Blower Motor replacement woes
Discussion in 'Technical Chat' started by Boog45, Jun 24, 2019.
  1. Jun 24, 2019 at 5:28 PM
    Boog45
    Boog45 [OP] New Member
    2008 Tacoma Prerunner
    The blower motor in my 2008 Tacoma stopped running. After consuming as much information and videos as I could, I did the typical: verified fuse, replaced blower motor (connector was burned), replaced blower motor resistor and connector (one lead was burned). I even replaced magnetic clutch relay (although this was probably not necessary). After all of this, it still won't run. I hot-wired fan directly to battery, so I know it works. When I probe yellow power wire on fan dial connector, it reads 12.3V - so I know I'm getting power to that point. I tried jumpering the yellow wire to the white/royal wire which seems to be the 'high' speed connection which should bypass the resistor, but the voltage dropped to 0.170V. I experimented with disconnecting the resistor in this state and heard a buzzing/humming sound coming from the engine fuse box (?). I checked the resistance on the resistor with a meter and got varying ohms: 2.5, 1.25, 0.4 - so I assume it is okay. I even pulled apart the dial mechanism to inspect the copper traces. The black (ground) wire that comes out of the blower motor connector goes back through a different harness behind the dashboard, so I 'assume' the grounding is okay. I'm at a loss on what to do next, but I didn't want to give up just yet and take it to the repair shop. Any good ideas out there?
  2. Jun 25, 2019 at 4:42 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    What kind of blower motor did you buy? Wouldnt surprise me at all if a cheap parts store unit didnt work out of the box.
  3. Jun 25, 2019 at 5:18 AM
    Boog45
