Blower motor problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Nov 5, 2022.
  1. Nov 5, 2022 at 3:40 PM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Hey guys,
    My blower motor stopped working a few days ago. I replaced it and now the new one only works on high. It does work at all low or medium. Anyone know what the problem is? Thanks!
  2. Nov 5, 2022 at 4:11 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Yes, it's the resistor, or the plug to it.
    In every normal resistor setup I'm aware of (not counting fancy newer electronically controlled systems) the fan switch on high bypasses the resistor, and feeds full voltage to the blower. So even if the resistor completely fails, you still get the high setting.
    Geeves77 and 2009Access4x4[OP] like this.
  3. Nov 6, 2022 at 3:40 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Pull the resistor connector and look at the four pins. One may look burnt. If so, it can be removed from the connector; use fine sandpaper to clean the terminal and put dielectric grease on the terminals when reconnecting the connector. Do same to the blower connector.
