Blower motor!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GJanes, Jun 21, 2025.
  1. Jun 21, 2025 at 9:43 PM
    GJanes
    GJanes [OP] New Member
    2009 Tacoma TRD
    ICON stage 10 suspension systemBody, Armor front bumper,Custom high clearance rear bumper,Trail Gear rock sliders, SpecD headlights, 4.56 nitro Re Gear, added pod lights and light bar and new sound system.
    My AC system went out, didn’t know what happened. I replaced the blower motor and that didn’t work, replaced the resistor, that didn’t work. I checked all the fuses nothings blown they all tested good. I then ohmed the whole system when it’s unplugged from the blower motor it is perfect, wash fan setting increases voltage how it’s supposed to. Then I plug the the pigtail into the motor and the pigtail ohmes with zero voltage going to the blower and the ac light won’t turn on and the compressor quits working. But as soon as I take the pigtail out of the motor the ac compressor works and the light comes on. Heater won’t work either if pigtail is plugged in but when it’s out then the system heats. I NEED HELP BADDDD
  2. Jun 21, 2025 at 10:01 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You have a voltage drop in the circuit somewhere.
    Backprobe the connector at the blower motor with it plugged in and turned on, check the Power (Pin 2 (Black/Yellow)) & Ground (Pin 1 (White/Blue)) and see which one is missing so we know which side of the circuit we need to go after.
    T4R_hereforbearings likes this.
  3. Jun 21, 2025 at 10:22 PM
    GJanes
    2009 Tacoma TRD
    I will try this tomorrow and respond with the result for either the ground or the power
