Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Jan 13, 2014 at 2:03 PM
    #1121
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
  2. Jan 13, 2014 at 2:06 PM
    #1122
    Cmurder
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
  3. Jan 24, 2014 at 9:32 AM
    #1123
    MJS
    MJS Well-Known Member
    Houston, TX
    2016 RAV-4 SE
    brutally stock
    Just pulled mine apart and greased. Got rid of the chirp but still has some click. May just be the sound of the brushes at this point.
  4. Jan 24, 2014 at 9:52 AM
    #1124
    BRUIN8124
    BRUIN8124 Well-Known Member
    Mark
    2020 TRD 4X4 OFF ROAD DCSB
    How much are they asking for the -043 p.n. blower motor? This thing is driving me nuts! I just may have to go pick one up. I wish I was still in warantee.
  5. Jan 24, 2014 at 11:28 AM
    #1125
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    anyone have a picture of the new design?
  6. Jan 25, 2014 at 6:35 PM
    #1126
    Valpo
    Valpo Well-Known Member
    Indiana
    2015 4x4
  7. Jan 27, 2014 at 10:42 AM
    #1127
    belone12
    belone12 Well-Known Member
    Brian
    Long Island, NY
    06 Tacoma Double Cab 6spd TRD OR
    Bilstein 5100s, AAL, heated leather seats, Thule Rack, tow package, anytime foglight, Fold-a-cover
    I am fnally getting around to this tonight. What is the preferred lubricant to "kill the canary" in the blower motor once and for all.....
    a) White Lithium Grease
    b) 10w30 Oil
    Thanks
  8. Jan 28, 2014 at 7:08 AM
    #1128
    belone12
    Brian
    Long Island, NY
    I feel like I have a new truck. Such a different experience without the cricket noise. Long overdue. Thanks OP for original post...
    Helpful tips:
    #1: I stripped one of the "two" screws in the attached picture pretty easily. I replaced them both with 1 inch M4-.7 screws that had a beefier philips head. If anyone else reads this, it may be worth doing in case this needs to be accessed 1x/2x a year to maintain. You need to have them pretty tight to prevent any wobbling/ticking of the fan.
    #2: I used a hair dryer to warm up the middle of the plastic fan blades where the shaft attaches. Then slowly worked it off by wedging 2 sockets under 1 side of the fan and using the back of the hammer to pull up on the other.
    #3: As somene else said, be careful when removing the magnets because they are spring loaded. Do it slowly and keep an eye on those suckers.
    #4: I used Blaster White Lithium Grease with the spray straw and a little help from some q-tips to lube the top and bottom bearings.
    #5: Cabin air filter was filled with dust/dirt/leaves/etc so I gave that a good cleaning temporarily until I can grab a new one.
    Night and day difference with the heat on last night in 16F weather. And no longer have to use the radio to compensate for the noise. Hope this post is helpful to someone as others were for me!
  9. Jan 29, 2014 at 6:27 PM
    #1129
    hmcclung
    hmcclung Well-Known Member
    Heath
    St. Louis
    14 Superwhite S/C DCSB TRD OR
    jsanford likes this.
  10. Jan 29, 2014 at 6:55 PM
    #1130
    60driver
    60driver Well-Known Member
    Sean
    CT
    10 DC TRD Sport 4x4 Tim Mica
    Illum 4x4 switch, 20" LED bar in lower grill, LED in scoop, aux fuse box, avid light bar and 'sliders'
    Nice, that is cheaper. Pending your review, I'll probably pull the trigger on it too. I couldn't tell by the site if it's the new blower or not. It says it replaces the new part #.
  11. Jan 29, 2014 at 8:00 PM
    #1131
    hmcclung
    Heath
    St. Louis
    Under product description it says:
    New, not remanufactured or rebuilt
    Includes blower motor fan cage impeller already installed
    Direct replacement
    Replaces dealer part numbers: 87103-04040, 87103-04043, 8710304040, 8710304043
    Built to strict quality control standards
    100% tested prior to leaving the factory
  12. Feb 1, 2014 at 1:40 PM
    #1132
    hmcclung
    Heath
    St. Louis
    Today I received and installed the new blower I ordered from AM-Autoparts for $54.45. And drumroll..... NO MORE NOISE!!!!!!
    It appears this is not an OEM Toyota part so the part number is different, but I took the covers off and it does appear to be closer to the -043 set up. I ordered it Jan 29 and received it Feb 1st. Here is the link to exactly what I ordered. http://www.am-autoparts.com/Toyota/Tacoma/blower-motor/AM-39122619/375230.html?gclid=CJ6v--fppLwCFa5DMgodRgsAsA
    Time will only tell how well it holds up. Here's a quick pic I snapped before the install too.
  13. Feb 2, 2014 at 9:52 AM
    #1133
    oh crap its him
    oh crap its him Well-Known Member
    Shannon
    OH->SLC,UT->SA,TX
    09 TRD OR
    Lift, Wheels, Lights
    I went ahead and got this ordered. My blower is ridiculous, its almost to the point of not being able to be drowned out by the stereo lol. Hoping this fixes it! Thanks for the link!
  14. Feb 2, 2014 at 10:46 AM
    #1134
    hmcclung
    Heath
    St. Louis
    That sounds exactly like my situation. I ran the blower all day yesterday as I ran errands and it made such a difference with the new one. Hope it fixes yours too!
  15. Feb 3, 2014 at 1:00 PM
    #1135
    fleafly
    fleafly New Member
    Jon
    El Paso, TX
    '11 Tacoma TRD Sport
    Hello, been lurking on the site since I bought a Tacoma last year and finally registered today to share my frustration with my damn blower chirp!! Rather than ripping apart the fan to grease up the bushings I decided to buy a new fan and found the newer model (4043) on Amazon today for $50.00! Hope this helps some of you all. I will post a review of this particular make as soon as I receive it and install.
    Guess it would help if I posted a link:
    http://www.amazon.com/dp/B009GXWZ9Q/ref=pe_385040_30332200_pe_309540_26725410_item
  16. Feb 8, 2014 at 1:57 PM
    #1136
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^FYI that is a Depo-brand aftermarket blower, not the Toyota 4043 unit. The Amazon listing states it's a compatible replacement for Toyota 4043. You may get the chirp in a couple of years. My TYC unit was quiet for the first two years, then it started chirping. I will replace it with OEM when it gets warm enough to work outside.
  17. Feb 8, 2014 at 4:23 PM
    #1137
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    Finally got around to installing the new blower motor (-04043). Old on left, new on right. No more annoying tick! Hopefully it stays that way. Tick was driving me crazy. Installation is pretty straightforward. Doable in 20-25 mins. Hardest part was pulling the plug from the old blower. Thought I was going to break it with the amount of force I was using. So for everyone else pulling it, don't worry too much if it feels like you're using too much force.
  18. Feb 8, 2014 at 4:31 PM
    #1138
    cjacob
    cjacob Well-Known Member
    Lafayette, La
    '05 PreRunner SR5 TRD
    Mine sounded pretty bad, but when I took it out I discovered that it had leaves in it and I was missing the cabin air filter. I bought a filter and cleared the debris. Chances are It wouldn't have made the sound now that it was clear, because it sounded like the leaves caused it. I went ahead and pulled it apart and lubed it anyways. It was nice and dirty, so it was a good decision. The motor is silent now, all for the price of some electronic cleaner and grease from the auto parts store. ~$10-$15
  19. Feb 9, 2014 at 7:58 AM
    #1139
    fleafly
    fleafly New Member
    Jon
    El Paso, TX
    Yeah, I'm aware it's not a toyota branded blower. Just figured it's the newer version of the blower. If it does chirp in 2 years, it was only 50 bucks. I guess we'd all take that chance even with the one toyota supplies. Just trying to help out someone that may be experiencing the chirp and doesn't want to take apart the fan or mess with the dealership. This one should be designed differently than the tyc since it is meant to replace the newer version of the fan (at least that is my hope). I'll update this once I receive it on Wednesday.
  20. Feb 11, 2014 at 7:28 AM
    #1140
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Please keep us posted on if the ( -04043) works or is just another POS.
    much appreciate it !!
