Blower Only Works on High
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gold910, Nov 8, 2020.
  1. Nov 8, 2020 at 1:38 PM
    gold910
    gold910 [OP] New Member
    William
    2015 Silver TRD Sport
    I know this is a common problem with Tachomas so it isn’t a surprise that it happened to mine.
    My blower only works on high. I replaced the resistor but it didn’t come with any additional wiring connectors. When I tried it after the repair the problem was still there - blower only worked on high.
    What’s the next step in troubleshooting?
  2. Nov 8, 2020 at 2:22 PM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    I had the same problem and replaced both the resistor and the connector. There was a burnt mark on my connector. Good luck.
  3. Nov 8, 2020 at 3:28 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Check the connector at the blower. That was my issue. Mine had melted some that I couldn't re-use the male connector. I bought thin blade connectors and spliced the wires directly into the female connector. My new issue is #3 power setting does not work - this turns out to be the connector to the resister. I cleaned it and worked for a couple of months and the #3 setting has stopped working again. Think if doing what I did to the blower connector.
  4. Nov 8, 2020 at 4:46 PM
    chop
    chop Well-Known Member
    byron
    British Columbia
    08 Tacoma 4x4 dclb TRD Sport 4.0L
    3"lift , arb front bumper,ome 886 coils, icon xrt leafs goodyear duratraxs firestone air bags
    Just fix mine again today, about every 9 months. Took off connector clean down inside the burnt one ( centre one). Put in di- electric grease. Slap it back together, all good
  5. Nov 9, 2020 at 5:54 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    o_O:annoyed: "di" in this case means does not conduct electricity.
    Jimmyh likes this.
  6. Nov 9, 2020 at 5:57 AM
    DG92071
    DG92071 Well-Known Member
    Spend the $20 on Amazon and get a new resistor block and the new plug that comes with it.
