Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Sep 21, 2010 at 3:18 PM
    #41
    Krusey1011
    Krusey1011 Well-Known Member
    Kyle
    Washington
    Just finished. Their was alot of crap in there you're right. It sounds alright. Not the smoothness I was looking for but I'm just going to accept the fact that it's a cheap noisy fan. :pout:It smells like grease in my truck now too lol but I'm sure it will wear off.
  2. Sep 21, 2010 at 3:30 PM
    #42
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I happened to have turbine oil closer at hand then grease, so no smell for me :D
  3. Sep 21, 2010 at 7:55 PM
    #43
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    7 months later, the chirp is back. Well, not back completely, but it does it once in a while.
    But I'm sure it's just a matter of time until it's back in full force.
  4. Sep 21, 2010 at 8:02 PM
    #44
    flightcancled
    You could just replace the bearings.
  5. Oct 25, 2010 at 6:46 PM
    #45
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I had the blower replaced under warranty over 4 years ago and it still chirps. Thanks for the info, only took me about 1/2 hour to clean the electronics and lube the bearings...now I won't go crazy this winter!
  6. Oct 25, 2010 at 9:54 PM
    #46
    WATacoRider
    TRD Sport 4x4
    you can buy the bearings? Part #?
  7. Oct 25, 2010 at 10:20 PM
    #47
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Why couldn't I have found this before! Thank you! Will try this week
  8. Oct 26, 2010 at 7:11 AM
    #48
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    i had this problem they replaced the motor under warranty
  9. Oct 26, 2010 at 11:06 AM
    #49
    MJG
    MJG Well-Known Member
    Michael
    North Bay
    Kenwood Nav system, Sub, etc
    My 2010 had this problem. Thanks to this post I was aware of the tsb. Had it fixed under warranty. Quiet now. Hope it was a permanent fix..
  10. Dec 4, 2010 at 6:29 PM
    #50
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    its not.
  11. Dec 5, 2010 at 11:54 AM
    #51
    flightcancled
    Pretty sure they are standard hardware.
    Mine started chirping WORSE in the past week. I'll be looking into better solutions soon.
  12. Dec 5, 2010 at 12:06 PM
    #52
    tacoma1
    tacoma1 Well-Known Member
    Greg
    Blossvale NY
    17 TRD PRO
    Mine gets replaced thursday at dealer.
  13. Dec 5, 2010 at 12:11 PM
    #53
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    subscribed... just in case the dealer won't work with me and give me a 3rd blower motor.
  14. Dec 5, 2010 at 12:15 PM
    #54
    teej
    teej Active Member
    NH
    '10 TRD Sport Dbl Cab
    OEM bed mat, Extang Trifecta tonneau, XM satellite radio, remote start, bull bar, hella 500s
    thanks for the write up but i don't think i should spend any of my own time trying to fix something that toyota couldn't design right and that they should fix under their dime. i'll take my chances with toyota trying to fix it first
  15. Dec 15, 2010 at 12:22 PM
    #55
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    what is the easiest way to get the plug out because mine wont come off?
  16. Dec 15, 2010 at 12:24 PM
    #56
    ShaLor
    ShaLor Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    There should be a tab you push in and then it will pull right off.
  17. Dec 15, 2010 at 12:46 PM
    #57
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Finally did this today, quiet as hell now. Thanks. Also for the clicking on the electrical contacts I put some dielectric grease on it... hopefully it'll last awhile but we'll see.
  18. Dec 16, 2010 at 7:02 AM
    #58
    uscg2008
    coby
    ya i pushed it it and i still isnt coming out i tried wiggling it back and forth and i even tried gently removing it with a pair of plyers. ill try on more time maybe i didnt push in enough. i did push down on it more than it. so who knws.
  19. Dec 16, 2010 at 5:58 PM
    #59
    larryde09
    Larry
    Boston, MA
    Mine gave me some trouble too. I unbolted the entire assembly from the mount so I could get to it easier on the floor. I had to use some pliers to convince it to come off, just keep at it, just don't break anything.
  20. Dec 26, 2010 at 7:01 AM
    #60
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I had to take the motor housing off and use some pliers to break the plastic that holds the tab in there. It was a bitch. My plug is all dinged up using pliers. Be very careful, if the pliers slip off the plug, it will crimp on the wires. If the wires break, you won't have to worry about a fan noise anymore :(
