Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Jan 18, 2011 at 8:54 PM
    #121
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    I don't think it will work. It will not go in the bearing and it will not stay there I don't think even if it did. Can't say I've ever tried it though but I don't think it will work. That lube does not work well over the time the motor will run. Think of a key lock, a few seconds at most not hours.
  2. Jan 19, 2011 at 6:30 AM
    #122
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    As soon as I get it fixed, I will get the info posted.
    (Nice avatar maju!)
  3. Jan 19, 2011 at 1:52 PM
    #123
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Tightened the three bolts on the bottom of the black housing and it has stopped for now. We will see how long it lasts.:rolleyes:
  4. Jan 20, 2011 at 7:06 PM
    #124
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    I have had my 2010 for 6 months now, and the motor replaced twice. Definitely doing this next time. My local dealership is under par in my opinion.
  5. Jan 20, 2011 at 10:36 PM
    #125
    Badwin45
    Badwin45 Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    Trap is correct, there is a felt "washer" at either end of the motor housing. If you disassemble the motor, it's easy to lube the washers. I did mine tonight and hopefully that will take care of it for awhile.
  6. Jan 21, 2011 at 9:20 AM
    #126
    Trap
    Indego Ink TRD OR
    outnot bad for never even taking one apart, but that is usually how they work. The felt dries out then the motor starts acting up. If you let it go too long it will be chances are, to late. The bushing will have worn by then.
  7. Jan 21, 2011 at 10:35 AM
    #127
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    There should be nothing to dry out or lubricate. This should not be a maintenance item on a vehicle made at this period of vehicle evolution. This is a sourcing / design problem and Toyota needs to resolve it.
  8. Jan 21, 2011 at 11:28 AM
    #128
    Trap
    Indego Ink TRD OR
    The oil will not sit there forever. It gets consumed slowly over time. If it simply lasted forever that would indicate a lack of lubrication was taking place. All these small fractional Hp motors are they same if they have the felts installed. The recommended relube interval is one year. Even if it had sealed bearing this process would take place but at a slower rate. The only way to fix it is magnetic bearings.
    I'm not defending it's design just trying to convince you maybe to add this vital maintenance item to the yearly tasks.
  9. Jan 21, 2011 at 11:35 AM
    #129
    EvilBetty
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    Understand, and I am in no way arguing with you, only stating that this should not be needed in a modern vehicle. And at no time have I ever had the dealer ask me if I wanted to have my wiper blades replaced and my bower fan lubricated. No where have I seen any blower fan maintenance listed in any scheduled maintenance documents.
    So there is a fault. Fine. But Toyota's TSB use of the same motor with fast failure rates and continued use of the same system in new trucks is inexcusable.
  10. Jan 21, 2011 at 11:47 AM
    #130
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Mine is making so much noise now that I want to rip it out and throw it out the window.
  11. Jan 21, 2011 at 1:41 PM
    #131
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Just got mine replaced at Toyota of SB in California on my 05 Taco. No backorder on the part at all had them in stock. Hopefully, this lasts longer then a few months.
  12. Jan 21, 2011 at 10:19 PM
    #132
    blacksandtaco
    blacksandtaco Well-Known Member
    I'm either stupid or really stupid. I took my blower apart as I've already had it replaced once and I'm far out of my warranty now. Used some white lithium grease but I must not have been careful enough with it because now that I have it installed and back together my heater won't come on at all. I checked to make sure the wire was plugged all the way in and triple checked everything else. I keep blowing the 50amp FMX fuse under the hood. Any thoughts on why this is happening all of a sudden? Could grease have gotten on the wrong parts and caused this? Thinking back, grease may have gotten on the brass spooling on the motor and even down the spindle. Thoughts?
  13. Jan 22, 2011 at 7:58 AM
    #133
    RedYoter10
    RedYoter10 Well-Known Member
    Andrew
    Clifton, Maine
    10 4x4 access cab 2.7
    Bilstein 5100's, 265/75/16's, LCE header.
    I had an appointment this morning to get my blower motor "fixed".. I showed up, and they had another motor, but said they didn't have to "packing" which is supposed to be the solution. I have heard that the packing that they speak of is to silence the noise, but it doesn't seem to me as a fix for the problem, just covering it up!! Has anyone else heard of this? I think I'm gonna tackle it myself, since the dealer is dumber than bricks!!!!
  14. Jan 22, 2011 at 12:42 PM
    #134
    Boilerman
    Brian
    Chirp came back after one hour:mad::mad::mad:
  15. Jan 22, 2011 at 3:43 PM
    #135
    Hipster
    Hipster Nothing beats a Butter Shave..
    Tom
    Tucson
    '10 DC trd 4x4
    Billy's @ .85 w/ Eibachs front, TSB w/ 5100's rear + 1.5" AAL & shims, Debadged, Avid Bolt On Sliders, NFab Light Bar w/ (2) Lightforce 170's. Weathertechs, ATO bed bars.
    Installed my Amazon replacement today and the chirp is gone. Unfortunately, it is now a flutter at low speed that gets faster at medium and sounds like a mutha at high. I am at a point where I will gladly pay a $100 for the Autozone one. I'm going to try and return the Amazon one for a new one first.
    Love the truck, but I can't stand this issue...
    hip
  16. Jan 22, 2011 at 3:50 PM
    #136
    Infinus
    Infinus Well-Known Member
    Indiana
    08 Tacoma Double Cab SB TRD Sport
    My Autozone Continental branded one just came in. I'll post results once I get it in.
  17. Jan 22, 2011 at 4:00 PM
    #137
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    Waiting for this!!!!
  18. Jan 22, 2011 at 4:12 PM
    #138
    Infinus
    Indiana
    It'll most likely be tomorrow morning. I'll post some pictures and impressions.
  19. Jan 22, 2011 at 5:13 PM
    #139
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Everyone is waiting for a real solution that lasts. Keep us posted.
  20. Jan 23, 2011 at 6:45 AM
    #140
    Infinus
    Indiana
    Ugh.... ok guys, here you go.
    Here's the fan:
    I really wanted to take a look underneath the cap to see what I could see..... that's where I got a small let down:
    A nice TYC sticker and part number :mad:
    So basically Autozone is selling the TYC part at 2x the cost but they are slapping their lifetime warranty on it. I suppose this doesn't make me too mad. My previous TYC fan did last for an entire year before making any unusual noises, and I'll never have to pay for a new one again.
    Other pics:
    Trying to peer into the motor housing:
    I installed it and it was quieter then my previous TYC fan. It was also better balanced as my previous one had a slight rumble to it.
    Overall, I'm disappointed, but not upset. I like that I'll never have to spend money on it again thanks to Autozone's lifetime warranty. I dislike that I'll probably have to replace it every year or so, but maybe this thing will surprise me. My overall impressions of TYC vs Delphi are that the Delphi part is quieter, but either starts to tick or squeal pretty rapidly in the cold. The TYC part is a tad noiser however I never got any ticks or squeals out of it. My previous one I took out after a year because it started to simply get louder while on, but it never squealed or ticked.
