Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Feb 9, 2011 at 3:01 PM
    #201
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    diy on how to get to the blower motor? yes mine sounds like a retarded canary
  2. Feb 9, 2011 at 3:06 PM
    #202
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    I took mine out and took it apart and greased the two bearings. It has been about a month and still no squeak!
  3. Feb 9, 2011 at 4:05 PM
    #203
    west467
    west467 Well-Known Member
    Two Black Tacos..03 and 09
    Look at the top of this thread:
    Tools needed:
    5.5 MM socket, phillips screwdriver, grease, and a tie down strap.
    Stand on your head, remove 3ea. 5.5 MM srews. (passenger side)
    Remove wiring connections, remove motor fan assy.
    I used the tie down strap, with motor on the floor, using my feet to hold the fan housing, placing the tie down strap under the fan, pulled up, and the fan came free of the motor shaft. Removed the plastic motor housing with 3 or 4 screws, removed 2 screws holding the bottom of the motor together. Removed the armature carefully keeping the contact springs in place. Clean, grease bushings.. put it back together.. NO..chirps!
    I hope this helps, if you are good with a wrench you will not have any problems.
  4. Feb 9, 2011 at 10:39 PM
    #204
    lowzone
    lowzone Well-Known Member
    Ron
    Earth aka NJ
    2010 MGM AC 2.7L 5 spd SR5
    future plan of 2" drop and any type of rim thats not a steelie. grille and BHLM mods, maybe....
    HAHAHAHAHAHAHAHAA, i needed that :D
  5. Feb 11, 2011 at 12:19 PM
    #205
    jjbeenken
    jjbeenken Well-Known Member
    Arkansas
    2022 DC TRD Sport(always under construction)
    Hertz - Arc Audio - Precision Power - Image Dynamics - Helix -AP UCA's - Dakar Springs - Icon Vehicle Dynamics
    I have a 3 hour trip tomorrow. I gotta get this done tonight... driving me crazy! 2010 truck has 17,000 miles on it and it sounds like crap!!!!!!!!!!!
  6. Feb 11, 2011 at 12:22 PM
    #206
    jjbeenken
    Arkansas
    I'm gonna do this one time then I'm gettin a new fan if it comes back. I think if goes too long you'll wear the bushings out.
  7. Feb 11, 2011 at 4:14 PM
    #207
    gtokarski
    gtokarski Well-Known Member
    George
    Dublin, CA
    06 4x4 xtra cab silver
    OME 886, AAL, ARB Bumper, XRC8 Winch, Sony MEX-N5000BT, and one angry beagle.
    I tried the strap method and cracked the entire fan assembly in half. It was REALY stuck on there good. Or I'm just hamfisted :facepalm:
    Anyway. I cleaned the whole thing with brake cleaner on the main housing and electrical contact cleaner on the motor. There was lots of dust inside, dark redish brown crap. I lubed the bearings with spray on white lithium grease as suggested. I re-assembled and superglued my cracked fan assembly and NO MORE CHIRP. It does wobble A LOT at the highest speed (vibrates the whole dash) because a few blades are missing. Ordering another motor/fan assembly from Amazon before the summer hits.
  8. Feb 11, 2011 at 5:36 PM
    #208
    Voos
    Voos Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    If any of you still have this problem see your dealer, Toyota has re engineered this fan assembly. I just had mine installed
  9. Feb 11, 2011 at 6:01 PM
    #209
    rev25sharp
    rev25sharp Well-Known Member
    Al
    jacksonville fl
    Silver 17dcsb trd sport
    good stuff, thanks
  10. Feb 11, 2011 at 8:43 PM
    #210
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Took mine in last week, Got a call on Friday from the dealer service, he ordered it, will let me know once he gets it. Can take up to a month he said..I told him make sure to get a new redesign one if there is such a thing.
  11. Feb 12, 2011 at 6:45 AM
    #211
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    Can you take some pics of your "new" blower motor? My truck is going back again today.
  12. Feb 12, 2011 at 7:45 AM
    #212
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I was told last April the same thing....newly desinged motor installed and everything; only to find out 9 months later the squeak is back. I doubt highly that Delphi redesinged the fan supplied to Toyota.
  13. Feb 12, 2011 at 9:18 AM
    #213
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I just did this, as my replacement fan was once again chirping. A few things to note:
    If you have a couple long screw drivers, use one on each side of the fan, to pry the fan off. Also, a 7/32's socket will work if you dont have (or lost :eek: ) a 5.5 mm socket. Instead of grease, Im using Mobil 1 10w-30. Not sure if I like the idea of using grease, as it will add a little bit more load to the motor. maybe not much, but being as the bushings were dry, Im guessing this was due to less friction/load on the motor, so I wanted to use a light oil instead. We'll see how long it lasts.
  14. Feb 12, 2011 at 9:58 AM
    #214
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    My 09 with 34,500 miles just started doing this so I'm going to call the stealer on monday. Going to get it done before the warranty runs out.
  15. Feb 12, 2011 at 11:21 AM
    #215
    Voos
    Eric
    Albuquerque, NM
    I had mine replaced twice.. Then got a call from the dealer that the fan was being re engineered, and it would be at least a 60 day wait. They had over 50 on back order.. I waited over three months for it. No problems thus far
  16. Feb 14, 2011 at 3:25 PM
    #216
    StandupTaco
    StandupTaco Well-Known Member
    2010 DC TRD Sport
    I was at my dealer last week to have my wiper motor replaced under warranty and I checked on my fan motor. Was told it won't be in til spring and it's a new design coming to replace the old one. I hear the chirp on settings 1,2 and 3 but not high, yet. Driving me crazy! Service manager told me not to dig into myself and wait as it wasn't serviceable. Don't know if I can wait...Now that I know you guys are doing it I don't really care, I need it fixed and I can't wait til spring...
  17. Feb 14, 2011 at 5:46 PM
    #217
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Well just do a quick PM on it yourself. Read the first few pages here to get a idea what is involved. On the weekend pop it out clean it and relube it with SAE 30 oil a few drops on where the felts are and a tiny bit on the shaft. Put it back in. They will be none the wiser.
  18. Feb 15, 2011 at 1:06 PM
    #218
    j0sh
    Oklahoma
    '10 TRD Sport 4x4
    After dealer telling me the blower motor came in today and me going to drop my truck off, now I get a call and them saying its on backorder... This sucks as mine is only working on the high speed and they said they can't replace the resistor until they replace the blower...
  19. Feb 17, 2011 at 11:04 AM
    #219
    terrman
    terrman Active Member
    Osoyoos B.C. Canada
    09 TRD Sport SR5
    HID Headlights Sylvania Silver Stars Nerf Bars XM Radio
    I am also fighting the blower fan issue problem. This will be my third motor in less than two years. Dealer is very aware of the problem, as i was told mine is back order number 15, and they cannot find a motor in North America. Maybe toyota should put a copper pipe to the bearing, and we could add a drop of oil every month :p
  20. Feb 17, 2011 at 11:06 AM
    #220
    deerme
    deerme Member
    i took mine to the dealer and although they "couldn't hear the noise" (MORONS) they are ordering a new motor since it's under warranty. there's supposedly one other guy in line and they have no ETA on when the motor will arrive...
