Blocks or Progressive AAL?
Discussion in 'Suspension' started by TRDtaco99, Nov 9, 2019.
  1. Nov 9, 2019 at 7:38 AM
    TRDtaco99
    TRDtaco99 [OP] Active Member
    1999 TRD tacoma 4WD 5spd
    Probably a stupid question, but I don't know if I should go with ICON 1.5" progressive leaf overloads or the toytec 1.5" blocks. I've heard mixed things about blocks and they are cheaper, so I'm wondering if quality blocks are worth it? Or should I spend the extra cash on the ICONs?
  2. Nov 9, 2019 at 7:41 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    There isn’t a quality block, really. It’s just a piece of metal, aluminum or cast iron. They’re pretty much the same outside of material.
    Do you tow or haul? A single leaf AAL is stronger than a 3 leaf, so if you use it as a truck I’d go with a single. If it’s a people hauler then a 3 leaf will ride softer unloaded.
  3. Nov 9, 2019 at 7:44 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    When people shy away from blocks, it isn't because of quality, but rather the way blocks affect the rear suspension. You are much better off, IMO, to install an add a leaf or a new spring pack.
  4. Nov 9, 2019 at 7:53 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you are doing this for style a 1.5 inch block on the rear is fine. If you are trying to compensate for sagging springs or heavy loads do the AAL. If sagging springs are a real issue get new springs.
    gotoman1969 likes this.
  5. Nov 9, 2019 at 12:34 PM
    TRDtaco99
    I'm doing this for a lift for style but mostly offroad. Would the blocks be okay if I got longer rear shocks?
  6. Nov 9, 2019 at 12:37 PM
    TRDtaco99
    I don't tow or haul, I'm going for offroad. I'm on a budget so I was just wondering if there was a huge difference in performance and ride quality between blocks or 3 leaf AAL
  7. Nov 9, 2019 at 12:54 PM
    T4RFTMFW
    I’d get a 3 leaf over a block
  8. Nov 9, 2019 at 1:01 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    How much would labor cost to do An AAL install? I don't want to missed up...
  9. Nov 9, 2019 at 1:14 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    New u bolts and an hour out of your life to install. I put an add a leaf in my truck that was60000 miles ago. No problems and I can put a level box of firewood in the back and ride is ok sits level,2 inch lift in the front. With blocks you get more axle wrap.
  10. Nov 9, 2019 at 1:17 PM
    rnish
    Tacoma 2nd gen
    If you are going to use the truck off road: go with the new springs or the AAL. The issue with blocks is they promote axel wrap, longer rear shocks will not solve the wrap issue.
