Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Oct 20, 2011 at 6:45 AM
    #541
    Richard Cranium
    Richard Cranium The lice...they hate the sugar
    Ted
    Omaha, NE
    2013 Raven FR-S
    Forever sideways and smiling :D
    'Tis the season...
  2. Oct 20, 2011 at 6:46 AM
    #542
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Must be, mine just started making noise again also... :mad:
    I guess it's time to tear down, clean out and regrease the motor again
  3. Oct 20, 2011 at 7:25 AM
    #543
    Richard Cranium
    Ted
    Omaha, NE
    2013 Raven FR-S
    It must have something to do with heat going through the system. It doesn't make a sound in the summer with the AC blasting, yet it sounds like a tank full of gerbil squeaking with heat on low in the winter. Squeak free so far since I got an "updated" version last Feb.
  4. Oct 21, 2011 at 5:12 AM
    #544
    Ralph Pootawn
    Ralph Pootawn Well-Known Member
    Fairfax, Va
    '11 Timberland Mica TRD Off-Road
    N/A
    It's gotta be. I just got mine replaced at the beginning of Sept. and had the heat on yesterday and it started squeaking again. :mad:
  5. Oct 21, 2011 at 7:04 PM
    #545
    StandupTaco
    StandupTaco Well-Known Member
    2010 DC TRD Sport
    I think it's the opposite, the colder temps. Mine just started doing it again and it was replaced last Feb/March. It could be dissimilar metals that expand/contract at different rates and show their ugly heads when the cooler temps come. Not sure, just a guess! Either way, mine will be going in for #2 soon...I'll wait til it happens on the 2nd setting before I get it replaced.
  6. Oct 25, 2011 at 11:47 PM
    #546
    biborado
    biborado Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
    I took apart mine after it initially started squeeking and I used some mobil 1 synthtic grease on the mating surfaces following the instructions on this thread. After about 4 months, the squeek came back.
    After taking it apart recently I found that the grease was really not the right stuff to use. It gums up and is really too "sticky" for this application.
    I had some Loctite Silver Grade Anti-seize on hand and decided that i'd try it out and see if it made a difference. So far so good, it's been squeek free for several months now.
  7. Oct 26, 2011 at 11:02 PM
    #547
    Randy22
    Randy22 New Member
    Randy
    Tacoma
    Viper 2-way starter, Leather seats, LED cab lights
    My fan was chirping so I pulled apart the whole fan and greased it, but no it wont free spin. Any ideas why? If I try using it, it blows the 50 A fuse. I know it should free spin but its like the magnents are holding it still.
    Any Ideas?
  8. Oct 27, 2011 at 4:43 AM
    #548
    Randy22
    Randy22 New Member
    Randy
    Tacoma
    I took my entire motor and fan apart to clean/lube to get rid of the squeek, and when i put it back together and turned it on it blew the fuse. Took it back apart and found the fan wouldn't free spin. Once I loosened off the two screws on the end bell the fan would spin freely. I put a little lock tite on the bolts to keep them from turning, as they were not tight on the lock washer. Also when I was putting the plastic peice with the 4 bolts on over the end bell if I tightened it too much it stopped the fan from spinning freely.
    Hope this helps anyone who is having the same problem.
  9. Oct 27, 2011 at 5:38 PM
    #549
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
  10. Oct 27, 2011 at 6:24 PM
    #550
    jabrackin
    jabrackin Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    anyone seen the new TSB on the updated blower motor? Is it really true? After all this time is there a new one?
  11. Oct 27, 2011 at 6:34 PM
    #551
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    Yes...I just got it last week.
  12. Oct 27, 2011 at 7:18 PM
    #552
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    do you know the part number?
  13. Oct 27, 2011 at 10:10 PM
    #553
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    T-SB-0162-11 is the TSB number. I'm sure if you wanted the actual part number, you could call Toyota and they would be able to give it to you of you're out of warranty and wanted to buy and install it yourself...
    I hope this TSB actually fixes this.
  14. Oct 28, 2011 at 5:10 PM
    #554
    genconex
    genconex Well-Known Member
    San Tan Valley
    11 TRD Sport DC LB 4X4
    -Leer shell -ImMrYo mirror bracket -OME suspension kit -1.5" Body Lift -Dirt King UCAs -Dirt King LCAs -Hypertech Speedometer Calibrator -315/17R70's on 17x9 wheels -Pelfrey aluminum front bumper -Smitty XRC 9500 winch with Warn wireless remote and incab switch -Blackoak LED lightbar -Rigid fog lights
    My 2011 started to rattle around 10,000 miles. Finally had it replaced with the newer MOTOR SUB ASSY: 8710304043. Morgan (dealership mechanic) at first informed me that the '11 model has the newer assembly and the older assembly with the issues was in the 05-09 models. After he searched Toyota's maintenance and service bulletin POI's (if I recall what he said correctly) he found out that these issues have been extended through the '11 model yr. Per Morgan, 05-11 assemblies 8710304040 - 8710304042 have different hardware connecting the fan to the motor which includes a compression spring and the 8710304043 has a bolt connecting the fan to the motor. Hopefully Morgan is correct and this will resolve the rattling issues I was having because it was driving me nuts.
  15. Oct 28, 2011 at 8:33 PM
    #555
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    does anyone have a TSB PDF file on the new update to the blower motor?
  16. Oct 29, 2011 at 7:03 AM
    #556
    Ralph Pootawn
    Fairfax, Va
    N/A
    In my 2011, the fan started ticking around 3000 miles, so I had it replaced the second week of Sept. (last month). I'm now around 12k miles and one day 2 weeks ago, it started lightly ticking again, but I haven't heard it since. Strange.
  17. Nov 2, 2011 at 10:33 AM
    #557
    Fla Yota
    Fla Yota Well-Known Member
    Drew
    Central Florida
    11 TRD Sport DC 4x4
    Black TRD Wheels
    2011 with 5000 miles and mine started ticking at low fan speeds!! WTF! This is ridiculous! I'm taking it in for the first oil change today and I'm going to mention this as well. It seems to coincide with cooler air temps from reading all the posts in this thread. Mine started the first week of cool weather.
  18. Nov 2, 2011 at 2:49 PM
    #558
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Out of all these problems only one person has tried the aftermarket fan that i posted the link too? I was hoping that was a $40 fix to this ongoing problem!?!?
  19. Nov 2, 2011 at 4:14 PM
    #559
    Hardwater
    Hardwater Well-Known Member
    Great Falls, MT
    2011 MGM TRD AC
    1.5" Add-A-Leaf, Toytec Coilover kit @ 2", LR UCA's, Bilstein 5100's all the way around, ProComp 7032's, 265/75 16 Duratracs, bed mat, Weather Techs Digital Fit Floor Mats, Wet Okole Seat Covers, Satoshi
    My 2011 starting chirping on low around 3k and by 7k was doing on both mediums, I just took it apart and greased the bearing, I never bothered complaining to Toyota since every blower seems to do it... I can't hear a thing now, but I just did it this afternoon.
  20. Nov 2, 2011 at 4:25 PM
    #560
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    I can't believe I never saw this post. I don't even remember what I did to fix it. I think I kept hitting the damn thing and/or I turned up the radio a little louder than usual. Either way, it's not doing it now. If it starts up again, I'll know what to do.
    REP PTS to the OP (better late than never).
