Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Sep 16, 2011 at 8:50 AM
    #501
    fyrmedc26
    fyrmedc26 New Member
    I took mine in for the little chirp it was making on low speed. They said ahhh yes i know the little chirp.. The mechanic told me that toyota knows about the problem and that they would replace that motor with an upgraded model that they had to order. Well my invoice also proves that they replaced the motor. The toyota mechanic told me that this is a recall that they arent sending out a notice but if you bring it in they will fix it..
  2. Sep 16, 2011 at 4:07 PM
    #502
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Must be a technical service bulletin (TSB). Recalls are meant for safety-related fixes. The difference is you must be within warranty to get TSB work done for free.
  3. Sep 16, 2011 at 4:14 PM
    #503
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    Mine just started this and just went out of warranty. Is it covered out of warranty?
  4. Sep 16, 2011 at 5:33 PM
    #504
    Eltacos
    Eltacos Well-Known Member
    BFE CA
    TRD Off Road
    LED conversion on every accessible bulb, TRD exhaust (dealership threw in for free along with the Blu-Logic).
    Good read.
    I thought I got a bum fan motor. Doing this on my next days off.
  5. Sep 19, 2011 at 4:55 PM
    #505
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    I've had mine replaced 3 times. Warranty expired a few months back, and I just noticed it squeaking again. Looks like I have a something to keep me busy one rainy afternoon this winter.
  6. Sep 23, 2011 at 8:30 AM
    #506
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Had mine fixed. the dealer told me that there was a "new" TSB out for this. not sure if anyone has had this new motor put in yet, or if it even is a new motor. Anyone know what they put in here?
  7. Sep 23, 2011 at 9:08 AM
    #507
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    I have had mine replaced 3 times so far. Last time was with the new updated motor, it has the insulation kit, and its back squeaking.
  8. Sep 23, 2011 at 10:48 AM
    #508
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    Unfortunately 4042 has been around since about March :cool: had it installed when it first came out and it squeeks a bit but not as bad as the previous version did. I actually haven't heard it squeek in about a month *knock on wood*
  9. Sep 25, 2011 at 6:10 PM
    #509
    mantry
    mantry Member
    Mark
    Salt Lake City
    06 Tacoma SR5 Sport Double LB
    Well great to say, I pulled my blower motor out and using the pictures and description in the first note, I pulled my motor apart and using some white lithium grease and a que tip lubed up the two bronze bushings and then put it all back together. So far, after a couple of days, no more squeeking, ticking or other noise.
    Thanks TACOMA WORLD!!!
  10. Sep 26, 2011 at 5:22 AM
    #510
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    I'm on my 2nd motor and it squeeks so bad it doesnt matter what the temp is. It squeeks during a/c AND heat use. I'm going to clean it off and use some dry teflon lubricant. Stuff used for high end bike chains and off road ball joints that keeps them from squeeking
  11. Sep 29, 2011 at 7:02 AM
    #511
    Razorecko
    I just opened it up today...
    used the stuff you use on your TC UCA's...
    used it on the springs/rubber patches around the base casing. Also one of you said if you press on the rubber patches it'll go quiet. So imho it would mean the springs do not have enough tension. I pulled them a little bit to increase them like 20% in length and than stuck them back in. As of now the blower motor is queiter than it has ever been. Even when I got the truck. I did notice alot of copper shavings in the grease when I opened it up... We'll see how it works out in the long run but I think the stretching of the springs made the real difference.
  12. Sep 29, 2011 at 9:28 AM
    #512
    KenLyns
    Belly of the Beast
    @mantry and Razorecko: be prepared to repeat the procedure in a few months.
  13. Sep 29, 2011 at 10:12 AM
    #513
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Or less with the cold coming.
  14. Sep 29, 2011 at 12:08 PM
    #514
    Razorecko
    we'll see...My other idea is to use a zip tie or a clamp to wrap around the metal base of the motor and tighten it up. See if that tightens up the clearances enough to keep anything from making noise....If it wears out the motor sooner, oh well. The teflon lube is the only thing that will queit down my tc uca's from squeekin also. And I've tried every single possible lube, grease, and spray on those
  15. Oct 1, 2011 at 6:33 PM
    #515
    Oshnjoe
    Oshnjoe Well-Known Member
    Joe
    Outside Philly
    2010 SR5 4X4 DC LB
    seat covers, floor mats, ARE cap, Yakuma racks, 4 leaf TSB, running boards
    I've been having this same chirpping since last winter. First thought it was just me but it never really goes away.
    will call my wonderful dealer Monday
    thanks again U'all
    Joe
  16. Oct 9, 2011 at 6:57 AM
    #516
    Phantom
    Phantom Well-Known Member
    Northern NJ
    2011 TRD Sport Double Cab
    My Tacoma has 667 miles on it. It just started chirping this morning. Only had it for two weeks and its chirping. That must a record haha. I think I'll skip the dealer and just buy an aftermarket one when the sound gets to annoying.
  17. Oct 9, 2011 at 7:26 AM
    #517
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^^ I've tried some dry lude, and some Surgical high speed lube (all it says on teh bottle), and the dreaded chirping has returned. I had blower number 3 installed last week, so if it comes back, Im going to use the lithium grease.
  18. Oct 9, 2011 at 8:36 AM
    #518
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    phantom- what year is yours?
  19. Oct 9, 2011 at 8:45 AM
    #519
    Phantom
    Northern NJ
    Its a 2011. Just got it 2 weeks ago
  20. Oct 9, 2011 at 11:58 AM
    #520
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    :rant:This is all very sad:( and total bull shit. Toyota can't figure this out:confused: All they need to do is go back to who and what they were using 10 years ago or B 4 this all started.
