Blower and Resistor Replacement Mishap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jacyzayne, Feb 1, 2021.
  1. Feb 1, 2021 at 2:22 PM
    Jacyzayne
    Jacyzayne [OP] New Member
    JC
    Prerunner 4cylinder sr5 2005
    After replacing blower motor and resistor everything seemed fine for about five minutes, air blowing at all levels and then my 2005 Prerunner started loosing power and the smell of burning plastic came into the cabin. Clearly I screwed something up, but curious if anyone has leads on classic mistakes when replacing these parts? Or potential problems creating when replacing these parts? My splicing job looks decent, i didn’t cross wires, but something burned up bad after a bit of time with the truck running. Any ideas help, Thanks!
  2. Feb 1, 2021 at 2:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would recommend you get under and look for burned wires and connectors in the area of the resistor.
    Does the fan still run?
    TnShooter likes this.
  3. Feb 1, 2021 at 3:21 PM
    dbbd1
    dbbd1 Well-Known Member
    The truck started losing power? Or, the fan started losing power?
  4. Feb 1, 2021 at 9:21 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Check to see where the magic smoke has escaped from the electronics, that will tell you where you’re problem is.
    wilcam47 likes this.
