Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Dec 1, 2011 at 6:55 AM
    #641
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    Got my blower motor replaced during this past summer (2nd one) now I start to hear the noise coming back...this blows (no punb at all)
  2. Dec 1, 2011 at 8:46 AM
    #642
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    I had my blower motor replaced as well at around 15,000 miles...now I am creeping up on 30,000 miles and it started up again. Warranty expires at 36,000. Knowing they did not fix the problem under warranty, will they still try to fix it after it expires? Like a pre-existing issue that was never really fixed?
  3. Dec 1, 2011 at 12:24 PM
    #643
    Airwolf NSX
    Airwolf NSX Well-Known Member
    Irvine, CA
    2010 Tacoma TRD Sport Double Cab
    When you guys say it's "CHIRPING" do you mean you hear this sound whenever you turn on your BLOWER? Whether if it's hot or cold?
  4. Dec 1, 2011 at 12:34 PM
    #644
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
  5. Dec 1, 2011 at 12:36 PM
    #645
    Airwolf NSX
    Irvine, CA
    hot damn! i thought iw as the only person who had this issue. bugs the turd out of me.
    everytime i have the blower on the low setting, the sound.. that annoying sound is there and never goes away.. but the moment i turn it up high, it's ok.
    never knew i had to grease this sucker.
  6. Dec 1, 2011 at 1:16 PM
    #646
    testedone
    Rick
    U.S.A.
    I may sound like a dick...but you should read all the pages on this issue to get the full history on what you should do...
  7. Dec 2, 2011 at 9:34 AM
    #647
    tasz
    tasz Member
    canada
    4 weeks now and all is still quiet. Sorry for the multiple postings but I am just trying to keep it in the most recent part of the forums as so far it has been the only thing that has solved the chirping issue for me.
    Give what I have posted a try. Last post of mine was on Nov16 and Nov24
  8. Dec 3, 2011 at 12:38 PM
    #648
    MarkCNP
    MarkCNP Active Member
    Mark
    Alberta
    '09 DCLB Sport 4x4
    OME 885 Dakars LR UCA Nitrocharger Sports
    I had done a separate post on this but I thought it might be helpful to post it here too.
    Here are comparison pictures of the old 05 blower motor compared to the newest (-0404(3)). They are quite different externally. I had tried to lubricate the old motor (it was VERY noisy and often did not work in the two lower settings) but the brass bushing had come out so I had to replace the whole assembly.
    The new one is on the left. The white cable clip had to be transferred to the new motor as it did not come with one.
  9. Dec 7, 2011 at 10:25 AM
    #649
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Well I'm sad to report after two months on my new blower motor (#2) the chirp is back. Argh! This is getting annoying but I don't think they put the new model in. Gonna call the dealer tomorrow and get the new model blower model installed.
    I searched back a couple pages and couldn't find it, can someone tell me what the part # is for the new model? Thanks!
  10. Dec 7, 2011 at 1:57 PM
    #650
    Skidmarc
    Skidmarc Active Member
    Marc
    Atlantic Canada
    4WD I4
    Ends with "...43".
  11. Dec 7, 2011 at 2:36 PM
    #651
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I have done about everything to mine including this http://www.tacomaworld.com/forum/2n...otor-squeek-chirp-low-fix-23.html#post3327477 and it still chirped after a few weeks. Now I don't know what I've done but on about the 6th or 7th lube it finally has quit making a noise. It's been months now and it's in the single digit temperatures. The last time I didn't care much about cleaning and polishing. I was mad and just slapped a big glob of Mobil 1 grease in both bearings and put it back together. I didn't spray any cleaner. I just wiped off the grease with a rag. I didn't do a good thorough job. Remember I've done this a half a dozen times before with no success but this time it seemed to work. I just tightened up the screws semi-loose because I knew I'd be back in there in a few weeks. I guess you just keep messing with it until it works.
  12. Dec 7, 2011 at 3:28 PM
    #652
    whale123
    whale123 Active Member
    New Jersey
    TRD Sport
    Leer Cap
  13. Dec 8, 2011 at 3:46 PM
    #653
    tasz
    tasz Member
    canada
    5 weeks and still quiet. Give it a try and please reply if it works for you too.
    Thanks
  14. Dec 8, 2011 at 4:41 PM
    #654
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    ^ I may have to try this..
    But I dont have the Toyota blower, its a after market one (TYC Part). It makes a little whistle/chirp..
  15. Dec 9, 2011 at 8:03 PM
    #655
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Mine just started chirping & driving me nuts. I am going into the dealership tomorrow to talk with my service manager. She has never done me wrong before so I doubt they will give me any grief.
  16. Dec 10, 2011 at 7:53 AM
    #656
    NvrSumR
    NvrSumR Well-Known Member
    Jeff
    Colorado
    Chirp free for 3 weeks on the new motor.
  17. Dec 10, 2011 at 11:58 AM
    #657
    maestroz2
    maestroz2 Well-Known Member
    Dave
    Erie, PA
    2010 DoubleCab Pyrite Mica TRD Sport SB
    TRD Skid Plate, Toyota Bed Mat, WeatherTech window visors, WeatherTech Floor mats, Access LE Bed Cover, Rocky Mounts Bike mounts, Astrostart 2-way Remote Start, TRD bronze beadlock wheels, Factory roof rack.
    Just got the #3 part number motor installed today, so far so good.
    However Superior Toyota in Erie, PA needs to find new people to run their service dept. I had them order parts, then called a few days later and the parts dept said they had two in stock. Then i made an appt and the service guy at the front desk had no idea they had them in stock and told me that the parts dept doesnt tell him anything.
    Get your shit together guys.
  18. Dec 10, 2011 at 2:12 PM
    #658
    extremachn1
    Turd Furgison
    Tucson, AZ
    Went in today and talked with my service manager at Desert Toyota in Tucson. She didnt even bother looking at it, called parts to make sure the new motor and resistor was avaliable and scheduled me for Monday.
    Desert Toyota is AWESOME. I have a lot of mods done to my truck and they never once have tried pulling any of that BS others dealers have. And I didnt even buy my truck from them. They will definately be my next dealership I buy from.
  19. Dec 10, 2011 at 3:07 PM
    #659
    jdburns1254
    jdburns1254 New Member
    jay
    reno, nv.
    floor mats, seat covers, and rims
    so its good to know that you can grease the shaft and get rid of the noise. My taco has about 6k on it, and the fan motor just started to make a ticking noise when its on on low. It sounds like a piece of bebris caught against the fan blades, like a card in a bicycle wheel. Any way Im glad Im not the only one with the issue. I will be taking it apart this week end, can"t wait to fix it!
  20. Dec 10, 2011 at 5:04 PM
    #660
    extremachn1
    Turd Furgison
    Tucson, AZ
    Its a temp fix. If you read through all the posts everyones chirp came back. No one has found a permenet fix other than to turn it off!!!
