Blowby and Breather Oil Leak- 2.7L 452,000 miles- Catch Can Help?
Discussion in '4 Cylinder' started by usadaytrader, Apr 25, 2023.
  1. Apr 25, 2023 at 9:55 AM
    usadaytrader
    usadaytrader [OP] Well-Known Member
    2005 Reg Cab 2.7. Orig owner, engine and trans.
    So my engine runs fine, but its definitely got an oil leak. I suspect its from the greasy valve cover. I suspect the leak is from the breather tube. I dont care about blowby, just want to address the oil leak.
    Will an oil catch can help the leak?
  2. Apr 25, 2023 at 2:30 PM
    Stelcom66
    Stelcom66 Well-Known Member
    2007 2.7L 5MT 4WD
    Wow - 452,000 miles, that is amazing to say the least. Sorry I can't help with advice.
  3. Apr 25, 2023 at 2:42 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    No. If the breather tube (a rubber hose) is leaking, replace it. If you haven't replaced the PCV valve, do that before anything else. A gummed up PCV valve will cause pressure buildup in the engine and promote oil leaks.
    whatstcp and Tacorific like this.
