Blower Chirp TSB...Half Yay!/Half Sadface
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Richard Cranium, Dec 27, 2010.
  1. Jan 18, 2011 at 2:50 PM
    #41
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    Still haven't received my fan yet, kind of bummed that it's taking so long...:mad:
  2. Jan 18, 2011 at 2:59 PM
    #42
    0wrx2
    0wrx2 Well-Known Member
    north nj / upstate ny
    '10 trd sport 4x4. dbl cab. shrt bed.
    mine was ordered and at my dealer in less than a week :D
  3. Jan 22, 2011 at 2:27 PM
    #43
    Hipster
    Tom
    Tucson
    '10 DC trd 4x4
    Well, I installed the motor from Amazon and it still makes a flutter noise on low and medium:mad: Working on getting it replaced and in the meantime I'm going to try the "fix" on the factory one.
  4. Jan 22, 2011 at 3:21 PM
    #44
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Immediately after installing it?
    I wonder if everyone is talking about the same thing.
    Most of you guys have got to have phones or cameras capable of taking video. Why not post a Youtube upload of the noise yours is making. Mine is not making any noise, just stopping now and then.
  5. Jan 22, 2011 at 3:46 PM
    #45
    Hipster
    Tom
    Tucson
    '10 DC trd 4x4
    Yes, immediately. Bummer...
    The sounds are either a chirp or a flutter, depending on the post. For me, the OEM was a chirp. This replacement looks to be a problem with the fan balance. The stopping now and then is weird though.
  6. Jan 22, 2011 at 4:11 PM
    #46
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Mine has always made a very low rhythmic noise that I thought was either the motor or just a sound from the fan blades themselves at slow speeds.
    Mine has only not come on with the switch 3 times. Once with the A/C. I just rolled the window down. Next time I got in the truck it was fine.
    The next time, on the coldest day in January so far... on the way home from work, with no gloves. :mad: I could not do anything to get it working.
    After I got home I searched around and found these threads. I went out to the truck to try some things and it was working.
    Next morning I get in the truck to go to work and it's not running. I tap the bottom of the motor with my hand, and it starts right up and has been fine ever since.
    It's almost like the few times it's done this the brushes have parked in a bad spot over the commutator or something. :confused:
  7. Jan 22, 2011 at 8:52 PM
    #47
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    wait, so your new TYC blower is making a flutter noise?
    Now are you determining this noise but holding your head under the passenger leg area? Or from sitting at the driver seat?
    Right now, my OEM is chirping again after having it greased months back. I remember hearing the fluttering noise, if I held my head right in the passenger area. But while driving, I couldnt hear it at all. Until the chirps came back. The fluttering noise should be because of the fan blades. Cant fix that.
    Just placed an order for the TYC motor.
  8. Jan 23, 2011 at 3:52 AM
    #48
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    The fans regardless of brand and model have always made a fluttering noise. Keep in mind, the fan motor when running is floating a little inside the housing. Thats's where the 4 balancing screws come into play. If you think you're supposed to get complete silence from the fan itself it's not going to happen. These fan spin with a lot of RPM that the torque generated by the movement of the motor is going to cause the motor to move a little as as well.
  9. Jan 23, 2011 at 8:19 AM
    #49
    Hipster
    Tom
    Tucson
    '10 DC trd 4x4
    I can hear it from the driver's seat while driving. The radio has to be turned above 10 for me not to hear it. If you pull the cabin filter and watch the blower start, you can tell it's out of balance.
  10. Jan 23, 2011 at 8:21 AM
    #50
    Hipster
    Tom
    Tucson
    '10 DC trd 4x4
    I think the point we're all making is that when I bought the truck brand new, it didn't make the noise. It took two months for it to happen. Same with the factory replacement. I'm now on my third motor. It amazes me that with a $33K truck, they can't find a fix for a $40 blower assembly.
  11. Jan 23, 2011 at 10:35 AM
    #51
    steviestyles
    Colorado Springs
    Bone Stock
    I agree. this is the only vehicle that I have ever had a problem with the blower motor. none of my GM's, Ford's and Jeep have ever had this problem. Worst of all, it's not like that this blower motor desing is unique to the Tacoma. I've got my fingers crossed that the TYC fan will work for awhile.
  12. Jan 23, 2011 at 10:41 AM
    #52
    2010accesscab4x4
    2010accesscab4x4 Member
    West Chester, Pa
    2010 SR5
    Dealer told me it was just leaves when I took it to get looked at. They said they cleaned it all out and it was fine now. I barely made it a block down the street before it started chirping again and this time it was worse than before and happened on both the lowest 2 settings.
  13. Jan 23, 2011 at 5:37 PM
    #53
    Hipster
    Tom
    Tucson
    '10 DC trd 4x4
    The leaves thing is a piece of junk. If they removed the Cabin Filter then a leave could have fallen down from there during the process. This issue is very frustrating. Bring it back and have them fix it.
  14. Jan 25, 2011 at 7:44 AM
    #54
    threepeat
    threepeat Active Member
    Ed
    Albany, OR
    10 SR5 DC LB
    SnugTop Hi-Liner DynoLock Tailgate Lock Seatsavers for rear seat (dog!)
    Taking mine in this week to have them check the third fan. It lasted about a month so about 1000 miles!
    It will be interesting to see what they say.
  15. Jan 25, 2011 at 7:46 AM
    #55
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I'm waiting as well...bought my truck in late april 2010 and have already had this replaced twice! They are on a nation backorder because the fan is being re-designed, or so i am told
  16. Jan 25, 2011 at 7:46 AM
    #56
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Mine chirpped for about two days, then went back to normal. I love when my truck fixes itself :)
  17. Jan 25, 2011 at 7:46 AM
    #57
    ryanr623
    ryanr623 Well-Known Member
    Took mine in and the fan is still on backorder.
    Seems like they last a few months and start chirping again..... why wouldn't toyota fix the problem and not have to keep replacing these fans!?!?!
  18. Jan 26, 2011 at 2:56 PM
    #58
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Just had mine replaced last week with no wait time for the blower. So far so good I will just have to keep my fingers crossed.
  19. Jan 26, 2011 at 3:03 PM
    #59
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    is this the thing that sounds like a super charger when i accelerate at like 2-3 thousand RPMs? whatever it is its been pissing me off
  20. Jan 27, 2011 at 8:57 AM
    #60
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    I have resorted to putting the blower on level 3 and rolling my window a little not to overheat. Now it's starting to do it on level 3 and 4. Seems to me it would be a balance issue if it quiets as it spins faster. I will try the self fixes then ream my dealer a new one!
