Blower Motor Group Buy Price Survey
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DaVikes, Jan 10, 2014.
Blower Motor Price Survey - Please Select Highest You Would Pay
Poll closed Feb 9, 2014.
  1. $99
    1 vote(s)
    5.9%
  2. $89
    3 vote(s)
    17.6%
  3. $79
    7 vote(s)
    41.2%
  4. $69
    6 vote(s)
    35.3%
  1. Jan 10, 2014 at 9:00 AM
    DaVikes
    DaVikes [OP] Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    Just to be very clear, there IS NO GROUP BUY IN PLACE. This is just a survey that I hope will persuade Camelback Toyota to offer a group buy.
    Jorge, the parts person at Camelback, has offered the blower motor at $105.43. To be fair that is actually the lowest price I have seen anywhere. I am hoping that if this survey demonstrates enough group buy demand at a somewhat lower price, that we could get a lower price. I've asked Jorge about that, but I haven't heard back yet. (I am sure that Jorge will have to get Mr. Camelback's permission to do a group buy, so please don't bust on Jorge if Mr. Camelback doesn't like the idea.)
    If you read this before filling out the survey, please indicate the highest price for which you would definitely buy a blower motor. Realistically, they aren't going to sell it for $50 or $60. But maybe they would come down to $79, $89, or $99. I just figure that it doesn't hurt to ask, and if they could see demand for 20 or 30, maybe they would do it.
    In case you are wondering why I am trying to get a lower price when Cameback is already offering the lowest price, I'll offer an explanation. Toyota buys 100,000 to 150,000 of these fans per year. I used to work for a couple of different manufacturers, one being Onan Corp, which makes engines and generators. So I have a decent idea of manufacturing costs. I would bet that Toyota pays between $10 and $15 for each blower motor/fan. If the part had a "normal" failure rate, I wouldn't bother with this. But the fan seems to have an abnormally high failure rate. When a has a high failure rate, I think that Toyota, to provide good service to it's customers, should provide a lower price and take a less than normal profit margin. They could do this and still make plenty of money on the part.
    (If you are new to this issue, the '05-'11 Tacoma's used a fan motor with bushings that are prone to making noise. The newer fan used in '12 and up uses bearings, which should be much better. I don't believe any of the aftermarket fans use bearings, so I don't see the point in putting one of those in only to have the problem again.)
  2. Jan 10, 2014 at 9:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I wouldn't pay a penny. The chirp issue is not with the motor itself, you need to take 5 minutes and adjust the set screws so the fan is 'balanced' in the housing. After that, the noise goes away and the fan still operates as it should.
  3. Jan 10, 2014 at 9:23 AM
    DaVikes
    Ross
    Denver
    Colorado Sports Car
    Pugga, I respectfully disagree. The balancing trick works for some, but not all. For many, the issue is that the bushings are not up to the task. Toyota has in fact replaced the old motor with a newer one that uses bearings, which indicates that their engineers believe the bushings were the problem.
  4. Jan 10, 2014 at 9:53 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
  5. Jan 10, 2014 at 9:55 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    You can get these on Ebay for about $50....never heard of the balancing thing, my fan vibrates at the highest setting, gonna have to check into the 'set screw' thing...
  6. Jan 10, 2014 at 10:17 AM
    DaVikes
    Ross
    Denver
    Colorado Sports Car
    Hello dillagaff82, I looked at the one you linked to, but they don't say if the motor uses bearings or bushings. There are a bunch on Amazon at similar prices, but they don't get very good reviews. I only want to fix the thing once, so I'm holding out for either the OEM part, or an aftermarket part that uses bearings.
  7. Jan 10, 2014 at 12:54 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I read the title quick and thought blower, as in supercharger and I was all :D . Now I understand that it was the actual fan motor and now I'm all :(
  8. Jan 10, 2014 at 12:57 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    Here is a shocker. How about Toyota fix their POS fans they had for however many years and replace them for free.
    Forgot, that gets into their bottom line profit and would have bad PR attached to it for an identified problem.
  9. Jan 10, 2014 at 2:08 PM
    DaVikes
    Ross
    Denver
    Colorado Sports Car
    Yeah, that would be nice, but I don't think they will. Sad thing is the manufacturing cost difference between the old fan and the new one is probably no more than a buck or two. So to save a couple bucks, they caused a problem for a lot of people. Same thing with the front diff needle bearing, same thing with the rear driveshaft, on and on.
