Blower Motor Resistor Replacement 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjpwaverka, Jun 24, 2020.
  1. Jun 24, 2020 at 12:39 PM
    jjpwaverka
    jjpwaverka [OP] New Member
    Does anyone know where I can purchase a blower motor resistor for my 2005 tacoma 2wd prerunner? The dealership shows an upgrade to the part from a inline configuration to a square setup, my truck has the inline version and converting to a square plug looks like I need to do some electrical work and that is not my gig. Thanks
  2. Jun 24, 2020 at 12:52 PM
    BeardeDave
    BeardeDave Member
    Dave
    Colorado Springs, CO
    08 Access Cab TRD-OR
    Nothing fun yet...
    Pretty sure any auto parts store will have what you're looking for. A quick search on Autozone's website has it for $40.
  3. Jun 24, 2020 at 1:04 PM
    jjpwaverka
    thanks! that will work!!
  4. Jun 24, 2020 at 1:05 PM
    Muddinfun
    Muddinfun Well-Known Member
    The resistor is only 1/2 the problem. The connector is the other half. You need to replace the connector for a complete repair.
    knayrb and NAAC3TACO like this.
  5. Jun 24, 2020 at 1:35 PM
    Muddinfun
  6. Jun 24, 2020 at 1:38 PM
    BeardeDave
    BeardeDave Member
    Dave
    Nothing fun yet...
    Is there a known issue with the connectors for these resistors failing as well? I had an old Dakota that had the resistor fail in it, and I swapped in a new one and it was good to go. Haven't had that issue with the Tacoma yet though.
  7. Jun 24, 2020 at 1:46 PM
    Muddinfun
    Yes. The resistor itself doesn't actually fail. It's the connection between the resistor and the connector terminal that cooks.
    Jimmyh likes this.
  8. Jun 24, 2020 at 1:47 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  9. Jun 24, 2020 at 2:04 PM
    BeardeDave
    BeardeDave Member
    Dave
    Nothing fun yet...
    Ah, I hadn't heard that before, so that's good info to share. I was confused when you just said "replace the connector too" because I haven't had to do that before. Thanks! :thumbsup:
    Muddinfun[QUOTED] likes this.
  10. Sep 23, 2020 at 6:12 PM
    DirtyArmor
    DirtyArmor Active Member
    Paul
    2008 Silver/Black Tacoma 4x4
    Blistein 5100's, 1" add a leaf, frontline grille guard, 265/75r16 coopers, herculined grille/bumpers/fenderflares. TACO truck ;)
    Yes but the reason the connection goes bad is typically because of the increase in resistance that happens as the resistor rusts.
  11. Sep 23, 2020 at 7:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Whuuut?
    Resistors don't rust.
    CurtB and Muddinfun like this.
  12. Sep 23, 2020 at 7:58 PM
    Muddinfun
    Jimmyh likes this.
