Blower Motor quit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kglinz, Jun 1, 2014.
  1. Jun 1, 2014 at 8:13 AM
    kglinz
    kglinz [OP] Member
    Idaho
    2008 Tacoma Reg cab... My air condition/heater blower only runs on high. I was driving down the road on a lower setting a it just quit. Any ideas.
    Thanks
  2. Jun 1, 2014 at 8:23 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    If it's not corroded connections then try swapping with a known/good blower.
    I dunno how hard it is to replace blower...
    ...it could be dirty and not able to push the fan on lower speeds....
    ...just grabbing at straws here.
  3. Jun 1, 2014 at 8:25 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Just leave it on high
  4. Jun 1, 2014 at 8:27 AM
    52motorhead
    52motorhead Well-Known Member
    Sounds like the resister block for the blower motor went not the blower motor itself since it still works on high speed.
  5. Jun 1, 2014 at 3:39 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    resistor is the correct answer here for sure
  6. Jun 1, 2014 at 3:52 PM
    anotherreject
    anotherreject Well-Known Member
    +1, mine did the same thing, theres a thread on here that shows how toreplace it
  7. Jun 2, 2014 at 4:44 AM
    kglinz
    kglinz [OP] Member
    Idaho
    Thanks, Guys
  8. Jun 2, 2014 at 9:28 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It's not always the resistor that is the problem. Sometimes, it's just a symptom of another problem.
    If the blower is near the end of its life, or the filter is severely clogged, it draws more current. Check the connector for the resistor. If it's discolored/melted, replace the blower, and the filter.
  9. Jun 2, 2014 at 3:29 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Not necessarily......
    When the resistor block fails, granted you can have HIGH only. In my case as well as many others, the connector on the resistor block was the problem.
    When you run a lot of current through a connector as you do with a fan motor, the connector can heat up if it is lose, that heat causes the connector pins to become even more loose and eventually melt the plastic. Here is my suggestion....
    (1) Put you fan on something lower than HIGH and wiggle the connector on the resistor. If it intermittently starts, remove the connector and examine. A common problem is a loose pin in that connector, this will be evident by a tell tale brown heat streak on the gray connector.
    (2) if you have the gray streak, bend the pin in the connector with a dental tool or jewelers screw drive to make a better connection. This will fix the problem if this is the issue.
    (3) if wiggling the connector or bending the pin doesn't fix it, replace the resistor.
    In my experience, the resistor and connector are an equal percentage in the cause.
    Start reading this at posting #9: http://www.toyotanation.com/forum/6...3-hvac-blower-motor-resistor-replacement.html post #14 shows pictures of the issue.
  10. Jun 3, 2014 at 9:46 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Where can I find a replacement connector. Mine is toast.
  11. Jun 3, 2014 at 11:48 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  12. Jun 4, 2014 at 10:11 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
  13. Aug 26, 2020 at 10:41 PM
    CHK
    CHK Member
    Seattle, Washington
    2013 Silver Tacoma 4-Door 4x4
    None
    Interesting thread. But the TSP only covers 2005- 2011. I just had the resistors go out on my 2013 Tacoma. Needless to say, I'm not happy. Based on this thread, I started checking and I have all the indications of the TSP- burnt connector, etc. I did call the dealer and they offered to install a new resistor and connector for free if I paid for the parts. But, they insist that the blower drawing too much amperage is not the problem. Has anyone else run into this with 2nd gen Tacomas 2012 and older? Have you gotten the dealer to step up?
  14. Aug 27, 2020 at 8:04 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    They can insist all they want. When I replaced the connector and resistor, it burned up again. Then replaced the resistor, connector, and blower. Trouble-free ever since
    davidstacoma likes this.
  15. Aug 27, 2020 at 9:48 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I’ve soldered a 12 awg solid copper coil to the nichrome resistor strip on the pin that is overheating to act as an extra heat sink. The problem is that the “resistors” are too close to the connection and are under rated for wattage so either the resistor fries or the connector does. I’m hoping that adding both more heat sink mass as well as cooling surface area will do the trick in lowering the temp of the connector pin.
  16. Aug 28, 2020 at 2:49 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And a TSB is only free during the initial warranty period.
  17. Aug 28, 2020 at 5:51 PM
    CHK
    CHK Member
    Seattle, Washington
    None
    That's what worries me. I'm expecting Toyota will do the "repair" and within a year or 2 it will happen again. Skytower, how long have you been trouble free?
    At this point, I'm willing to give them the benefit of the doubt, but if it happens again I will not be happy. It's very obviously a Toyota engineering design flaw. I bought this 2nd gen based on my son's failure free experience with his 1st gen.
    Thank you guys for the input.
  18. Aug 28, 2020 at 7:24 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Actually it is a GM Engineering Design Flaw.
    CurtB likes this.
  19. Aug 28, 2020 at 8:09 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    And a cheap and easy flaw to fix.
  20. Aug 29, 2020 at 6:27 PM
    CHK
    CHK Member
    Seattle, Washington
    None
    Interestingly, I went with the Toyota fix to the resistor. I pulled it out after they replaced it and the resistor is completely redesigned. I'm no electronics expert but it looks to me like they simplified the resistor and added what looks like a large metal plate that could be a heat sink. Bagleboy's idea to add a heat sink might be the way to go. I'll be watching to see how long this Toyota fix lasts.
