Blower motor started to only blow on low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maykevin5, Jun 9, 2015.
  1. Jun 9, 2015 at 6:05 AM
    maykevin5
    maykevin5 [OP] Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    I have a 2012 Tacoma and yesterday i noticed my HVAC blower motor only spins low speed. Switching the speed to med or high has no effect. The only way i can get it to work is turn the speed switch to off then on sometimes more than once. I don't think it is the resistors because it should work on high if it were bad. I don't think it's the speed switch because high current doesn't run through the speed switch. I'm thinking its the HVAC blower relay not making good contact. Any thoughts?
  2. Jun 9, 2015 at 6:12 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I know there is a TSB out for this for the 05-11 trucks "Broken Fan Speed Control" where it does exactly what you are talking about. If you are still within warranty I would recommend a trip to the dealer.
    The TSB for the 05-11 trucks is T-SB-0149-11. Maybe that can give you a good direction to go.
  3. Jun 9, 2015 at 8:45 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Seems there have been quite a few threads like this lately. I would first check the cabin air filter and the squirrel cage in that area. Lots of yack about that already. Here's the PDF for the TSB
  4. Jun 9, 2015 at 8:54 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    i pulled the controller out and sure enough the main power wire going into the switch is burnt. I checked with the dealer about just getting the switch but it comes as a whole unit.$700 also can't get just the connector. If anyone has a blower switch let me know.. thanks.
    Same problem this guy is having https://www.tacomaworld.com/threads/wire-connector-help.377189/
  5. Jun 9, 2015 at 9:34 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    Unfortunately that is not my issue. I've checked the resistor. Definitely the switch.
  6. Jun 9, 2015 at 9:46 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    This is what it looks like. Everyone may want to check to see if your's is doing it to.
  7. Jun 9, 2015 at 9:50 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Nasty, if you bought it new take it to the dealer.
  8. Jun 9, 2015 at 9:53 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    Out of warranty.
  9. Jun 9, 2015 at 9:55 AM
    Robnik
    Rob
    Greenacres, Florida
    That sucks, they might still do something for you. Looks like a loose connection from the factory.
  10. Jun 9, 2015 at 9:58 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    apparently you haven't had the pleasure dealing with Toyota service....
    Lester Lugnut likes this.
  11. Jun 9, 2015 at 10:04 AM
    Robnik
    Rob
    Greenacres, Florida
    Oh yeah I have, I used to work there. Depends on the dealer & their "service advisors". But, I know what you're saying. :)
  12. Jun 9, 2015 at 10:21 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Check some auto salvage yards for the part online.....
  13. Jun 9, 2015 at 10:27 AM
    IPNPULZ
    going to be fun!
    Is that a 2 or 3 knob control or is it the whole trim style with the knobs built in?
  14. Jun 9, 2015 at 10:33 AM
    IPNPULZ
    going to be fun!
  15. Jun 9, 2015 at 10:34 AM
    NiteTaco
    NiteTaco Well-Known Member
    North Alabama
    09 TRD DCSB
    I assume no extended warranty? I had to argue a little, but got the TSB done on my 09 about a year ago and they covered it under the extended. There's also a write up somewhere on here on doing it yourself with a matching GM/Chevy plug that was cheaper IIRC. Good luck!!!
  16. Jun 9, 2015 at 10:42 AM
    Robnik
    Rob
    Greenacres, Florida
    Kevin, I just looked at mine since I was doing something else. White as undriven snow. If the blade (male end) is burnt to a crisp, go to a junk yard & redo the wiring harness.
  17. Jun 9, 2015 at 11:26 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    I have a 2012. controls are different from the 2011 ebay link above. The spade terminal is in the controls and i've cleaned that up but the connector on the harness is what i'm looking for.
  18. Jun 9, 2015 at 11:36 AM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    does anyone know where i can get these metal pins? I've ordered a used 2013 control unit. Its the same as the 2012 for $79 Thought that's a heck of a deal considering toyota quoted me $700 for it.
  19. Jun 9, 2015 at 11:58 AM
    Robnik
    Rob
    Greenacres, Florida
    Did you pull it out of the harness? Post a pic. I gotta see this :D.
  20. Jun 9, 2015 at 12:05 PM
    maykevin5
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    here is a good pin.
