Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Nov 11, 2013 at 7:26 PM
    #1101
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    giving this a bump as its that time of year.
  2. Nov 16, 2013 at 6:33 AM
    #1102
    stonecutter908
    stonecutter908 Member
    West Chester, PA
    95 Ext Cab v6
    My newly purchased 2011 has this issue.
    Annoying is not the word.
    First attempt at the fix, made it worse.
    I'll be revisiting this ...
    :popcorn:
  3. Nov 16, 2013 at 6:27 PM
    #1103
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Almost six months later and still no noise :D
  4. Dec 2, 2013 at 12:51 PM
    #1104
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    The chirp finally hit my last nerve so I got to this today. Thank you to all the photos posted & write ups. Really simple remove/reinstall of blower motor. Disassembly of blower motor is also straightforward. Hopefully the fine sanding, cleaning, & lube will be the fix. The chirp is gone right now. FWIW, I used AeroKroil spray penetrating oil.
  5. Dec 12, 2013 at 11:39 AM
    #1105
    Hookster
    Hookster Member
    Shannon
    TN
    08 PreRunner
    FINALLY the chirp is gone! Thanks for your post. This was driving me up the wall, so I followed your instructions and re installed the motor. There was a slight chirp when I first started the blower, but quickly disappeared. It's been a month now and all is well!
  6. Dec 12, 2013 at 6:43 PM
    #1106
    Chilli Taco
    Chilli Taco Senior Member
    NC
    2010 4x4 SR5 V6
    Toyota Front Bug Guard, Vent Shades, UWS Low profile Toolbox, Husky Floor Liners, Tacoma Rubber Bed Mat, 3 ball with tow hook trailer hitch, Nerf bars, EZ clamp on tailgate, overhead console with compass and temp, Transmission smoothness TSB, Rear 4 leaf spring pack TSB with 4 new Bilstein TRD shocks, Back up camera, JBS Keypad Entry, 2" blind spot safety mirrors, Leaf spring squeak TSB spacer discs,TSB AC/Heater Blower motor 04043, aFe Pro-Dry S Air Filter, Toytec AAL for TSB leafs, TSB redesigned headlights, GMC 5702KA Bulbs in DRL's, DRL switch mod, Illuminated 4x4 switch mod, 2010 4runner heated signal mirrors with puddle lights and 2013 Tacoma color matched mirror covers, bed lights, NOS GMC under hood reel light, TacomaWorld.com sticker on back window,fog lights on anytime mod, hidden ignition kill switch, TRD Skid plate painted black, TRD front recovery hook, console vault, Avid Off-road Light bar, 6" KC Daylighters
    Thanks for posting this fix! My 2010 has been doing this for about a year and it drives me crazy! I'll have to try this!
  7. Dec 13, 2013 at 3:23 PM
    #1107
    CreepyTm
    CreepyTm Well-Known Member
    Long Island, NY
    Bug Out Battle Truck
    Line-X'ed CBI Rock Sliders, Avid Light Bar, Flowmaster 10 series, Painted Grill and bumper, OKLED 20, 5100's with TSB and AAL, Bed mounted M240G
    2011 here...Dealer said, oh its just a leaf in the motor, It came back a week after the dealers fix. I checked here and finally did the lube fix on the bearings. So far so good. No clicks, ticks or chirps.
    On a side note, Once you drop the blower from the under-Dash housing, the interior lips of the blower housing are razor sharp so use caution while checking for debris that may have gotten past your filter......I didn't :(
  8. Dec 13, 2013 at 4:18 PM
    #1108
    hmcclung
    hmcclung Well-Known Member
    Heath
    St. Louis
    14 Superwhite S/C DCSB TRD OR
    I finally did this fix today and adjusted the two screws that balance the motor cover. I bought an 08 DCSB a few weeks ago and it made significant chirping originally. I disassembled everything like the OP and clean the bejesus out of everything. Sounds great for now! Hopefully continues. Thanks for the write up:thumbsup:
  9. Dec 13, 2013 at 4:26 PM
    #1109
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Toyota just installed the "new" upgraded (87103-04043)part in my truck. Outta 3/36K warranty. They paid for the part and I had to cover the labor. So I guess Toyota is pretty aware this is a ridiculously common problem. Only had it for a couple of days, but so far no more squeaky-squeaky. Hopefully it's cured for good, but at least I've got 12months/12K miles in case it comes back.
  10. Dec 13, 2013 at 4:30 PM
    #1110
    Tacoma Mike
    Southern Maine
    I have not heard of any issues with the 043 blower. You should not have any more problems. I had to change mine also. I was changing 2 a week at one point.
    jsanford likes this.
  11. Dec 19, 2013 at 12:07 PM
    #1111
    Chilli Taco
    NC
    2010 4x4 SR5 V6
    My update. After reading about the new upgraded blower motor they install as a fix part # 87103-04043. I called the parts department an the dealership here. The part cost $146.26 from them. I then searched online and found it a little cheaper. I have 45k miles so out of warranty but thought I'd take a chance and pull the TSB card with service manager. When I called he said well you have over 36k miles. It would be $336 installed. I told him for that price I could just get the part online and install myself. It only has 3 bolts holding it in. He said he would call corporate and see if he could help me with price. 3 hours later he said he could do job and my portion would be $66.50. I took it in today. Took them an hour. No more annoying noise!!!! :)
  12. Dec 19, 2013 at 2:31 PM
    #1112
    Chilli Taco
    NC
    2010 4x4 SR5 V6
    So for $66.50 I got the part and had it installed. That's cheaper than I could get the part only online! Glad I took the time to call before I just got the part and installed it myself!
  13. Jan 6, 2014 at 12:25 PM
    #1113
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
  14. Jan 6, 2014 at 12:30 PM
    #1114
    BennyTRD
    BennyTRD Active Member
    Sask, Canada
    '11 TRD Sport 4X4
    Going in Wednesday to get the new blower put it under warranty. I advised the service guy about the new blower part number so hopefully all this squeaking madness will be over.
  15. Jan 11, 2014 at 6:58 AM
    #1115
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    just had mine replaced 2 days ago by the dealer under warranty still. it was driving my crazy. it started as a small squeak/chirp about a year ago and finally in the last month it ticks nonstop. took my truck in, dealer had it about an hour and called me back and said they replaced the motor. no hassel. its really one of those things you don't even know how amazing a quiet fan motor is until you get one. I have a copy of the tsb paperwork if anyone needs a picture of it for some reason.
    ive read that the new motor will probably go bad in a year or so but whatever. it's quiet for now.
  16. Jan 11, 2014 at 1:47 PM
    #1116
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Cmurder,
    Can you tell if it is the new and improved motor and what the part # is?
  17. Jan 12, 2014 at 6:23 AM
    #1117
    Cmurder
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    i can take a pic of the paperwork tomorrow. after all my reading it is the motor with the model # ending in 43. i think i read sometime about a 43 being better or something? if you "think" your fan motor is making noise and annoying it's probably not bad yet. because when it's bad, its BAD! got mine done with no questions asked. just get it done before the 3yr/36000. it's amazing how a quiet fan motor can make me happy while driving.
  18. Jan 12, 2014 at 7:52 AM
    #1118
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    The motor with p/n ending in 043 is the new one. It has bearings instead of bushings. Hopefully it lasts longer than a year.
  19. Jan 12, 2014 at 10:35 AM
    #1119
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    My truck is a 2011 w 22k miles in it. It seems to be past the three year mark and I'm not sure I'd the dealer would replace the blower motor.
  20. Jan 12, 2014 at 1:26 PM
    #1120
    Nostunknivek
    Nostunknivek Well-Known Member
    Kevin
    Victoria, BC
    '09 TRD OR partially debadged
    Seat belt chime mod, weathertech floor liners, secondary air filter removal,
    I just took mine apart (old part number). greased the necessary bushings with lithium grease and whalaa. No more ticking/chirping. No sound. After a year and a half of listening to this sound it is gone. Thank you for the write up! I can now drive in peace.
