Blower motor connector fried (07 PreRunner)
Discussion in 'Technical Chat' started by dmanemann, Dec 30, 2011.
  1. Dec 30, 2011 at 4:55 PM
    dmanemann
    dmanemann [OP] New Member
    07 PreRunner
    Never had a problem with the blower motor or resistor (as others have noted in these forums) in my '07 PreRunner until today when smoke from under the glove-box and the strong smell of burning plastic forced me to pull off to the side of the road.
    When taking out the blower motor tonight I noticed that the female connector was fried on one side and contained one of the two electrical prongs that was formerly attached to the motor. I know where I can get a new blower motor but can't seem to find a part number for the connector. I'm assuming that I can splice a new connector into the harness.
    Can anyone tell me where I can find that part number, better yet a place where I can order it? Other suggestions for a fix?
  2. Dec 30, 2011 at 5:06 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  3. Dec 30, 2011 at 5:44 PM
    dmanemann
    07 PreRunner
    Thanks for the post, NelsonTacoma. I seen those connectors in my search but neither matched the connector I'm looking for. I've attached images of both blower and connector.
  4. Jun 11, 2013 at 1:05 PM
    stva1006
    stva1006 New Member
    I was wondering if you were ever able to locate the part number for the connector? Same thing happened to my '07 after 6 years being problem free!
  5. Aug 30, 2013 at 2:44 PM
    TSlagle
    TSlagle New Member
    dmanemann, Stva1006,
    Any luck finding the blower motor connector? Have a 2010, same problems as others. Connector fried.
  6. Aug 17, 2014 at 3:32 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    This same thing happened on my 2007 4-door 4X4 back in April of this year.
    My initial problem was the blower only working on the high setting. A new resistor late last year fixed that problem, but then the blower stopped blowing altogether. I worked the problem to the blower connector. The connector had melted and the plastic insulation on the wires at the connector had melted off about 2 inches. I had to cut the blower wires in order to remove the blower and take it to my bench. I was able to cut off enough material to remove the connector. Lucky for me the two tabs in the blower were intact and the connector, although partly melted and burnt, appeared functional. I notice the connector moved in/out too easy when inserting into the blower connector; this loose connection may have caused the overheating. I cleaned the tabs and used a pick to press the female tabs in the connector for a tighter fit.
    I looked for a new connector but I did not find one. I did order some tabs to be on standby in case the connector melts again on me in the future. The tabs are .187 12-10 gauge female disconnects. I "dry-fitted" them and they could get the job done if needed. You only have to glue a spacer to keep the disconnects from making contact with each other. So far, my fix is holding up. All my blower speeds work again, but the wires down there still heat up a bit. I'm still looking for a new connector.
    So guys, with the blower on high for a couple of minutes, touch those two wires at the connector and see if they are not too hot. If they are, you may want to remove the connector and crimp the female tabs a little tighter to provide a more secure connection.
  7. Jan 1, 2015 at 9:47 AM
    lelio98
    lelio98 New Member
    Shane
    California
    Were you ever able to locate the correct connector? Mine has completely melted away!
  8. Jan 11, 2015 at 4:38 PM
    TSlagle
    TSlagle New Member
    Lelio98,
    Yes, I was able to repair. I wound up at the local Toyota dealership. I could not locate a new or used anywhere....The parts guy was great, he looked in the back and found a connector that was not fried. I did purchase a new resistor. From what I researched...The factory resistor was bad, that caused the connector to fry.
  9. Feb 16, 2016 at 7:57 AM
    ajb1371
    ajb1371 Member
    2010 Black DCLB 4x4
    Here's my situation...
    I have a short in mine somewhere... The zip tie was pulling the cord, allowing the heater to work. Any ideas or I am stuck with going to the dealership??
  10. Apr 30, 2017 at 2:35 PM
    cookswv
    cookswv New Member
    Has anyone found this connector? Same one I need and can't find
  11. May 17, 2017 at 11:45 AM
    Johnkr
    Johnkr New Member
    2010 Tacoma
    My son has a 2010 Tacoma and the blower motor connector was burned, this is the connector on the fan a two wire connector, not the one that connects to the little resistor board!
    The dealer said you need to buy the whole harness, but you can buy the connector separate and the two wires each separate with the female pins already crimped.
    Housing Connector 90980-10916
    Wire with terminals 82998-12380 need two !
  12. Jul 10, 2018 at 9:11 PM
    WiredPig
    WiredPig Member
    Glenn
    Forest Grove, OR
    2006 Tacoma PreRunner DCLB
    USB Outlets In Cab.
    Thanks for the thread. I just ran into this on my '06 PreRunner. I pulled the connector and looked at it, sure thing, its burnt. Time to get a new blower motor, connector and terminals.
  13. Jul 11, 2018 at 2:58 PM
    stefanlg55
    stefanlg55 Toyota Master Technician
    2008 Tacoma TRD OffRoad
    Yep these are the correct part numbers!!
  14. Jul 20, 2018 at 1:10 PM
    WiredPig
    WiredPig Member
    Glenn
    Forest Grove, OR
    USB Outlets In Cab.
    Anyone know what the motor's amp rating is? I'm going to put in an inline fuse.
  15. Aug 21, 2018 at 8:08 PM
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    Different aftermaket suppliers will have different amp ratings. Check their websites. But this issue is usually because the blower motor gets worn and generates too much heat from the excessive draw. This circuit does have an adequate fuse. The issue is that the start up amperage is higher than the running amperage. So if you put a low amp fuse rated at the running amperage it will blow everytime you turn the fan on. Especially if your like me and tend to go from off to max speed.
  16. Aug 22, 2018 at 3:06 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    So for those of us who haven’t had this issue (yet), do you think it’s best to go ahead and replace the motor before this happens?
  17. Aug 22, 2018 at 8:41 AM
    ColoTacoPrerunner06
    Just replace it when it starts to make noise before it gets too loud
  18. Jun 3, 2023 at 10:43 AM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Resurrecting an oooollllld thread.
    Both of these items look like they have the plug, with wires attached. What am I missing?
    I noticed mine is starting to get a little burnt, so I want to order the parts to get ahead of it.
