Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Jan 23, 2011 at 7:20 AM
    #141
    Rhino8541
    Rhino8541 I like ze best!
    WA
    2017 QS DCSB OR
    That is kind of disappointing, would you do it again knowing the price, and that it's still a TYC part? I've been waiting to drop the cash, because I've tried fixing my fan multiple times, and it just keeps getting worse. I think I would rather have it replaced yearly, than try to take it apart and fix another fan.
  2. Jan 23, 2011 at 7:24 AM
    #142
    Infinus
    Infinus Well-Known Member
    Indiana
    08 Tacoma Double Cab SB TRD Sport
    I was thinking about that, and I think I would. Knowing that these face possible future replacement..... I do like that I'll never, EVER have to spend money on this issue again.
  3. Jan 23, 2011 at 7:32 AM
    #143
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Pics are really clear. Great job ! Too bad the only solution is to keep replacing it even if it is on their dime after the 2X $ on the part. Maybe you could take some pics of the steps swapping it out next time - make it easy for every ones yearly fan exchange.
  4. Jan 23, 2011 at 7:36 AM
    #144
    Infinus
    Indiana
    I could try to do that at some point. It's really easy.... 3 screws to remove, pull the fan, swap the plug, re-insert. 5 minute job for the most part.
    The TYC part should be even easier to replace because the socket for the connector doesn't have the piece that lets it snap and lock into place. It's still held in there firmly but the locking part on that connector was a real pain. I've about destroyed mine trying to get it out of the Delphi part. If you did it once you'd know what I'm talking about.
  5. Jan 23, 2011 at 7:43 AM
    #145
    Rhino8541
    WA
    2017 QS DCSB OR
    I know exactly what you mean by that clip. I thought I was gonna tear mine up a few times. Thanks for the input. I think I will order the autozone part, I don't want to drop the money, but that thing is aggravating!!
    Well I ordered the Autozone fan, here's to hoping it all works out!
  6. Jan 23, 2011 at 10:19 AM
    #146
    Infinus
    Indiana
    I just bought a roll of Dynomat. If I can make this TYC part as quiet as stock I'll be pretty happy.
  7. Jan 23, 2011 at 10:20 AM
    #147
    Rhino8541
    WA
    2017 QS DCSB OR
    Nice, are you gonna insulate inside the unit itself?
  8. Jan 23, 2011 at 12:58 PM
    #148
    Infinus
    Indiana
    Ok, finished with the dynomat....
    Here are some more pics.
    These are the screws you back out to remove the fan, one of them is just off the photo:
    Here is a view of everything with the glove box out and the cabin air filter removed from it's slot:
    This is looking up into the empty fan housing:
    And here, I know you all will laugh at this, is my GHETTO dynomat solution. I didn't want to put the dynomat inside the fan housing out of fear of it one day interfering with the fan blades. My only goal was to put the dynomat between me and the fan. Since it's out of sight, I didn't care at all about how it looked. I also have a great distrust of adhesives in the warm car so I wanted it to be held in place by something other then just the dynomat adhesive. So I fashioned some support out of zip ties. I know, it's REALLY GHETTO. But IT WORKS! and that's really all I care about since I can't see it. This has quieted the fan down enough that I'll run this TYC part until it gives out, and then just go to Autozone and get another..... so, onto the ghetto pic:
    It'll work, it'll stay in place, that's all I care about.
    I also put a piece of dynomat on the back side of the glove box. The fan is as quiet as the stock unit with the dynomat in place, and the TYC doesn't seem to develop crickets like the stock fan, so I'm happy for now.
    Hopefully all the pics are ok for you all. I took them, resized them, and edited them all on my Iphone so it's not professional by any means.
  9. Jan 23, 2011 at 2:02 PM
    #149
    h2o's taco
    h2o's taco Active Member
    Kurtis
    Sacramento
    2010 Tacoma TRD off road 4X4
    Undercover tonneau cover, Westin side steps w/ Line X coating, MANY more to come.
    I had mine replaced with the warranty six months after I got the truck. I was initially told to ignore it. I had to argue with the service manager and threatened to go to another dealership before he said he would replace it. I am not looking forward to taking it back to the dealership since it has started to chirp again.
    I guess since it isn't anything that puts the occupants at risk, like the accelerator petal, Toyota doesn't want to pay for another recall.
  10. Jan 23, 2011 at 6:22 PM
    #150
    george3
    New Jersey
    Thanks for your time and effort. I'm impress with the results from the iphone - would have thought it was a camera.
  11. Jan 25, 2011 at 3:01 PM
    #151
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    I have been reading about the problems with the fan blower motor,
    Is the motor getting hot when its running on low speed?
    What gauge is the wiring to the motor?
    I am guessing it could be a current problem with the motor, the low speed goes thru a resistor.
    If I had this problem I would rewire it from the resistor with a full copper heavy gauge wire.
    I am only guessing, but your noise problem could be from raised comm bars, as the comm heats up the comm bars raise uneven, but I am only guessing, but a sure signal is if the motor feels very hot, also a hot motor will simply evaporate the grease or oil you may have coated the end cap bushings with, a good quailty full synthetic grease won't melt when hot.
    My Tacoma is a new 2011, only 500 miles,, and I hope I never have this problem, but if I did I would conduct a current test, a frame ground test with a votage drop test, and a paracitic test.
    Your problem could be electrical
  12. Jan 25, 2011 at 5:19 PM
    #152
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Give it time, you will... :D
  13. Jan 25, 2011 at 11:23 PM
    #153
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Bartstar:
    No the motor is just a POS. They should have used a brushless DC motor with real bearings. Proven technology. It would still screw up eventually but around the 7 year mark. For instance I have one running here now for 7 years now continuous and it's still running and it's not making any noise. I've cleaned it about once every 6 months but it's also running filtered air so it don't really get very dirty anyway. That's running 24/7. In a truck it would never run like that. That would be like a 40 year life in a truck. Damn engineers don't know shit about anything. Should have asked a electrician. That's why I get ticked off when the think they know everything and there god or something. Could learn a few tricks from people that actually work on this shit and not just read about it in a fucking book somewhere. End Rant ! Price difference? I don't think there is one and if there is it's minor. I think the other motor is actually cheaper cause it's just way more common now days.
  14. Jan 26, 2011 at 1:35 AM
    #154
    BartStar
    pa
    you're saying its just a cheap, generic fan motor, OK I will accept that, maybe a creative member of this forum can adapt fan motor from a Chevy truck into the Tacoma?
    I can remember back in the 1990's I owned an old 1978 Ford F150 with 156K miles and my fan motor went bad, it just quit, went to Napa Auto Parts and they asked me if I wanted the standard or the heavy duty fan motor, took the heavy duty and it sounded like a freight train and the volume of air that it pushed out felt like a tornado, is it possible that maybe some auto parts retailer has maybe another style or heavy duty one? Maybe the fan motor from a Toyota Camray, or Lexus might work?
    You could find a different one that works and perhaps drill different mounting holes, and or design, or make or machine a metal mounting plate to fit the fan motor.
    I have a friend at a auto parts warehouse that stocks every part there is, he is an expert knowing that different car makes use the same electrical parts.
    Thats what i'm thinking about I am sure the same manufacture is making the same fan motor for Toyota, Ford, Dodge, Kia and so on, and why don't they have problems when Toyota does, so you have to look at the Toyota electrical engineering design, the mounting and so on and see whats different, you have to think like an engineer to understand why they wired it up and mounted it that way.
  15. Jan 26, 2011 at 1:46 AM
    #155
    Snoyota
    Snoyota Well-Known Member
    Taylor
    Marin County, CA
    07 Black Dbl Cab Sport
    3" King coilovers with resi, king rear shocks with resi, ome dakar leafs, 4xinnovation kickout sliders, CBI front bumper, warn M8000 winch K&N filter. Pioneer deckplate with 500w alpine amp and 13" Focal Sub
    Im doin this tomorrow
  16. Jan 26, 2011 at 2:38 AM
    #156
    Trap
    Indego Ink TRD OR
    Unfortunately it's the same damn POS motor. I've noticed some cars have the brushelss DC fan motor installed. That's what we need we need somebody that can try to source a much better motor replacement.. All the ones that are known so far are already listed on this thread. There is also a possibility just the motor part can be replaced with a much better one. Like reuse the plastic parts. That would make the potential field of machines much larger. If you figure out something or find something that works better let us know on this thread.
  17. Jan 26, 2011 at 9:45 AM
    #157
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Just made an appointment to take my truck in. I'll let the dealership replace the damn thing - though I'm sure it will happen again.
    I reached my hand in and spun the fan blade. It chirps at one particular point in the rotation. It's very annoying but I don't want to get into disassembling the fan when I know warranty will take care of it.
    Truck is only 2 years old so I'm sure it will happen again.
  18. Jan 26, 2011 at 3:32 PM
    #158
    Rhino8541
    WA
    2017 QS DCSB OR
    My autozone replacement fan should be here tomorrow. I hope it is a worthwhile solution.
  19. Jan 26, 2011 at 3:38 PM
    #159
    BRMTaco
    BRMTaco New Member
    Moncton, New Brunswick
    2010 TRD Taco
    Brand spankin new
    I just bought my truck a month ago and its already doing it especially in this cold weather. I do notice if you run it at high for awhile then return to low it goes away then comes and goes. I believe from reading all posts that its a lubrication issue and poor overall design IE cheap
  20. Jan 27, 2011 at 2:09 AM
    #160
    Infinus
    Indiana
    I can't imagine that choice on the fan used was an engineering decision (gotta protect my fellow engineers). Honestly it was probably an executive decision based on some cost study.
