Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Mar 6, 2012 at 10:30 AM
    #841
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    got my blower fan replaced today free of charge. thanks toyota for making it right
  2. Mar 6, 2012 at 10:41 AM
    #842
    mondexyota
    mondexyota Well-Known Member
    Beau
    Titusville, FL
    2010 Barcelona Red DC SR5 4x4
    3" Toytec spacer lift, 285x70x17 Nitto Terra Grapplers on 17x9 XD Misfits
    My chirp has been fixed! Thanks Toyota, they put in a brand new blower motor & now I actually enjoy using the AC.
  3. Mar 6, 2012 at 10:46 AM
    #843
    Texio
    Texio Well-Known Member
    Austin, TX
    11 4WD DBCab SB
    It took a couple of months, and a couple of trips to the dealership, but I have a brand new (and quiet!) blower motor, and a 4th leaf on my rear springs! Quiet and solid ride, finally!
  4. Mar 6, 2012 at 12:12 PM
    #844
    fixer5000
    massachusetts
    a couple of months? really? i made an appt online yesterday and today i have a new blower motor installed and springs on order for later this week!
  5. Mar 6, 2012 at 12:30 PM
    #845
    Texio
    Austin, TX
    11 4WD DBCab SB
    The first time I went, for my 5000 mile check-up, they ordered the springs. The second time they installed the springs, but instead of adding a 4th leaf, they just replaced my springs with a new 3-pack (...). Then they ordered the correct springs, but they were back ordered nationally, and also ordered the blower motor. Finally, I went back last week and had the correct springs added, and the newt blower motor installed. Now my truck drives a little more like a truck, and sounds a little less like a bike with a baseball card in its spokes.
  6. Mar 6, 2012 at 8:32 PM
    #846
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I put the Continental fan in this weekend. thoughts:
    -looks basically the same, mounts up perfect
    -the OEM fan, when it works, provides a nice wush sound. The Continental model has a bit of a robotic whizzing, which is not as nice, but much preferable to erratic whistling!
    Go go lifetime warranty!
  7. Mar 7, 2012 at 4:42 PM
    #847
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    This damn thing started squaking at me yesterday. I can't believe it only took seven months to go. The worst part is it didn't start slowly. It wasn't there at all then it was there all the time. Coming up on my 10K service so they'll be fixing this at the same time. I figure as long as it's still under warranty they can do it and when it goes later, I'll follow the directions in this thread.
    Edit: Mine chirps on low and speed 2. Annoying as hell!
  8. Mar 8, 2012 at 5:54 AM
    #848
    Dave333
    Dave333 Well-Known Member
    Dave
    Loganville
    06 PreRunner TRD long bed dbl cab
    Borla Exhaust, D/T LT, TRD CAI, Hella Rallye 4000, ARB, M/T Sidebiters 16", 265/75/16, Stubbs HD SKO Sliders, OME 3" lift with 886, Dakar Rear leafs, Satoshi
    My Tacoma has 102,000 miles and for about the last 40,000 I've been living with the chirp. The blower motor finally died yesterday, so sad. I ordered a new motor and resistor in anticipation of its death as it was intermittently cutting out.
    Latest blower motor cost was $108.81 and the resistor was $24.95 from toyotapartscenter.net. Came to $149.91 with shipping.
    Just finished the install in a hotel parking lot since we're on vacation. It took all of 20 minutes with the hardest part of the install being the removal of the pigtail of the old blower motor from the wiring harness. Tip of the day: use a very small flat head jewelers screwdriver and push down on the lip and then lever it out.
    Here's a quick rundown of how I did it and tools:
    Gearwrench flex head socket set with extender and a 5.5mm socket head.
    Small jewelers flathead screwdriver.
    Unhook the resistor. It's in the back by the firewall, easy latch.
    Remove the 3 screws holding the blower motor in with the 5.5mm socket. Used the extension on 2 of these because it was easier.As it comes down wedge out the black wiring harness clip. The white one just unclips and the wire will come out. Take your jewelers screwdriver now that you have some room to see and work with and wedge it in the top of the pigtail, slowly push down and lever it out tugging at the end of the pigtail, don't grip it by the wires though. It'll come out pretty easy this way.
    Now access the resistor. 2 5.5mm headed screws. Get the rear one first, it's a little of a pain. Then the front and out the resistor comes.
    Slide in the new resistor, the nipple to the latch should be facing you. Put in the rear 5.5mm bolt first, then the front. Wiggle the resistor so the foam gets a good seal as you tighten it down.
    Install the blower motor. When I set mine up there, it held in place without the screws. So I could use both hands to thread in the screws. Tighten them all up. Hook up the resistor, then the pigtail and reinstall the wiring clamp as well at this time.
    That's it.
    Probably one of the easiest installs on this truck I've done. Only reason it took 20 minutes is I kept messing with that pigtail until I remembered the jewelers screwdriver trick. Came right out.
    Just wanted to pass this info on to guys who are out of warranty but want to fix.
  9. Mar 8, 2012 at 12:56 PM
    #849
    Chickenmunga
    Keizer, Oregon
    I don't remember seeing any resistors... all I had to do was the fan body itself.
  10. Mar 8, 2012 at 2:54 PM
    #850
    Dave333
    Dave
    Loganville
  11. Mar 10, 2012 at 6:09 AM
    #851
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    Is there a warranty period for the TSB? Im over 65k....nevermind. Just found the actual doc for it.
  12. Mar 10, 2012 at 6:13 AM
    #852
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    2019 TRD Double cab, Long box
    Roof Rack, Step Bars, 3” Rough Country lift 265/70/17 Goodyear DuraTracs
    Ahh that's what that noise is. Thanks for letting me know
  13. Mar 10, 2012 at 8:14 PM
    #853
    CVTejas
    CVTejas CVTejas
    Charles
    Fort Worth, TX
    2010 Taco 4x4 TRD Sport
    Farad Cold Air Intake, BFG All Terrains, ARE Z-Series Deluxe Fiberglass Top w/ Keyless Entry and LED interior lighting,Road Armor front bumper w PIAA 510 driving lights, Edlebrock adjustable shocks w factory coils, road Armor front bumper. Kenwood DDX8901HD
    Well, after 3 months with replaced blower motor, I'm happy to say the sqeek hasn't returned. However, I do get other noises out of this motor. Granted, they are not nearly as annoying as the Chirp so I've decided I could live with it.
  14. Mar 13, 2012 at 11:55 AM
    #854
    NiceGuyEddie
    NiceGuyEddie Well-Known Member
    Chino, SoCal
    none yet
    3-13-12
    the squeak returned after 11 months. still under warranty. (there was a 1-year on the new blower regardless of vehicle warranty/age.)
    they installed a "more improved 2nd-generation replacement blower" today and the squeak is gone...
    for now.
  15. Mar 13, 2012 at 1:08 PM
    #855
    Capt Ike
    Capt Ike Well-Known Member
    Josh
    Gainesville, FL
    '14 PreRunner TRD Sport
    Just got mine replaced today free of charge. I do like that Toyota stands behind their products. An hour and a half and I can actually use the A/C again!! Whew....:D
  16. Mar 13, 2012 at 4:51 PM
    #856
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... ^^^ ... great step by step DIY info ... :D
  17. Mar 14, 2012 at 5:37 AM
    #857
    sthrnprd116
    sthrnprd116 Well-Known Member
    Jordan
    North Carolina
    2010 DC Short Bed TRD Sport 4x4 Pyrite Mica
    N-Fab Step Bars, WeatherTech Liners, Bed Mat, Extang Trifecta Tonneau Cover
    Had a new "improved" blower motor installed at Toyota of Concord in NC without any questions asked. Very straight forward. No chirps yet. *crosses fingers* :eek:
  18. Mar 14, 2012 at 12:35 PM
    #858
    oZmonKey
    oZmonKey Big Metal Hubajube
    Northern Colorado
    Black 98
    Unknown Spacer Lift.
  19. Mar 16, 2012 at 10:11 AM
    #859
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Got mine replaced by the dealer with my 10K service the other day. This is definitely a different motor and/or fan than what was in there. It doesn't sound the same at all (much quieter) yet still puts out a reasonable airflow. Maybe they actually did finally resolve this issue?
  20. Mar 18, 2012 at 1:05 PM
    #860
    sofiasdad11
    sofiasdad11 Reads more than posts
    Near the Windy City, but in the country
    2011 BLACK 4X4 DCLB TRD SPORT
    Flux capacitor (2nd gen version), toytec ultimate liftkit, amp research powersteps, custom katzkin heated leather incl. console cover, retraxpro retractable bed cover, earnhardt jr. cannons@18x9(summer),ballistic jesters@18x9 (winter),285/60/18 nitto grapplers, bodymatched bushwackers, the original Homertaco full satoshi " raptor" grill, viper 5704 remote/smart-start/alarm w/viper cellulor app, ravelco anti-theft device, ipcw tails, redline hoodstruts, oem roof rack, led maps/dome, backup light mod, swingcase storage box, jl audio stealthbox and amps,focal drivers,alpine carplay unit, pop&lock premium handle, seatbelt chime disabled, tailgate hoseclamp mod, rich evans caliper covers, weathertech digitalfit mats, flyzeye V2W,oem bedmat, salex console organizer,speeddawg shiftknob
    took mine in yesterday for the 10k service and to check out the chirp. told needed to be diagnosed by a tech before they replaced it. on the way in, i couldn't get the chirp to sound, thus thinkin they may not do it. the service manager was cool though, and loved what i had done to my truck, so when i picked it up, he stated they didn't hear a chirp either, but replaced it anyway (#87103-04043):)
