Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Nov 26, 2014 at 9:55 AM
    #1201
    senn4586
    senn4586 Well-Known Member
    Orange County
    05 PreRunner SR5 TRD Off Road
    Always on lighter output, Any Time On Fog lights, rear 12v outlet, 4 additional D-Rings, Plasti-Dipped Side Steps, Satoshi Color Matched Grill, Dash light swap, Dome light and map light, Under hood light, Back up light/Bed Light, Diff Breather relocation, Cubby Combo Lock, Ammo Cans Mounted in bed
  2. Dec 27, 2014 at 3:46 PM
    #1202
    Tacocoa Bean
    Tacocoa Bean Well-Known Member
    Justin
    Colorado
    14 Taco DCSB Off Road
    No significant mods....yet
    After only 10,000 mi, my fan on a 2014 taco was making a buzzing sound when I had it on high. However, it was below freezing temperature when I heard the annoying sound. I've heard that in colder temperatures, the bearings in the fan motor are more susceptible to making noise as the lubricant oil is more viscous and doesn't sufficiently cycle in the bearings or something. In warmer weather it appears to operate normally so far, so it's hard to know how to completely solve this noise.
  3. Dec 28, 2014 at 10:57 AM
    #1203
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    subd. I have to add the fan clicking noise to the growing list of annoying things my truck does. Nothing major just annoyances
  4. Dec 28, 2014 at 11:06 AM
    #1204
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Buy the updated motor. It's worth it.
  5. Dec 28, 2014 at 11:08 AM
    #1205
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Took mine apart, cleaned it up and applied corrosion block grease to the rotating shaft. No more noise! Thanks for the write up OP!
  6. Dec 28, 2014 at 12:20 PM
    #1206
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    Im going to try this out
  7. Dec 29, 2014 at 4:11 PM
    #1207
    Cstone
    Cstone New Member
    Colin
    Vancouver
    07 TRD White DC LB
    Having a hard time getting bearing back into the silver casing. Any pointers?
  8. Dec 29, 2014 at 4:34 PM
    #1208
    HB Taco
    Curt
    Put a drop of oil right where the shaft and bearing are (under the cap). That's as far as I wanted to go. So far so good. If it comes back I'll just get the new Fan Assembly.
  9. Jan 15, 2015 at 5:03 AM
    #1209
    Frogdaddy
    Frogdaddy Well-Known Member
    Ga.
    2010 PreRunner SR5 DC
    Pioneer MVH-p8200 hu with XM receiver using TSS supplied shark fin cable, Mud Flap cut mod.
    Sorry to resurrect this thread but in case anyone cares, I ordered the latest version (87103-04043 ) of the blower which looks considerably different. I crosschecked the other numbers on it and this appears to be it:
    http://www.xiuyanqipei.com/product/showproduct5859.html
    I got tired of lubricating it every winter and the most recent attempt I broke it. Sounded like a leaf blower.
    So far so good.
  10. Jan 18, 2015 at 8:15 PM
    #1210
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Wow, tons of info in this thread. Read all 61 pages over the weekend :)
    Bought a used 09 a month ago and blower has driven me nuts. After reading all this I removed today and noticed it's the 42 version. I'm guessing that means it probably got replaced under warranty (I'm second owner).
    I decided to just removed the motor cover and add about 6-7 drops of 3-1 oil. Put back in and it's quiet!! Woohoo.
    I guess I'll just wait and see. It only took 15 min so I may do 1-2 more times but after that I'll just drop the $125 and install the 43.
    Thanks all!
  11. Jan 19, 2015 at 1:27 AM
    #1211
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    So you didn't buy an oem blower? Did you buy it from that Chinese vendor directly?
  12. Feb 8, 2015 at 6:22 AM
    #1212
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    Update.
    Noise came back two weeks later. Bought the 43 from Amazon and installed.
    Noise gone. I'm happy. Thanks all.
  13. Feb 8, 2015 at 7:35 AM
    #1213
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  14. Feb 9, 2015 at 10:58 AM
    #1214
    Dick Proenneke
    Dick Proenneke Well-Known Member
    Edmonton, Alberta
    2013 TRD Sport 4X4
    OME 3" Lift with DAKAR'S, LR UCA'S, ECGS Bushing, Leer Cap, 18" Dick Cepek Torque', Duratracs, custom drive shaft, etc!
    I just talked to a parts guy at Mayfield Toyota in Edmonton, AB Canada, and he said they just got in a new blower motor in the last month. He refused to give the part number over the phone, which he eventually admitted, was so that I wouldn't buy it online somewhere. Price was $197 CDN. Does anyone know, if they have released a newer motor in the last couple of months?
  15. Feb 9, 2015 at 11:12 AM
    #1215
    BennyTRD
    BennyTRD Active Member
    Sask, Canada
    '11 TRD Sport 4X4
  16. Feb 9, 2015 at 8:27 PM
    #1216
    Dick Proenneke
    Edmonton, Alberta
    2013 TRD Sport 4X4
    I stopped in today after calling the dealership, and they said there is a new model after the 043. He spat the number at me, which I believe was 04404, 04044. Something like that. They are trying to decide if they are going to warranty my blower motor, since I bought the truck in the US, and want to get it Warrantied in Canada. Apparently the new motor is back ordered. My 2013 probably already had the 043, which ticks like crazy when its below -10 Degrees Celsius (Northern Alberta).
  17. Feb 9, 2015 at 8:47 PM
    #1217
    BennyTRD
    Sask, Canada
    '11 TRD Sport 4X4
    Well hopefully they do it for you. Been 2 winters since on the -43 series blower change and been working good for me (Northern Sask).
  18. Feb 10, 2015 at 7:34 PM
    #1218
    MJS
    MJS Well-Known Member
    Houston, TX
    2016 RAV-4 SE
    brutally stock
    I recently tried Tri-Flo on my old blower motor and it works pretty well...except for after very long trips when I presume the motor bearing gets warm, then it starts to quietly chirp. I would actually recommend the tri-flow for those trying to avoid buying the 043 motor.
    That said, I broke down and finally bought the 043 on Amazon and swapped it in today, because I don't event want to think about it again.
  19. Feb 10, 2015 at 8:30 PM
    #1219
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
  20. Feb 11, 2015 at 1:10 PM
    #1220
    Dick Proenneke
    Edmonton, Alberta
    2013 TRD Sport 4X4
    OK, so I just got back from Mayfield Toyota after they agreed to warranty my blower motor. They replaced it with part "#87103-04044" (Taken from my receipt), so I guess there has been a revision, or update after the 043 model. The new motor is quiet, and it's -15 today. Hopefully it works out.
    Looks like there are a few links for the new blower, sub-assembly, online:
    http://www.toyotapartszone.com/oem/toyota~motor~sub~assy~blow~87103-04044.html
    http://www.supertoyotaparts.com/oe-toyota/8710304044
