Blowing Fuses (Parking lights, tail lights not working)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MotoXFreeStyle61, Oct 19, 2008.
  1. Oct 19, 2008 at 7:48 PM
    MotoXFreeStyle61
    MotoXFreeStyle61 [OP] Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    While I was driving home tonight, I noticed that my AC panel was not lit up, then I also noticed that my parking lights were not working as well. When I finally got home I discovered that my tail lights did not work when I had my head lights on but worked when I pushed the brake. I got under the panel and checked the fuses and low and behold the 10AMP fuse for the tail light was burnt out. I got a spare fuse and put a new one in and when I turned my parking lights on it blew the fuse once again. I haven't done anything new to my truck in a few weeks so I am kind of clueless to what could be causing my truck to keep blowing fuses. I would go out and get more but I don't want to risk getting pulled over. Any input would be much appreciated.
    ChadsPride likes this.
  2. Oct 20, 2008 at 10:00 AM
    Brunes
    Brunes abides.
    Rotorhead
    What are the last few electrical related items you've done to the truck?? Whatever they are-Go back and check all the grounding points. Get some dry towels and some sandpaper and alcohol- Clean all of them and make sure they are solid contacts.
    My buddies WRX has a full engine grounding harness that had to be cleaned and re-installed after we dropped his hew HID headlights into the car. It's hinky that it jsut started outta no where without a related mod- but it's a great place to start.
  3. Oct 20, 2008 at 12:32 PM
    MotoXFreeStyle61
    San Antonio TX
    The last thing I did was install my XM satellite radio and that was over a month ago. I'm about to go grab some more fuses and start trouble shooting. I think it might have to do with my fog lights being tapped into my parking lights, possibly causing a short somewhere.
  4. Oct 20, 2008 at 12:38 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Last time that happened to me it was in my Corolla. Nearly identical symptoms. A real fun time to find it.
    It was the wiring at the trailer hitch. Rubbed through in one spot, only grounded out when I made a right hand turn.
  5. Oct 20, 2008 at 12:48 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    SOunds like your problem. Is Relay big enough..how did you do it?
  6. Oct 20, 2008 at 1:26 PM
    MotoXFreeStyle61
    San Antonio TX
    That's what I thought too. But I disconnected my fogs and tested it again and I blew the fuse once again. I downloaded the Taillight circuit just to see what all is in that circuit. The problem is my aftermarket alarm is also tied up in there somewhere. I didn't do it myself so I have no clue how it is hooked up. I noticed about a couple of weeks ago, when I armed and disarmed my alarm my parking and tail lights didn't flash anymore, yet to my knowledge my parking lights and tail light still worked fine at the time. I attached the diagram.
  7. Nov 23, 2015 at 4:44 PM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    What was the issue here? Having the same problem
  8. Dec 13, 2016 at 2:29 PM
    MyTaco07
    MyTaco07 Member
    Summit County, CO
    2.5 bilstein UME 885 total chaos uca custom brute force fab high clearance rear and custom front bumpers 285s Warn power station winch remote pop 'n lock tailgate with mobtown reinforcement gait and cap 4 row led light bar and pods- front and rear all led interior and dash double din
    did anyone find the solution? my tail lights, and front markers are out. but my dash lights work. keeps blowing fuses. i have trailer lights, but i'm pretty sure it's aftermarket.
  9. Jun 6, 2017 at 1:15 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    Im in the same boat. Out of no where my 10amp fuse keeps blowing . I already checked the tail light harness , license plate and front makers. The relay clicks so i know its working.
  10. Jun 8, 2017 at 11:14 AM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    I have heard of aftermarket trailer wiring kits going bad after a time. To check you will have to pull the tail lights and reconnect without the trailer plugs, then try a new fuse. No blown fuse= bad trailer kit.
  11. Jun 11, 2017 at 1:12 PM
    lilgerber
    Aaron
    Fresno, CA
    Yeah tried that still popped. I unplugged my tail lights, licence plate lights, front markers, AC controls and trailer harness and its still popping. What else does it swnd power to?
  12. Jun 11, 2017 at 1:53 PM
    tacoma4
    tacoma4 Well-Known Member
    Accessory Meter
    Clock
    Combination Meter
    Engine Control (1GR–FE)
    Engine Control (2TR–FE)
    Illumination
    Taillight
    Trailer Towing
    Or a short in any of the wiring
    Jimmyh and JoefromPTC like this.
