Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Dec 30, 2010 at 10:35 AM
    #81
    Danmassman
    Danmassman Member
    2010 Tacoma Double Cab
    Thanks for the help everyone---Dealer called me back today and went to order the parts from the TSB, and the motor is on backorder. Looks like they finally figured out that something is wrong! Thanks again,Dan.
  2. Dec 30, 2010 at 1:58 PM
    #82
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Does anyone have a set of calipers and there motor apart, I would like to know the inside and outside dimensions of the bushing.
  3. Dec 30, 2010 at 2:01 PM
    #83
    ubugarrity
    ubugarrity Well-Known Member
    Northern NJ
    TRD SPORT
    Glad I found this....I thought I was crazy. I'll be stopping by the dealer in the morning.
  4. Dec 30, 2010 at 5:00 PM
    #84
    Rossi396
    Rossi396 Rossi396
    Tony
    Pittsburgh, PA
    2020 Super White TRD Off Road DCSB
    Just received my new blower motor yesterday. No squeaking, just a constant whine on low! My daughter could actually hear it from the back seat! I turned the truck off and switched back and forth between the lowest and second setting and it sounds like a siren....Unbelievable! I'm sure when I take it to the dealer they'll say it's normal.
    Did anyone else here have their blower motor replaced and hear this...?
  5. Jan 2, 2011 at 10:54 PM
    #85
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    Agreed.. I know where your going with this. :D
  6. Jan 2, 2011 at 11:00 PM
    #86
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    yup! it was better with the squeak before the "new" one. now 20 000km later the squeak is back!
  7. Jan 8, 2011 at 11:00 PM
    #87
    Bu11etWhisperer
    Bu11etWhisperer My Taco is Blue!!!
    Mark
    Douglasville, GA
    2010 Prerunner, SR5, TRD Sport, Speedway Blue
    Noley's right, "its not"...I had mine replaced back in June, two months after getting the truck and damned if it didn't come back tonight. ARRGGG!!!
  8. Jan 8, 2011 at 11:05 PM
    #88
    Bu11etWhisperer
    Mark
    Douglasville, GA
    The person that checks you in at the dealer actually tried to make me think I was the crazy person hearing things that weren't there. "Sounds normal to me" he said. "But we'll have the mechanic look at it". Turns out they had to replace it, imagine that....That's what I told them to begin with.
  9. Jan 9, 2011 at 6:34 AM
    #89
    LabradorBoy
    LabradorBoy Well-Known Member
    Canada
    09 DCab TRD Sport
    All I have to say is that I am extremely annoyed with this POS fan. I have read the multitudes of threads on here, have taken the sucker apart, applied the lubrication as suggested and it just keeps coming back. I live where the temps are -30*C on a regular basis and the cold temps are making the lubing/flow situation even worse. The other compounding factor is that I can't just afford to pull the fan out and mess with it now that I depend on cabin circulation for window defrosting each day. If I break my fan some casual day, I may as well park my truck or pull an Ace Ventura.
    If somebody in this thread can find a way to modify these lousy fans to make them stop chirping/squeaking/ticking, I am willing to pay $200 for a fan that I do not have to F with any more.
    Is there anybody out there who has the time/resources/energy to work on something permanent for the rest of us? I believe that the successful individual would have some money to be made.
  10. Jan 9, 2011 at 6:52 AM
    #90
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Yes I feel an owner performed proper fix with of all the crazy ideas BEARINGS!!!!! is the way to go here.
    At least untill toyota corrects the fault, not just replace with another one.
    Subed for a non toyota fix..
    Go to it man, 2010 with 6000 miles mine just started.
    I do not wish to argue with advisors if they hear it or not and after doing a tsb replace with another one that will fail ( squeeeeek ) 3 months later.
    With a bonus of removed floormats and the gas pedal circumcision!
    We will overcome with skill and desire!!
  11. Jan 9, 2011 at 7:13 AM
    #91
    brow
    brow Well-Known Member
    Andy
    Minnesota
    2020 Dodge Ram 1500
    my "new" fan replaced with the TSB lasted a whopping three weeks, the squeek is back. I drive a minimum 100 miles a day, every day. There are not swear words that describe my level of frustration.
  12. Jan 9, 2011 at 2:50 PM
    #92
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    There is a special grease at my work that we use for -40C applications. I'll see if I can find the name and give it a try.
  13. Jan 9, 2011 at 3:15 PM
    #93
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    All,
    I've said this in numerous posts on this exact topic, the OEM fan Toyota uses is not made by Toyota or any of their subsidiary suppliers (Denso). The fan used in our trucks is manufactured by Delphi a parts manufacturer owned by GM. If you want a suitable cheap option, go wih the TYC manufactured fan sold on Amazon for $40. I installed mine a month ago and it's been good and we've had some frigid tempratures around this part of Va. The OEM fans are designed with a dry lube bearing and when the temps drop to freezing and below, the bearing squeals/chirps like no other. In the aftermarket fan option, the design is different. Taking apart and lubing the OEM Delphi fan is only a temporary solution and will come back due to it's inherent crappy design flaw. There is also a fan sold at Autozone for $100 made by Continental backed with a lifetime warranty. I'm not going to bother reposting the link to either part as I've done so in a bizzillion other threads on this topic. If you're interested in a fix for this issue; search "noisy AC fan" and you'll see the links.
  14. Jan 9, 2011 at 3:31 PM
    #94
    moe1967
    moe1967 Well-Known Member
    2010 TRD DC Off-Road PreRunner
    Going get my replacement fan motor this week. Service manager told me that it will take 1 hour. That sounds suspicious cause I could replace that thing in about 20 minutes. We'll see.
  15. Jan 9, 2011 at 6:18 PM
    #95
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I got my call last week for the new fan motor. Taking it in tomorrow or Tuesday
  16. Jan 10, 2011 at 5:51 PM
    #96
    LabradorBoy
    Canada
    09 DCab TRD Sport
    Thanks for the tip, I ordered the TYC fan today. I will be thoroughly inspecting the sucker before it is installed.
  17. Jan 10, 2011 at 6:40 PM
    #97
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Let me know how it works out. I took my original one apart several times. It was quiet for a little while, now it's back worse than ever. I think I let it go for too long before trying to fix it, and now it's beyond the fixable point.
  18. Jan 12, 2011 at 1:14 PM
    #98
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Sub'd for future info.
  19. Jan 12, 2011 at 1:22 PM
    #99
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
  20. Jan 12, 2011 at 4:14 PM
    #100
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    when i went to take mine out from under the glove box, 2 out of 3 of the shitty screws heads broke off... WTF. going in tuesday to have the dealer fix it under warranty as my truck only has 900 miles.
