Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Dec 4, 2019 at 2:03 PM
    #1381
    DrFunker
    DrFunker Well-Known Member
    Are you good with electrical stuff?
    You may have luck looking to a parts place for the exact piece.
    But I wonder if Gunny can help you.
    He is the parts guy for Camelback Toyota.
    I am going to tag you in the thread for him.
    He works best with PMs.
    TRDSport10 and tigerag97[QUOTED] like this.
  2. Dec 4, 2019 at 2:07 PM
    #1382
    DrFunker
    @Blais03
    Any suggestions with this challenge?
  3. Dec 4, 2019 at 2:10 PM
    #1383
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    take it apart, grease the center pin, reassemble. should be good for a while.
  4. Dec 4, 2019 at 2:11 PM
    #1384
    DrFunker
    He needs to rewire the harness, I believe.
    You are the wire guy. :D
    edit: wiring master. :bowdown:
    Blais03[QUOTED] likes this.
  5. Dec 4, 2019 at 2:13 PM
    #1385
    Blais03
    Nick
    Easthampton MA
    guess I should have read more...
    should be an easy fix. Let me look into it .
  6. Dec 4, 2019 at 2:15 PM
    #1386
    DrFunker
    I did the same. :drunk:
  7. Dec 4, 2019 at 2:15 PM
    #1387
    Blais03
    Nick
    Easthampton MA
    Toyota dealer will be able to get you a new connector and some wires that go with it. cut and splice. I had a similar issue with my transmission speed sensor.
  8. Dec 4, 2019 at 2:16 PM
    #1388
    DrFunker
    That is what I thought as well. Cool.
    :cheers:
    tigerag97 likes this.
  9. Dec 4, 2019 at 2:42 PM
    #1389
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Is this the connector to the blower or to the resistor? The latter is more common to see burned in earlier trucks (because the GM-supplied connector fit poorly).
    DrFunker likes this.
  10. Dec 4, 2019 at 4:35 PM
    #1390
    tigerag97
    tigerag97 Member
    2006 Silver Tacoma Double Cab
    That would be the blower connector.
  11. Dec 4, 2019 at 5:05 PM
    #1391
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Go to the dealer. Toyota's public online catalog doesn't have this part.
    Alternatively just crimp on two insulated spade terminals to the wires, since the pins on the blower are simple:
  12. May 4, 2020 at 2:40 PM
    #1392
    Twitch81
    Twitch81 Well-Known Member
    2019 Double cab Taco 4x4
    Well, after more than year, my chirp is back. Will be redoing it again soon.
  13. May 16, 2020 at 10:43 PM
    #1393
    jrowe4321
    jrowe4321 Well-Known Member
    Justin
    Los Angeles
    09 prerunner access cab
    Didn't have any grease, but giving the inside a good ol compressed air cleaning has taken away my squeak for 2+ years
  14. Jan 22, 2021 at 10:52 AM
    #1394
    SurviveToRide
    SurviveToRide Lover of anything on wheels
    Elijah
    2009 Access Cab V6 6MT TRD Sport
    17" TRD Pro Wheels 265/70/17 A/T’s Jason Topper
    What grease are you guys using for this?
  15. Mar 18, 2021 at 9:34 AM
    #1395
    Fosterlr
    Fosterlr Well-Known Member
    Mancos, CO
    2013 TRD Off-Road
    Is there a TSB for the blower motor chirp for my 2013? I'm under warranty and I'd like to get this dealt with, what an annoying sound!
  16. Mar 18, 2021 at 11:02 AM
    #1396
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    I think they replace the motor under warranty, give them a call. There's supposedly an updated motor that people say work better, not sure. Make sure it's squeaking when you bring it in.
  17. Mar 24, 2021 at 2:41 PM
    #1397
    Fosterlr
    Mancos, CO
    2013 TRD Off-Road
    Mine was chirping terribly, mostly on medium fan speeds. Under warranty so took it in to the shop - they found some debris and a cracked cage on the assembly. New one installed - blissfully quiet for the snowy commute this morning. Hope it lasts!
  18. Mar 24, 2021 at 2:42 PM
    #1398
    Fosterlr
    Mancos, CO
    2013 TRD Off-Road
    They covered it under warranty, but bill was only $259 regardless, for a whole new blower motor assembly, not terrible
  19. Dec 14, 2021 at 1:08 PM
    #1399
    VikingTrad3r
    VikingTrad3r Well-Known Member
    "contractor model" white with black fenders
    Can we get a confirmation from anyone that the most recent 044 will eventually start squealing again or have there been no failures?
    my local dealer in calgary canada has the 044 available and im happy to pay the price if the squeal has been eradicated.
