Blower Motor (Heat & A/C) Stopped Working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by K Williams, Dec 3, 2022.
  1. Dec 3, 2022 at 11:15 AM
    K Williams
    K Williams [OP] Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    The blower motor for my heat/air/air-conditioning stopped working. Is this an easy fix? Part numbers? Thanks.
  2. Dec 3, 2022 at 12:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. Dec 4, 2022 at 11:33 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It’s either/or the resistor 4-pin connector (to the left of the blower as you face it), or the two-pin connector at the blower. When you look at the connectors one of the pins will look burnt. Pull it apart if you can to gently sand the pin. Use dielectric grease when reattaching the connectors. This has worked for me. Others have had melted connectors and spliced in new connectors. It is rare for the blower and resistor to need replacing, but it can happen.
    edit: you may find it easier to remove said components to access the connectors. Both take a 5.5 mm socket to remove the bolts, two on the resistor, and, I think, three on the blower (could be four, I forget).
    K Williams[OP] and wilcam47 like this.
  4. Dec 6, 2022 at 7:05 AM
    K Williams
    Long Island, NY
    Thanks for the info. It started working again by itself yesterday, after over a month of no air, so it has to be a wiring or connection issue.
    TnShooter likes this.
  5. Dec 6, 2022 at 11:05 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The blower and resistor are easy to get to. No tools required. I’d disconnect the plugs and check them. Melted connections are common.
  6. Dec 6, 2022 at 11:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    Fix it before it burns up.
  7. Dec 6, 2022 at 11:07 AM
    Chuy
    Lakeside, CA
    Silver Taco
    I would at least remove the connectors and apply some dielectric grease to prevent corrosion. It will not fix itself permanently.
    K Williams[OP] likes this.
  8. Dec 9, 2022 at 11:23 AM
    K Williams
    Long Island, NY
