Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Oct 9, 2011 at 3:18 PM
    #521
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Did you remove the springs and stretch them out also ? This way they will give more pressure up against the magnets and create tighter tolerance ? I also lubed up the rubber pads that attach on the sides of the casing.
  2. Oct 9, 2011 at 3:20 PM
    #522
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No. I just lubed the bushings, and such.
  3. Oct 9, 2011 at 3:50 PM
    #523
    Razorecko
    A member was saying that when the motor was running he pressed on the rubber on the casing and the sound went away. And pressing on the rubber causes the spring to have more tension. I figured it could possibly be a tension issue on the spring somehow causing the noise. I'll keep this thread updated on how it goes but outside of me I have not heard of one single person stretching out the spring to give it more tension. Fingers crossed if thats the real issue at hand.
  4. Oct 10, 2011 at 7:43 AM
    #524
    dndj
    dndj Member
    Pacific Northwest
    2010 TRD Off-Road DC S/B, Magnetic Gray
    That was me, back in post #440 on page 22 of this same thread. Link
    Before I took mine apart I found pressing on both rubber blocks simultaneously while the motor was running caused the chirping to go away. If you look at the 2nd picture in my post, you will see that pressing there doesn't increase spring pressure on the brushes, because they are mounted in a hard plastic carrier. Pressing on the rubber puts pressure between the plastic brush carrier and the metal clip interface which the spring and brush are attached to. I my case I never stretched the brush springs, but I did put a dab of grease on them to damp any vibrations and prevent rubbing against nearby materials. I also put grease between the metal clip of the brush and the plastic brush carrier housing, and also a dab in the rubber insert too.
    For what it's worth it's been 5 months and mine is still perfectly quiet through summer and now in cooler temps as well. We'll see how much longer it goes.
  5. Oct 10, 2011 at 8:46 AM
    #525
    Oshnjoe
    Oshnjoe Well-Known Member
    Joe
    Outside Philly
    2010 SR5 4X4 DC LB
    seat covers, floor mats, ARE cap, Yakuma racks, 4 leaf TSB, running boards
    took it to the dealer last Friday
    They said there was a TSB on it
    they replaced it with an "updated version" and added an insulation kit
    no charge
    it's a 2010 w/10.8k miles
    done in 2 hrs along with to other TSBs
    - floor mats
    - wheel/tire combo
  6. Oct 10, 2011 at 9:07 AM
    #526
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Had this done too sound came back 6 mos later
  7. Oct 10, 2011 at 10:26 AM
    #527
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    X2
  8. Oct 10, 2011 at 11:11 AM
    #528
    CQB 1911
    CQB 1911 Well-Known Member
    Jesse
    AZ.
    2010 TRD OR AC
    Do you have the TSB number?
  9. Oct 10, 2011 at 11:14 AM
    #529
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
  10. Oct 10, 2011 at 12:36 PM
    #530
    Razorecko
    Guys there is no "new" motor design being installed. Talk to my service guy and he said toyota is still replacing them with the same old junk. Hence why I just decided to take mine apart. No way in hell am I going to go through another winter with Alvin the chipmunk dying in my glovebox
  11. Oct 11, 2011 at 7:07 PM
    #531
    Danmassman
    Danmassman Member
    2010 Tacoma Double Cab
    Razorecko---I couldn't have said it better myself. My 2010 is on its' 2nd replacement motor...and this one is now squeaking worse than the first two! I'm going to bring it back to the dealer yet again when I go to have my broken fuel door replaced!
  12. Oct 12, 2011 at 6:03 AM
    #532
    ToyTaco
    ToyTaco For the Retards, Im a Female
    Kristin
    Newark, DE
    '10 TRD Sport 4x4 modified
    Mine is a 2010 as well and my 2nd one just started making noises slightly so I will probably going in at the time of my oil change and have them put a new one in yet again.
  13. Oct 13, 2011 at 6:13 PM
    #533
    Oshnjoe
    Joe
    Outside Philly
    2010 SR5 4X4 DC LB
    no TSB # given
  14. Oct 14, 2011 at 10:30 AM
    #534
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Finally got my blower motor replaced today. I'm keeping my fingers crossed that this one will last longer than the first. I'm at 48 000 kms on the ODO.
    Don't know if they added an insulation kit or not, the paper work doesn't mention it.
    TSB # 3394
  15. Oct 14, 2011 at 12:56 PM
    #535
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Went in to get mine fixed last week. They put the insulating kit but used my old sqeaky motor. It didn't work from the moment I drove it away from the dealership. It was closing time and I figured I'd bring it up in 3K miles when I go for the 25K service.
  16. Oct 14, 2011 at 7:56 PM
    #536
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
  17. Oct 14, 2011 at 8:11 PM
    #537
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^ This is the TYC fan. Mine didn't chirp after last winter. We'll see if it will survive this winter.
  18. Oct 15, 2011 at 12:46 AM
    #538
    nfs257
    DFW
    She gone
    If yours lasted more than 3-4 months it did better than the one the dealer put in...
  19. Oct 15, 2011 at 11:48 AM
    #539
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    It's a faulty design, not even worth replacing tbh... just grease it every few months instead.
  20. Oct 19, 2011 at 8:54 PM
    #540
    Labambawarrior
    Labambawarrior Member
    Hello, Im a newb here. I had an '06 Taco with this blower motor issue...and now I have a 2010 Taco thats doing the same thing. The darn thing is driving me nuts!!! I took it to the dealer last month and they told me that Toyota is supposed to release a 'new' blower model sometime in October. They didn't fix\replace the motor, but told me to call later in the month to see if the new model has been released. I called the dealer today. They told me it hasn't been released yet. Has anyone else heard this? Also has anyone tried the VDO aftermarket blower motor? Im thinking of replacing it myself since Toyota keeps failing to address the issue.
