Blower motor sometimes needs a smack to get started
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Jul 11, 2018.
  1. Jul 11, 2018 at 6:27 AM
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    So I went through all the nonsense of replacing the resistor plug and cable previously. This fixed the issue I had where it would only work on high most of the time.
    it's been a few months but now I'm having a different problem where it won't work on any speed, if I reach down and give it a hard smack it will start right up and then work perfectly until I turn it off for a while.
    I had already previously taken it out to see if it could be oiled, but this one looks a lot different than all the pictures I've seen on here and I don't see any way to take it apart, much less oil it
    When it does run, it does not squeak or chirp, but it does have a dull sounding "da da da da da da da" as it spins. It's very quiet and not very noticeable.
    I read that part 87103-04044 is like a revision that is supposedly better. Is this true?
    Should I go ahead and replace it?
  2. Jul 11, 2018 at 6:59 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes replace it. The brushes in the motor are only making intermittent contact. Hitting it with your hand shakes the brushes and makes them have better contact
  3. Jul 11, 2018 at 7:20 AM
    jross20
    Georgia
    Well darn, I guess I would have had to at some point.
    So what is your opinion on the different revisions?
  4. Jul 11, 2018 at 9:35 AM
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    When my resistor went bad I could usually smack the blower motor and get the fan to work on all four speeds. I know you said you replaced the resistor already but it’s possible you got a defective one.
    Also, FWIW, I replaced the original motor in my 2009 with the newest OEM revision to eliminate squeaks and squeals a while ago. It’s been working great.
  5. Jul 11, 2018 at 11:24 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you can afford it, go OEM
    The blower is pretty easy to access though, so if you want to try a cheaper option and see how it goes it's not like it takes a bunch of time to pull it back out
