Blower motor question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ARB1977, May 18, 2013.
  1. May 18, 2013 at 12:32 PM
    ARB1977
    ARB1977 [OP] It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I'm having an intermittent, I'm talking twice a year with the blower motor not blowing any air. Mainly when I'm using the ac. If I let sit it will come back on. It happened today and now it's working again. I took the blower motor out and it seems to be working fine. Can these blower resistors go out and then work again?
    This happens on every speed selection. We're is the HTR fuse located? Tring to make sure that a connection isn't loose or something.
    Thanks
  2. May 18, 2013 at 2:01 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Could be the switch in the dash or the blower resistors are bad but not likely..
    Check the connection at the blower mine had melted made a mess out of it..
  3. May 18, 2013 at 2:13 PM
    ARB1977
    North Texas
    I did check the blower motor and every thing looks brand new and the connection looks fine.
  4. May 18, 2013 at 6:21 PM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    Ok what about the switch in the dash?
  5. May 19, 2013 at 12:17 AM
    ARB1977
    North Texas
    Haven't checked that. How do you pull it apart?
  6. May 19, 2013 at 8:10 AM
    hayabusa3303
    florence sc
    95.5 taco 4x4
    Look for a write up on changing the radio to make sure.
    BUt pull the knobs off.. Lift the panel where the knobs are which will expose two screws. remove those.. Remove the trim piece by pulling top to bottom slowly.. remove the wire to the flasher switch.. After all that is out of the way.. There are two more screws holding the dash peice where the switch is at on. remove those two screws.. Remove the switch to test it... With that as a pot switch if my memory is correct..
    I have a 95 but they should be same for taking dash apart minus i have older style controls where you have the turn knobs ones..
    If your going that far i would just replace the switch they really dont cost that much and keeps you from go back in there when it does fail.
  7. May 19, 2013 at 4:25 PM
    jdintexas
    jdintexas Member
    JD
    Texas
    2007 Prerunner V6
    none yet
    I seem to have the same issue...( just posted )
    I haven't started looking under the hood, yet but my switch seems to work until the fan stops functioning.
    I have seen post about relay problems on 2005 but not 2001...
    My first thought was fuse but it started working again....
  8. May 20, 2013 at 7:13 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    If you wanna get the panel all the way off I think you gotta take the very bottom of the center console off first (the part in front of the shifter with the outlets in it) and pull the ash tray before the whole thing will come out. Also you'll have to disconnect the airbag switch (If you have one?) THEN it should come all the way out.
  9. May 27, 2014 at 8:23 PM
    1997tacomav6
    Denver
    Ok so I have the same problem, I have nailed it down to the connector that goes into the back of the fan control switch, the fan works on 3 setting and then sometimes one one setting, so I need a new wiring harness connector that goes into the back of the fan switch.
    Where can I get a new one from? Toyota does not sell just the male wire connector that goes into the switch, you have to buy the whole wire harness, anyone know where this part can be bought, 1997 tacoma
