Blower motor resister
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toywoodsguy82, Nov 7, 2019.
  1. Nov 7, 2019 at 6:20 AM
    Toywoodsguy82
    Toywoodsguy82 [OP] Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    So I thought I had this problem figured out (and I still might) but my understanding is if your air only runs on high then it’s your blower Moyer resister.
    Well all of a sudden two days ago it randomly turns on and off on lower speeds.
    Should I still plan on the blower motor resister or look at something different??
  2. Nov 7, 2019 at 6:49 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    Hi is the default, the lower speeds are where it is burnt, they "may" work from time to time. Resister is would still be my first step.
    cleats50 and Marc70 like this.
  3. Nov 7, 2019 at 7:21 AM
    bordinco90
    bordinco90 Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    The same thing happened to me. It was my resistor. Once replaced the a/c worked on all speeds.
    cleats50 likes this.
  4. Nov 7, 2019 at 7:21 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    I've got this problem too. I just went out tapped the bottom, and all of a sudden the lower speeds worked, again.
  5. Nov 7, 2019 at 7:24 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    When you change your resistor also check the condition of the connector. Most likely it will be fine, but on some vehicles it can get fried.
    LAMCKMA007 and Marc70 like this.
  6. Nov 7, 2019 at 8:01 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    I went through the same thing for close to a year. It would sporadically work. It will eventually get worse and not work. I just replaced it with oem parts, which are now completely different and updated from the originals. hopefully toyota solved the issue.
  7. Nov 7, 2019 at 9:37 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    It sure is easy enough to check. Unplug it and look at it.
  8. Nov 11, 2019 at 6:32 PM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    Hey guys I can't find a thread on it but my Fan only works on the 3 low speeds but nothing on high??? Suggestions?
  9. Nov 11, 2019 at 7:27 PM
    Muddinfun
    Muddinfun Well-Known Member
    Most likely the fan switch. Unplug the connector and see if it's burnt.
    LAMCKMA007 and cytocycle[QUOTED] like this.
  10. Nov 12, 2019 at 12:50 AM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    The newer updated resistor was $5 cheaper than the previous version. I bought mine on Amazon and the one I ordered came with the new plug. $20.
  11. Nov 12, 2019 at 4:05 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    I had the same issue, so I bought a new resistor after reading through some threads but it did nothing. Mine ended up being the blower itself, so now I've got a resistor when when it actually goes bad.
    https://www.amazon.com/dp/B012EKYCT...colid=GY07FUPJTWVX&psc=1&ref_=lv_ov_lig_dp_it
