Blower motor or fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DawgLink, Sep 16, 2022.
  1. Sep 16, 2022 at 1:38 PM
    DawgLink
    DawgLink [OP] Member
    Jay
    2009 Tacoma 4WD SR5 double cab
    The blower for the fan on my 2009 Tacoma started acting strange the other day. It actually didn’t come on when I turned on the AC. Shut it off and back on and it worked. 2 days later same thing. Is this the blower motor or some type of electrical supply issue? Anyone else had this happen?
  2. Sep 16, 2022 at 2:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Search. This is a common issue and usually caused by a loose connection at the Blower motor resistor or on the motor connection itself. Check both connectors to see if they are burned.
    Dm93 likes this.
  3. Sep 16, 2022 at 2:11 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Blower resistor connector under passenger side dash.
    Motor connector
    parsonsjr, TnShooter and BassAckwards like this.
  4. Sep 16, 2022 at 2:17 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    As described above, a LOT of people think the resistor itself is broken but in reality, you just need to clean the pin (it will be obvious which one) and then bend it in such a way that it makes more rigid contact with the other connector. You do that and you're likely good to go.
    BassAckwards likes this.
