Blowing fuse on new fog lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sg5845, Jul 24, 2012.
  1. Jul 24, 2012 at 7:06 AM
    Sg5845
    Sg5845 [OP] Well-Known Member
    Atlanta, GA
    2008 Tacoma TRD OffRoad Edition
    I installed new fogs in my father in laws 2012 Taco base model and wired the 12V supply to the hot on the low beam headlights so that he can't leave them on (i.e. they only can be on when he has the headlights switched on).
    Unfortunately it works for about 10 seconds and then blows the 10 amp headlight fuse for the headlight it is wired to. Is this just a no-no? Are the fogs drawing too much power for the 10 amp fuse?
    I have a 2010 Taco with the fogs built in and this is how they are factory wired so just looking for help.
    Thanks much!
  2. Jul 24, 2012 at 7:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Your factory fogs do not take power from the low beams, they are on their own circuit and have their own fuse, siwtch and relay.
    You need to install a relay, have the low beam trigger the relay and have the fogs draw their own fused power from the battery or an add-a-circuit. You are blowing a fuse because you've overloaded the circuit for the headlights.
  3. Jul 24, 2012 at 7:21 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    ^ what he said
  4. Jul 24, 2012 at 7:48 AM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    Ditto
    You need a relay (small solenoid). In your case the relay would be switched by the hot low beam headlight.
  5. Jul 24, 2012 at 9:47 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Here's a link to how I installed my fogs. They are wired into the parking lights so they come on when ever I have on my parking lights, low beams or migh beams.
    My Auto OEM Fog Light Mod
