Blower motor connector burnt!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarrosMoto, Nov 21, 2023.
  1. Oct 21, 2024 at 5:37 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You say ohms law still applies right. A loose terminal adds resistance to the circuit. IAW ohms law: as resistance increases current flow decreases.
    Di-electric grease is a insulator and doesn't the conductive abilities of the connector.
    But do it your way. It isn't worth arguing about it.
  2. Oct 21, 2024 at 5:41 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sometimes you can melt things by having loose connectors because they arc every time they lose contact under load. Makes a surprising amount of heat.
  3. Oct 21, 2024 at 6:33 PM
    Perfuseme
    Perfuseme Well-Known Member
    Rick
    im not arguing, you are. The wire is 1000% too small. The loose connection is 1000% speculation.
    yes, the grease is an insulator but I would also speculate and additionally use it to stabilizes any loose connector pins due to its consistency.
  4. Oct 22, 2024 at 5:32 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    The above issue was 100% caused by a poor connection between the spade and the socket part of the ground lead in the connector, poor connection causes an increase in resistance which causes heat in a location where it's not designed for the addl heat. wire size is not the issue with that failure, if it was it wouldn't have started in the connector. . Saying it's the wire size when the heat started in the connector and worked back is speculation and incorrect. Had the connector not failed I doubt there would have been an issue.
    2024OffRoad, Jimmyh and 0xDEADBEEF like this.
  5. Oct 22, 2024 at 2:14 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Someone doesn't understand Ohms Law or electricity.
    <<<----- Electronics technician for 47 years....
    2024OffRoad likes this.
