Blower
Discussion in '2nd Gen. Tacomas (2005-2015)' started by macanic, Mar 11, 2013.
  1. Mar 11, 2013 at 5:00 AM
    macanic
    macanic [OP] Member
    JERRY
    LOWER ALABAMA
    2009 PRERUNNER
    Thinking about a blower on my Tacoma, or would a "performance chip" pep it up any at all. 2.7 4 cylinder, talk to me.
    Recommendations, but keep it real. :cool:
  2. Mar 11, 2013 at 5:06 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    I don't know if they make a SC for the 2.7 but if they do go for that, hands down.
  3. Mar 11, 2013 at 11:28 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Underdog Racing Developement has a SC for the 2.7l. IIRC it's around 3k, all inclusive.
  4. Mar 11, 2013 at 11:31 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
  5. Mar 11, 2013 at 3:39 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I'm on the fence on the URD SC. I like it, but they did data with catylitics out. I actually am more interested in one that passes Oregon's DEQ, with the catas. I'm also interested in a more sedate 40-60 hp or tq gain.. moderate power. More is ok, but I'm also interested in knowing its low maintenance and something I dont need to tweak here n there.
  6. Apr 22, 2015 at 6:02 AM
    wyomingray
    wyomingray New Member
    2010 4wd 4.0 automatic
    I have a 2010 4.0. Before installing a supercharger, I need to know if I can drive it to the dealer to have it reflashed. It's 100 miles to the nearest dealership. They tell me not to even start it without reflashing. How do I do that?
  7. Apr 22, 2015 at 10:39 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    you might be able to remove the ECU and send it in to be reflashed?
    timing will be way off and it will probably seize up if you try and start it, guaranteed to blow up if you drive it.
  8. Apr 22, 2015 at 10:42 AM
    Gearheadesw
    Gearheadesw Well-Known Member
    Davenport Fl
    2016 GMC 2500hd
    some
    What? how far does the flash adjust the timing? Retard the timing so the SC doesn't overfill the combustion chamber, yes.
  9. Apr 22, 2015 at 3:38 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    My brother has URD SC on his 2.7L. With their stage 1 kit, you leave the cat on, but with the stage 2 kit, apparently it is recommended to cut out the cat. It is all inclusive, but I have to say that URD lacks in customer service. It took almost 3 months for him to receive his kit after it was paid for.
    When it finally arrived, it was only a stage 1 when it was suppose to be a stage 2. After it was all said and done, it extra hp and trq will put a smile on your face. Their big HKS blow-off valve does make an annoying swoosh sound between shifts, but I guess you can get used it after a while.
