikus
    Scott
    OK, now you guys got me curious. These are the 17" wheels on my truck. Are they OEM Toyota, and what are they off of? I assumed they were because they have TMC (toyota
    motor corporation I assumed) cast into them. Now I don't know ...
  19. Jul 20, 2019 at 11:18 AM
    L J
    Illinois
    ^^^that’s a stock Toyota Wheel but may not be what came on your truck new. Not sure but I think that’s a 4runner wheel. Lots of folks on here run 4runner, FJ and even some Tundra wheels in place of stock.
