blower whistle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by graywolf2011, Nov 9, 2011.
  1. Nov 9, 2011 at 6:07 AM
    graywolf2011
    graywolf2011 [OP] Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    I have a 2011 Taco, DC, TRD OR, 4X4. Love the truck, not my first Taco. Anyhow, the blower on low whistles(truck is so quiet you can hear a mouse fart:eek:). Doesn't matter whether it is on fresh or recirculate(louder on rec). You can hear it best on low. Not sure what would cause this, not the motor, sounds more like a flap/door not closing completely inside the HVAC system. Any ideas?
  2. Nov 9, 2011 at 6:10 AM
    CrAiG
    CrAiG Well-Known Member
    Tacoma889
    2010 toyota tacoma TRD
    Three inch spacer lift
    I just took the blower off and lubed the bearings haven't had a problem sence
  3. Nov 9, 2011 at 6:14 AM
    CrAiG
    Tacoma889
  4. Nov 9, 2011 at 6:15 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    whistle tip
  5. Nov 9, 2011 at 6:16 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    lol mine does it so bad it drives me fucking crazy lol i have to get it fixed!
    i had it at toyota on 3 separate occasions now and they swear they never heard of the problem before and they can't reproduce it when it 's there wtf lol the minute i drive away it starts :mad:
  6. Nov 9, 2011 at 6:25 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    There's a TSB for the blower chirp. Print it out and go to your Toyota dealer. I had mine replaced with the new redesigned TSB one at no charge about 2 months ago on my 2009.
  7. Nov 9, 2011 at 6:27 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Copy of the new revised tsb for the blower motor chirp. Mine does it on all settings all the way up to high.
  8. Nov 9, 2011 at 7:14 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    If you have problems call corporate
  9. Nov 9, 2011 at 7:52 AM
    graywolf2011
    Orlando Florida
    11 Tacoma 4X4
    Thanks for the input, I'll take it to the stealer and see what they say:cool:
  10. Nov 9, 2011 at 7:56 AM
    4Wheelin4Banger
    Randy
  11. Nov 10, 2011 at 6:06 AM
    graywolf2011
    Orlando Florida
    11 Tacoma 4X4
    I went to the stealer yesterday, they replaced the motor and the noise is still there.:mad: As I stated in my original post, it sounds like a whistle, wind going past a small crack, like a door or flap is not closed all the way. I will go back to stealer today or Friday.:argue:
  12. Nov 10, 2011 at 6:22 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just wait a while...Mine eventually went away at around 50k miles. It hasn't chirped since.
  13. Nov 10, 2011 at 1:52 PM
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    Back over 50 years ago the rage was engine swaps, you never knew what pulled up alongside you at the lights.
    My first car was a '50 Chev hardtop. The first thing I did to it was to stuff a '54 Olds V-8 into it. While it was fast, it wasn't 'that' fast. There were some '57 Chevys, some 'vettes, and surprisingly, the '57 Rambler Rebels could occasionally beat me.
    Well I soldered a couple Captain Crunch whistles to the fan blade. In those days the fan was belt-driven and spun all the time the engine was running. Those whistles sounded just like a McCullough 'blower' (supercharger) with the whine/whistling up and down with the RPM's.
    Bluffed my way through a lot of drags. ;->
    Years later I was able to afford a Latham blower with the 4 Weber side-draft carbs.
    Whit
  14. Nov 10, 2011 at 2:00 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I'd have a mechanic ride around the block with ya. If that doesn't work you're probably just nuts :p
