Blocks and AAL
Discussion in 'Suspension' started by Twisted Vegas, May 2, 2013.
  1. May 2, 2013 at 12:19 PM
    Twisted Vegas
    Twisted Vegas [OP] Well-Known Member
    San Antonio
    08 PreRunner SR5 Double Cab V6 Sport
    car air freshener Front Grille Custom DVD/NAV Backup Camera
    Forum Gods
    History
    I have front 2.0 spacer with Brillstein 5100 @ .85. More then likely...going to remove the spacer and bring up the 5100 to 2.5.
    In the rear, I had a 1" block, but replaced with a 1.5-2.0 AAL
    The question I have is...."drum roll please" Has anyone installed a block and AAL together?
    Thanks for any responses
  2. May 2, 2013 at 12:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    A very good rule of thumb when dealing with suspension is do not stack lifts.
  3. May 5, 2013 at 9:02 AM
    DevL
    DevL Well-Known Member
    There is no problem adding the block and add a leaf. Its adding a block to a leaf spring with more leaves... which no different than any other leaf spring/block install.
