Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Mar 1, 2011 at 10:47 AM
    #261
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    Yeah if you read the last paragraph...the part apparently is so new that there isn't a TSB out for it yet is what the tech told me. He had to call corporate to be able to install it because he wasn't sure if it needed the bracket that the older models of the blower had to have (4040 and 4041). I can post a picture of my work order if you want me too.
  2. Mar 1, 2011 at 11:01 AM
    #262
    TacomaHunter
    TacomaHunter Member
    Boston
    08 TRD Off Road DC 4x4
    Rear leaf TSB Bent Tailgate TSB L2S Bed Rails
    So, I have been on the waiting list for about 2 months now. I just called the dealer to see where I stood and magically the part had "just" come in. I apparently have really good luck.
    Anyway, my truck goes in on Friday and before hanging up I asked the service writer for the part number and she read off 87103 042 which is slightly different than what is posted above, but I had her read it of twice. I will be sure to check back in with the results.
  3. Mar 1, 2011 at 11:05 AM
    #263
    deerme
    deerme Member
    looking at my invoice from the repair now....says:
    87103-04042 MOTOR SUB-ASSY, BLOW
  4. Mar 2, 2011 at 7:44 AM
    #264
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Thank you guys.
    I'm going to have to call corporation and see if they can help me, Longo Toyota, Toyota Pasadena and Wondries are just wasting my time.
    Can't loose any more work days so I can leave the truck at the dealer all day for them to remove leaves (according to them) and probably spray some WD40, because the noise is gone for 2 days after I leave the stealer.
    Thanks for the help ;)
  5. Mar 3, 2011 at 7:15 AM
    #265
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    is there an aftermarket motor we can use to replace the stock one??
  6. Mar 3, 2011 at 3:40 PM
    #266
    Voos
    Voos Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    Ugh... New "redesigned" fan is squeaking.. only a few weeks old
  7. Mar 3, 2011 at 3:49 PM
    #267
    jloe
    jloe Well-Known Member
    john
    syracuse ny
    SR5 2.7 4x4
    TRD alloys, Cooper Tires, Clairion sound, Weathertech floorliners,AVS bugshield,Toyota Toolbox,secondary air filter delete,tailgate antitheft mod,Afe pro dry filter,fog light mod Leather interior mod
    Just 2 k mi on my 2011 and just started making noise! :eek::confused::eek::mad: What did I just buy?
  8. Mar 3, 2011 at 3:49 PM
    #268
    gtokarski
    gtokarski Well-Known Member
    George
    Dublin, CA
    06 4x4 xtra cab silver
    OME 886, AAL, ARB Bumper, XRC8 Winch, Sony MEX-N5000BT, and one angry beagle.
    just a quick note about my replacement from Amazon:
    TYC 700188 Toyota Tacoma Replacement Blower Assembly
    No squeak! But the fan is a bit unbalanced and makes a bit of whirly noise at high speed, Not nearly as much as the old unit though. The blade assembly is held on by a retention clip so I can probably get it apart without breaking it next time :)
    I think it was worth it for $40.
  9. Mar 3, 2011 at 4:27 PM
    #269
    tommyxv
    tommyxv Well-Known Member
    Delaware
    '11 DC 4x4 TRD Sport
    Can anyone else confirm that the new fan #04042 is also defective?
    I am bringing my 2011 in for the first oil change and asked them to change the fan blower assembly because mine squeaks and chirps too. I was going to request the new part number. :(
    I found this old TSB for the foam bandaid fix.... what a joke! 17 page TSB to add foam.
    http://www.scribd.com/doc/28543771/T-SB-0092-10
  10. Mar 3, 2011 at 4:34 PM
    #270
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Could not handle the squeek anymore (even after repair) so I went for a TYC from ebay. Took 2 days (!!!!) to get here in canada with standard shipping just look for directauto. The fan is not perfectly balanced but still way better than the old one.
  11. Mar 3, 2011 at 5:24 PM
    #271
    deerme
    deerme Member
    i noticed my new fan started the squeaking again today!!!!! WTF!!!!!!! it's the 04042, new "redesigned" fan and it's squeaking after being installed for a week!!!!!!
  12. Mar 3, 2011 at 5:40 PM
    #272
    Yota1
    Yota1 Well-Known Member
    gives me a headache. going to make sure this is taking care off soon
  13. Mar 3, 2011 at 10:42 PM
    #273
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I'm new on here, and just found this thread, but did something similar to the OP's procedure on mine last month - BUT, I also found that there was an excessive amount of end play in the motor, and that the shaft was "chattering" vertically when the fan was running. With the bottom plastic cover removed from the motor, I could push the end of the shaft upward and eliminate the noise.
    I disassembled the motor, cleaned it out with compressed air, gently chucked the shaft in a drill (redneck lathe :D) and cleaned up the commutator bars with 600 and 1500 grit emery paper. Then, I added a thin brass washer to the bottom end, to take up the excessive end play. I had to remove two of the very thin fibre shim washers (there were 4) to get it right, as the new washer was thicker than needed. A little trial and error was needed for this part, but basically remove as much of the end play as possible without causing any added drag on the shaft. I applied a bit of synthetic grease to the bushings and the shaft, and it's been quiet as a mouse for over a month. The brass washer needs to be 5/16 or 8mm ID, and as thin as possible.
    If it comes back, I'm going to look into installing a Denso motor from a pre-02 corolla - I had the fan out of my wife's car to clean out the leaves, and while it is different, it just might be similar enough to make work. 10 years and 226000 Km's and that motor is still good. Denso vs Delphi - not even close.:(
  14. Mar 4, 2011 at 3:15 AM
    #274
    SPORT
    SPORT Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    Just a note for those newbie's to Toyota Tacoma.
    I had a 2001 Tacoma with 90,000 on the odometer. In those 9+ year, it only had to replace the battery twice. that's probably due to pulling and drawing power from a camper trailer. My truck had a tow package installed later, and as such, really wasn't meant for the job. But it NEVER let me sit due to mechanical problems.
    I liked it so much I bought another Tacoma. Although I too am aggrivated by the nuescent chirping, I am reminded that most American vehicles experience more problems than our Toyota Tacoma.
    I have been working with Toyota Customer Service directly and they say the newly designed part is slated for distribution mid March. I'm not sure if it's the 4042 or something different. I'll see what I can find out.
    Inspite of the chirp. I doubt you'll be disappointed by the relaibility, as well as the abilities of your Tacoma.
    Sport
  15. Mar 4, 2011 at 5:18 AM
    #275
    TacoSport
    TacoSport opinions are like assholes; everyones got one.
    NE
    2011 TRD SSM Sport DCSB w/Tow
    x2
  16. Mar 4, 2011 at 6:57 AM
    #276
    TRDguy
    TRDguy Cruisen GA
    Marietta ,GA
    2010 PreRunner DC SR5 TRD Sport
    K & N air filter, antenna X 13in., window tint, vent visors, bug guard, floor mats, door sill protectors, tonno-pro tri-fold tonneau cover, pop n lock tailgate lock, Truck Champ chrome Nerf Bars, LED lights in cupholder mod, tailgate hose clamp mod, stainless bull bar, 1 inch leveling kit, rear under the bumper LED's, Halo headlights.
    Finally getting my new Blower Motor today. Took 5 weeks to get it here. They told me it was the newly designed part...hopefully the 4042 part number. Will let you know what they say about all these problems across the U.S. with this motor issue.
  17. Mar 4, 2011 at 7:35 AM
    #277
    TRDguy
    TRDguy Cruisen GA
    Marietta ,GA
    Did you bring it back in yet? I'm curious to hear what they say about this as it's the "new" redesigned motor. I'm going in today for the same motor. Now I'm worried!
  18. Mar 4, 2011 at 7:44 AM
    #278
    El Tano
    Pasadena. CA
    10 Tacoma TRD sport
    For those who replaced the fan 3 times or more
    When, enough it's enough:
    Lemon law:
    The same problem has been subject to repair four or more times by the manufacturer or its agents and the buyer has at least once directly notified the manufacturer of the need for the repair of the problem as provided in the warranty or owner's manual.
    It is a good idea to send your written notice to the manufacturer at the address shown in the warranty or owner's manual by certified mail, return receipt requested so that you have proof that your letter was received. Keep a copy of all correspondence.
    Text source: http://ag.ca.gov/consumers/general/lemon.php
    And for all the haters. Me in my case, I sold my old truck, because I can't loose a day of work,( no work no money). I already left the truck 3 times all day at the dealer and last time they didn't do anything. The window seals were not replaced, they are still open and the piece of window molding that was hanging down from the back window was still hanging down. I'm not saying that Toyota it's doing this, But Toyota know that there is a problem and they are trying to get away with, they took a gamble, the fan problem it's not new, they new about the leaf springs in 2009 and they kept building trucks with the 3 leaf springs, out of the thousand trucks that they build, I don't think every single one will load it and have problems but for those who trusted Toyota and got a truck for work, has to go to the dealer, an stupid amount of times to have the problems fixed.
    A recall it's not the solution, but don't give me shit if I have a problem and there is a TSB for it.
    sorry, but I have all day to do nothing, since my truck is parked in the dealers lot to fix the moldings , the fan and the rear view mirror. The good thing is after they are done they wash your truck !!!!ohhh I love those automated car washes, those plastic rolls really apply spiderwebs to the paint..Even when you tell them DON'T wash the truck, they do it anyway. They want the customer to be happy 8(
  19. Mar 4, 2011 at 11:51 AM
    #279
    zombiekiller
    zombiekiller Well-Known Member
    Dela-where?
    '10 doublecab trd
    My stealer has been no help with this. 8 weeks i've been waiting now. Called the "toyota customer experience" too. what a bunch of shit. they said it is backordered and that they'd call me in another 2 weeks to give me an ETA on the part.
    so the dealer wont help. Corporate wont help. I shouldnt alter the truck at all as toyota corp said that i'd void my warranty on much of the electrical system by putting in a non factory part or by disassembling the part and greasing it.
    so now i'm driving my 12 year old truck that has no issues while my 2010 sits in the driveway because the blower motor squeek is louder than the radio.
    this WILL be my last toyota after owning 6. i guess an ecoboost ford is in my future. I most likely will trade in the taco right after they replace the blower.
    i used to like toyota, but after this truck, they've lost a customer for life.
  20. Mar 4, 2011 at 3:15 PM
    #280
    BlueSteel
    BlueSteel Well-Known Member
    James
    Houston, TX
    2009 Magnetic Grey TRD Sport
    I'm really sorry to hear that. I know your pain because I had an H3 that had a clear defect with the Intermediate steering shaft. I had it replaced 3 times and it still did the exact same thing every time, and this was with the redesign part. I had steering wheel shake/shifting and foot pedal vibration and tapping constantly. I finally said screw it and sold it even with all the money I dumped into it.
    I have had some issues with that blower motor on my taco. I complained a long time ago about it before a TSB was even out. I finally took it in today to the Dealer and they argued that they weren't going to do anything about it. I got that overturned and am in the cue for a new one now. I just live with alot of the rattles and pops because I'm tired of buying a new car every couple years.
