Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Mar 20, 2014 at 7:28 PM
    #1161
    MJS
    MJS Well-Known Member
    Houston, TX
    2016 RAV-4 SE
    brutally stock
    Did this, adjusted until the fan ran at the highest speed. It had the white lithium aerosol grease on it now. If the screw adjustment doesn't work with that, my last attempt will be wheel bearing grease.
    Crossing my fingers :cool:
  2. Mar 22, 2014 at 2:43 PM
    #1162
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    My TYC blower started chirping after about two years, so I ordered 87103-04043 from ToyotaPartSales (operated by Toyota of Dallas) for $109 + shipping. I also read about the resistor connector melting issue, so I ordered the improved Denso resistor 87138-04052 for $25 at the same time. Installed both yesterday.
    The -04043 blower is quiet and doesn't have the servo whine at higher speeds like the TYC blower (you can hear it in this video: https://www.youtube.com/watch?v=HC6mFt65f6k
    jsanford likes this.
  3. Apr 13, 2014 at 6:48 AM
    #1163
    LabradorBoy
    LabradorBoy Well-Known Member
    Canada
    09 DCab TRD Sport
    Just installed the -043 blower motor in my truck. Best $125 I've spent on my truck since I bought it. I stomped the old blower motor into smithereens once it was out. Felt great to be a gangsta (Office Space reference).
  4. Apr 14, 2014 at 3:46 PM
    #1164
    Edmonton Taco
    Edmonton Taco Member
    Brock
    Saskatoon, Sk
    WHITE 2010 TRD SPORT DBL CAB
    Mine has been squeaking for years now. Finally read most of the posts in this thread and decided to do something about it. I had intentions of getting the proper grease at the store and doing a full clean of the motor - but - I didn't have to do that at all (which is weirding me out lol).
    I basically took out the blower motor, hooked the power up to it and turned the switch on to low (the "squeak" setting), and sure enough the thing started to squeak after a few seconds in my hands. The sound would progressively get a little bit worse as the blower motor/fan was tilted/angled. Afterwards I "adjusted" those two small balancing screws located at the bottom of the blower motor while the blower motor was "on" - I noticed that as I would loosen one screw the fan would slow right down, and then would go faster again when I would tighten the same screw. I tried that with the other screw too and it did the same thing. I sat there and told myself "neat", and I hmm'ed and hah'd for a few more minutes. I have no idea what happened but the squeak stopped while did this, so I tightened the screws up again (not "crazy" tight, just snug tight) and I put the blower motor back into its proper place and put the covers back on and it's been quiet now for 2 days. Bliss!
    I fully expect it to squeak again but maybe I'll just mess around with those screws again to try and solve it.
  5. Apr 14, 2014 at 3:53 PM
    #1165
    Edmonton Taco
    Brock
    Saskatoon, Sk
    ...FYI, I also used a 7/32" socket to take off the 3 screws, and then a philips screwdriver to adjust the balancing screws - and since I'm a big guy and can't turn my head upside down, I used my iPad mini with the camera function on (and reversed) and placed it on the floor under the fan on the passenger side enabling me to get a great view of the underside of the glove compartment- this was VERY helpful in locating the placement of the screws with my thumb-fingers lol.
  6. Apr 14, 2014 at 3:56 PM
    #1166
    KenLyns
    Belly of the Beast
    Sucks to be in Canada eh? Would've been more satisfying to shoot it. :cool:
  7. Apr 28, 2014 at 9:36 PM
    #1167
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    great my grease only lasted about a month, squeek is now worse
  8. May 13, 2014 at 2:01 PM
    #1168
    crdillon
    crdillon Active Member
    Denver
    tacoma TRD Offroad 4.0l
    Hey all. So I am going to take my fan apart and I was thinking that a little anti cease might work better the grease or oil. I'll give it a shot and let you know.
  9. May 13, 2014 at 3:12 PM
    #1169
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    3 months with the new fan and no issues. Pretty much forgotten that it used to annoy the hell out of me.
  10. May 13, 2014 at 3:13 PM
    #1170
    crdillon
    Denver
    Nice did you just buy a new one from the dealership?
  11. May 14, 2014 at 11:15 AM
    #1171
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    I wouldn't. I tried the aftermarket fan route (AutoZone I think). Had it in about 2 weeks and couldn't stand it. It was worse than the chirp I had.
  12. May 14, 2014 at 2:32 PM
    #1172
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
  13. May 14, 2014 at 2:49 PM
    #1173
    DPC08
    FL
    09 DCSB
    Getting there...
    Bought it online through Camelback Toyota.
  14. May 14, 2014 at 7:02 PM
    #1174
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    I went this route too with a VDO fan from Autozone (with a lifetime warranty). The cage is smaller in diameter than the factory cage, so it makes more noise. So much so that it sounds like it's vibrating the dash on the HI setting when you're sitting still. On the road you don't notice it as much.
    Took me a few to get used to it, and I've stuck with it. At any sign of chirping, etc. it's going back. That's the reason why I went with aftermarket (easy warranty return) versus mail order (I didn't price a local OEM, figuring it would be pricey).
  15. May 14, 2014 at 8:42 PM
    #1175
    MJS
    Houston, TX
    2016 RAV-4 SE
    brutally stock
    Mine is driving me nuts again after multiple lubrication and screw adjustment attempts...I'll probably go with the updated OEM I think
  16. May 14, 2014 at 9:37 PM
    #1176
    DPC08
    FL
    09 DCSB
    Getting there...
    Completely worth it IMO if it drives you mad. Takes no time to install, and you'll be surprised how fast you forget that it was ever an issue.
  17. Sep 26, 2014 at 4:04 PM
    #1177
    little red
    little red Well-Known Member
    Central GA
    PreRunner SR5
    I performed this fix on my '06 three years ago and it never squeaked, chirped, or clicked again. My "11 I just bought was doing it the day I brought it home. Just finished fixing it today. After cleaning everything with CRC electrical spray cleaner, I used a few drops of high speed electric motor oil (kind of like the little cans of sewing machine oil) on the two brass bearings, then let them sit while I worked on smoothing the edges of the brushes with a jewelers file. Next I packed dielectric grease around the shaft next to the little cover that slides down over the brass bushings that I oiled previously. I hope I get several years of quiet fan motor with this truck now.
  18. Sep 26, 2014 at 4:17 PM
    #1178
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I applaud your tenacity but isn't it a shame Toyota doesn't address this long standing problem.
  19. Sep 26, 2014 at 4:32 PM
    #1179
    little red
    Central GA
    PreRunner SR5
    Yes it is my friend. Yes it is.
  20. Oct 3, 2014 at 7:27 PM
    #1180
    DRMetz
    DRMetz Well-Known Member
    Drew
    DMV
    05 PreRunner SR5 TRD Sport Rad Red
    Thank God for this post. I cleaned the internals with electronic cleaner, cleaned the internals, and let them dry. I picked up some WD-40 White Lithium Grease in the aerosol can and used the straw to hit the bearings. So far so good, no noises anymore!
