Blower on '07 Intermittently Stops working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1Biggerwoody, Nov 30, 2022.
  1. Nov 30, 2022 at 9:17 AM
    1Biggerwoody
    1Biggerwoody [OP] Better to be a Smart Ass than a Dumb Ass
    Montie
    Winter-Peg, Manitoba, Canada
    07 TRD Sport Double Cab
    The fan on my Tacoma randomly stops working. If I hit a bump sometimes it will go back on or if I shut it off and turn it back on, the fan randomly works again.
    From what I read it is likely the blower motor and/or the motor resistor
    I thought I read somewhere that a new motor might draw too much and cause the resistor to fail prematurely.
    I was wondering if it's easier to just replace the blower motor and resistor at the same time even if they both don't need replacement.
    Any thoughts?
    Cheers
  2. Nov 30, 2022 at 9:19 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Nov 30, 2022 at 9:20 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I am having a similar issue. It is likely the resistor or the harness going to the resistor. here are the updated part #s for the harness and resistor.
    resistor 87138-04070
    Harness 82141-04Q80
    1Biggerwoody[OP] likes this.
  4. Nov 30, 2022 at 9:23 AM
    Clearwater Bill
    Billy
    Largo Florida
    Check resistor and harness as others have said. 98.2% chance that's the problem.
    You can drop the blower and make sure nothing is binding the wheel (like an acorn) then moving. Easy, costs nothing, you're there when replacing the wiring you're gonna find bad anyway. :D
  5. Nov 30, 2022 at 9:33 AM
    1Biggerwoody
    Montie
    Thanks guys - I will take it apart and go from there - it's -27 C out and no garage so I am trying to limit the amount I am outside lol
